Question about Dell XPS Computers & Internet
Had a virus and now computer won't read the cd drive. I can't boot from the install disk because there's no driver.. Any suggestions?
Is there something in the registry that I can fix so computer will read this drive? Thanks foor your help!
  • Dell Master
  • 27,725 Answers
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. if this fails to fix the problem
It could be a problem with the lens you could use a liquid type lens cleaner place 2-3 drops on top of a cd/dvd then run it Hope this helps
Posted on Jan 22, 2013
  • 1 more comment
  • app_3rp73358
    app_3rp73358 Jan 22, 2013
    Thank you so much! I will try all your suggestions and see if it works. Basically I
  • app_3rp73358
    think this was a worm as all my folders and many programs were hidden. I managed to get most of them unhidden but it wsn't easy. I really appreciate your time.
  • Brian Sullivan
    Brian Sullivan Jan 22, 2013
    well done hope it all works out
Hanto
  • 226 Answers
SOURCE: HP Pavilion a220n cd-rw won't burn
Have you tried this firmware update from HP yet. This particular update from June 2004 indicates that it primarily addresses an audio performance issue, but rarely do any firmware updates also not address media recognition that would help the CD/DVD writer both read and write to specific blank media.
It is highly unlikely but not impossible that a virii infection would cause you inability to write to media, much more likey that the CDwriter is trying to give up the ghost. Before assuming to much tho, get some canned compressed air and blow into the cdwriter with tray open. This may more a simply issue of some foreign material sitting on the lens of the laser that allows you write to media. Be aware while this may be the latest firmware from HP on this particular CDwriter, that does not mean that there are not other later firmware updates from other souces. HP and all the OEM companies have a bad habit of taking their time about issuing updates and rarely if ever follow a product to completion of its update cycle. In other words remember this is a Sony product, not a HP product even tho it is in a HP computer.
If more information is needed come back to us and don't forget to rate us, as that is the only compensation we are getting for these long drawn out explanations and research on your product or problem.
Posted on Aug 30, 2008
SOURCE: Dvd/cd Driver not working
My CD/DVD will not work. I get a message stating that the drivers are missing. I have a Restore CD from eMachines to install the drivers but cannot use it as the Drivers are not working!!!
Posted on Oct 26, 2008
  • 3 Answers
SOURCE: Problem with Inspiron 530S Desktop Reading CD's
If your computers are relatively old then they may not be able to burn CD's or read CD's that were burned. A new CD/DVD burner is relatively inexpensive and easy to install.
Posted on Jan 02, 2009
  • 461 Answers
SOURCE: Boot CD is not being recognized when trying to install hard drive
Why not use the Vista disc to format the drive. At the bottom of the Install screen after the License Agreement you should see Drive Options (Advanced) where you can select the partition. You may have to create the partition using the New option, but formatting is automatic with the Vista install. If you are not able to do this something may not be correct with the drive setup - either jumpers or BIOS settings.
Posted on Jan 10, 2009
pumpkinman
  • 1165 Answers
SOURCE: working device (DVD/CD rom burner/reader) not reading disks
try rolling back the driver
Posted on Jul 01, 2009
540 wont boot up
The hard drive could be corrupt, this will cause the operating system to run the error checking. If you had a virus, and it infected any windows files, windows will check the files, but if it can\'t fix them, then it won;t run. You can try to enter safe mode, tapping F8 at boot, you should see a option to repair or restore. If not see if you can enter Safe Mode.
In safe mode you can go to start button, all programs, accessories, system tools, system restore.
You can also get a windows install disk, same version as you have, and put in the disk and hit F11, and boot from the disk, and run a repair from it.
You really should go to the website Avira, and download the rescue disk, burn it to a CD. This will run a virus scan of the hard drive before windows in DOS.
If there is a virus, it will kill it. But there is a chance it can\'t clean the virus and windows won\'t start.
The other option is to just erase the hard drive, not format, erase it with a program like Active kill disk. Then reinstall windows, all the drivers.
Mar 31, 2013 | Dell Studio 540 MT Pentium DualCore E5300...
I get a disk read erroroccurred after I have installed a new hard disk. How can I get my computer going again?
The problem is that XP installation CD does not have a SATA driver, unless you have a SATA drive on a disk etc. and can install the driver when XP asks for a hard drive driver then, XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS and disable the SATA drive (enable IDE emulation), this will make XP think it is a IDE/PATA hard disk. Then you can install XP normally. When Windows has been installed then install all the device drivers (including the SATA driver), then shut down and boot up and got into the BIOS and enable the SATA drive.
Aug 15, 2012 | HP Compaq nx6325 Notebook
Lenovo B560 virus?
If there is a virus simply reinstall windows it will get rid of it permanently hope that can help if you need to know how:
need the windows disk and serial code then you need to boot up your computer and as soon as it begins to turn on press the corresponding button for boot devices this will bring you to a list showing you hard drive CD drive and other peripherals , insert the windows disk and then use the arrow keys to select the CD drive from there just follow the basic next,next,agree installer then i would suggest installing the drivers then all your programs
Mar 01, 2012 | IBM Computers & Internet
Good Day! i have a aspire 6930. I've had it for a
The average life of a laptop is 5 years. Your model was made in 2008. Replace it.
Mar 01, 2017 | Acer Aspire 6930-6455 Notebook
ACER ASPIRE 3750G 13.3", reformat.
when you turn the unit on hit Alt+F10. This will access the acer recovery partition from which you can restore. This is provided you didn't replace the Hard drive or wiped the drive yourself
Aug 02, 2011 | Acer Computers & Internet
I own eMachine Notebook e525 and it won't read any disks. I have tried multiple disks such as music cds, installation cds and video dvds. None of them read or open. There isn't even an icon for the...
> there is no icon for the CD-drive
Probably means that either:
* no electrical power is reaching the CD-ROM drive
* no "data" is being transferred to/from the drive
* the electronics inside the CD-ROM drive have "died"
Check the "power" and "data" connectors.
If necessary, replace the drive with a new CD/DVD reader/writer.
Jun 20, 2011 | E-Machines emachines (emachinees) CD-ROM...
RM Z91FR laptop I want to remove the windows "Vista Ultimate" operating system and go back to XP Vista has slowed the machine drastically and filled the HD. I also want to instal a larger HD...
try to format all your drive by deleting your partition..insert your xp cd room boot with cd room press enter, press f8 press esc, press d, press l, then press c and enter
May 06, 2011 | ASUS Computers & Internet
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
Have a virus in the harddrive nothing of importance on computer I would like to format harddrive .I have another xp cd to use need instuction on how to do this please help
What I am about to tell you is not a normal solution. If you don't have anti virus to use to clear the virus out or access to another computer to get something like "Stinger" from McAfee you can format and install the OS again but if you don't do it just right the virus will just put itself back in. This assumes you don't want to save any information on the drive whatsoever. Get a DOS boot disk from another computer and write protect it. Remove the battery from the laptop and connect the power cord. Insert and boot the computer from your DOS boot disk. I prefer to use "Knoppix" for this procedure because it is a Linux based OS that runs from the CD Drive and is Free. Cost about $3 at a used book store if you get a book with it. Using the DOS disk once the computer is booted switch to the C drive and type "part" or "fpart" this should bring up the DOS partitioning tool. Select the option to remove all partitions. Once complete reboot the computer using the DOS disk. Now Format the drive using "format c:" command. Remove the DOS disk and disconnect the power cord once the format is complete. You don't want to power down you just want to pull the cord, this is to stop the Virus from writing itself back to your disk from memory which is what will happen if you use the power button. Plug the cord back in and insert your XP CD in the drive then boot the computer from the XP CD and select to format the Drive in NTSF in the Windows installation process. This should remove all traces of the virus unless it is an MBR virus in which case you will have to get a tool like "Stinger" from McAfee. This tool is free to down load and can be run from a 3 1/2 floppy that is formated as a boot disk. The process will get rid of most viruses but something like 123MBR or any of the other MBR viruses will remain because they write themselves to the Master Boot Record which is the first thing the computer loads once it reads the Drive. These MBR viruses are read into memory when the computer starts which is why that are so hard to get rid of and a simple Format doesn't really touch the upper segments of the Master Boot Record where they reside that is why you had to do a partition in the beginning of the process.
Feb 12, 2011 | ASUS Eee 1005HAB (1005HAB-RBLU001X)...
I think I went to a virus riddled website. My computer shut down. Now when I restart it, it comes on for a few seconds and a blue screen pops up and tells me Windows is shutting down to prevent damage. How...
avg makes a down-loadable boot disk download this and burn to disk select your dvd/cd as your first boot device then and follow on screen prompts. the virus as corrupted the MBR (master boot record ) that may have to be repaired after the virus is removed
Oct 21, 2010 | Computers & Internet
Computers & Internet Logo
77 people viewed this question
Alun Cox
