Question about Horizon Fitness T202 Treadmill - Sport Chalet
My treadmill belt is sliding from left to right
  • 3,904 Answers
One of your rollers is not running true or straight causing this. Take the belt off and see if it is visibly off. Also check to see if there is an adjustment that you can do to straighten these out. This can also happen if the belt is bad and stretched. Could be just time for a new belt.
Posted on Jan 21, 2013
Bremshey treadmill maintenance treadmill belt slipping
Fit new belt ,check for slide adjuster slots.
Aug 13, 2014 | Exercise & Fitness
Belt keeps sliding from side to side
You have not properly aligned and / or adjusted the tension. If it is SLIDING then you do not have enough Rear Tension. Once you get the right amount of REAR TENSION, then you have to adjust the left right (balance the belt). Your belt should go straight, right now you have it too far to the FRAYED SIDE. Turn the Machine on, have your Hex Wrench in the Bolt and turn it slowly CW and as the belt come back to Center, watch the adjustment. If it continues to go past, then loosen it a little until you have the right balance. Remember REAR TENSION FIRST... THEN BALANCE for Alignment
Mar 03, 2014 | Proform Crosswalk 395 Treadmill
How do i get the belt to stay inline? it keeps sliding to the side causing it to 'fold' when i rotates.
On both ends of one of the rollers are adjustment or takeup screws. You may need a screwdriver or open end or allen wrench to adjust them. If the belt is moving toward the right, adjust the right side of the rollers to be farther apart (if I'm not mistaken). This should cause the belt to walk to the left. Run the machine and watch for belt movement. If the belt is tightening too much, adjust the left side to make the rollers closer together. These adjustments are best made while the belt is running, but BE CAREFUL!
Gary
Jan 09, 2011 | Proform 380 Treadmill Walking Belt
The walking deck on my Weslo Cadence 975sel slides to the right and causes a loud rubbing noise. How can I correct this problem? Thanks,
Find the allen key that came with the machine. If you don't have it, you will need a 3/16" allen key to adjust the roller.
If the belt is pulling to the right, adjust the right screw by turning it clockwise 1/4 turn with the belt moving. You may need to do this more than once. Between adjustments, watch the belt closely to see how much it moves to the left.
Unless something dramatic has happened to the frame or some other part, the amount of adjustment should not be too great..
Dec 17, 2010 | Treadmill Doctor Weslo Cadence 930...
Belt slipping and moving
Here is a basic procedure that will work for the majority of treadmills out in the market:
If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt clockwise, and the right bolt counterclockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill for a few minutes. Repeat until the walking belt is centred. b. If the walking belt has shifted to the right, first remove the key and UNPLUG THE POWER CORD. Using the allen wrench, turn the left rear roller adjustment bolt counterclockwise, and the right bolt clockwise, 1/4 of a turn each. Be careful not to overtighten the walking belt. Plug in the power cord, insert the key and run the treadmill
Jul 15, 2010 | Treadmill Doctor Weslo Cadence Dx10...
The belt seems to slide to one side on my Proform Crosswalk 380. How do I fix it?
PROBLEM: The walking belt is off-center or slips when walked on SOLUTION: a. If the walking belt has shifted to the left, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn the left idler roller bolt clockwise 1/2 of a turn. Be careful not to overtighten the walking belt. If the walking belt has shifted to the right, turn the left idler roller bolt counterclockwise 1/2 of a turn. Then, plug in the power cord, insert the key, and run the treadmill for a few minutes. Repeat until the walking belt is centered.
Feb 27, 2010 | Proform 380 CS Treadmill !
My weslo cadence 200 treadmill belt keeps slipping to the left. i keep tightening and loosing it to keep it even but i keeps sliding to the left
please look under the bottom of the treadmill and be sure that your alignment brackets are not benmt/missing. (put the machine in the storage position and look about 2/3 way down the side of the belt) you should see a metal bracket on each side pressing in on the belt. They should be pressing in about 1 1/2 -2 inches to help track the belt.
Nov 24, 2009 | Proform XP Weight Loss 620 Treadmill
Belt slides to one side
if this is a resident unit. check the back of the unit. make sure there are no broken plastic pieces. if so this could be why you can not adjust the guide. if there is no broken pieces use the right screw to adjust guide. left to make belt go right and right to make belt go left.
Aug 03, 2009 | RTO Stairmaster Clubtrack 510 Treadmill
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
My belt keeps sliding to the left
The rollers in the front and rear need to be adjusted. If its sliding to the left, than the left side needs to be adjusted out until the belt stops going that way and stays on straight.
Jun 08, 2009 | Proform Crosswalk 500 Treadmill
Horizon Fitness T202 Treadmill - Sport Chalet Logo
80 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Matt Olenzek
Matt Olenzek
Jerry Kramer
Jerry Kramer
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
