I have a tosiba satellite pro A200 i am trying to burn dvds and pics onto dvds but it keeps coming up that the disc is not compatable with mt disc drive and the write speed is to fast what can i do to fix this?
    Problem Solver:
  • 12 Answers
You might be able open the software you are using to try to burn the DVD and manually set the speed of the DVD burner so it matches the speed of the DVD.
If you need help with this, I will need the name of the software and the brand and speed of the DVD you are using.
Posted on Jan 27, 2009
When I try to burn data files to a CD-R disc on my toshiba satellite M1115, it repeatedly tells me to insert a disc, when I have put a brand new disc in. I have used the drive to burn music discs &...
It sounds like you are trying to burn too much data onto the disk. If you want to test this theory, you can burn a small amount of data to a blank CD-R to see if it works. If it does then you do not have a hardware problem. This will be good news.
There are different sizes of CD-R media, 650MB, 700MB and larger sometimes. If you select 700MB and try to burn to a 650MB media disk, the drive will just spit out the blank disk so as not to ruin it for a future burn. Also, if you are going to make a multi-session disk (or you have accidentally selected multi session, then you will automatically waste 22 MB leaving you 650-22 /628 MB, or 700-22 or 668 MB of space to burn your data. Each additional session will also take up 22 MB of space.
There is also a chance that the media you are trying to burn to is not compatible. Some lower end brands do not use enough reflective material for some burners. You can test this theory by trying an alternate brand of media.
Aug 30, 2011 | Toshiba Satellite M115-S3094 Notebook
Hello, I have a Toshiba laptop A200 - EZ2204X with a model number of PSAF4U now my problem exactly that i have got the recovery discs on a DVDs and after that I have lost them .... and now the windows...
For recovery disks set, they are available only for purchase. You can buy the recovery disks for your laptop on http://recovery-disks.com/toshiba/toshiba-satellite-pro-a200-ez2204x.html.
What I can suggest if you don't want to pay for these disks is to format and install Windows and then you can install free software like Driver detective to know what drivers you will need. Once you have the list of drivers, you can download them from websites like driverguide.com.
Note that formatting your laptop will result in losing everything you have on it.
Hope this helps.
May 19, 2011 | Toshiba Satellite Pro A200-EZ2204X...
How do i restore my toshiba satellit pro a200 back
If you have a backup, you can do that, off your hard drive. Otherwise, you will need to get a replacement disk from Toshiba.
Feb 25, 2010 | Toshiba Satellite Pro A200-EZ2204X...
The headphones on my Tosiba Satellite Pro A200 dont work
it might be hardware technical problem.. i think headphone censor in the port is not working get it repaired from local service centre
Oct 01, 2009 | Toshiba Satellite Pro A200-EZ2204X...
I don,t have recovery disc for toshiba satellite A200
haven't mentioned the os and service pack version
download recovery disc here
http://coblitz.codeen.org/neosmart.net/downloads/guides/Vista_Repair/Vista_Recovery_Disc_x86.iso
burn it a cd using nero or any other image burning software
Jul 09, 2009 | Toshiba Satellite P205-S6287 Notebook PC
Bios Pasword
Unfortunately, if you can't remember your bios password you'll have to reset the CMOS. This is usually done via a jumper on your laptops motherboard itself, or removing the battery on the motherboard while the laptop is unplugged and the main battery is taken out. Be very careful when opening up your laptop, make sure all the screws needed are removed, as they are easy to miss. If you don't feel comfortable opening up your laptop, I would recommend taking it to a certified technician.
May 06, 2009 | Toshiba Satellite Pro A200-EZ2204X...
Dvd burner not working
It sounds like the DVD burner does not have a "write strategy" for the type of disc you are using. This results in the burner and the software having an endless argument about how to go about the burn!
You can either use another brand of disc more compatible with your burner or go to the DVD burner's manufacturer's website and check for "Firmware" updates.
The firmware is the software within the drive that establishes the write strategy for each type of disc and these are often updated.
If you do update the firmware then be sure to read the instructions on the manufacturers website carefully and follow them EXACTLY.
Jan 27, 2009 | Toshiba SD C2512 (SD-C2512) Internal DVD...
I have a Sony CRX320E CD/DVD unable to write a DVD
CD-RW drives can only read all CD-rom and CD-RW formats and read DVD formats but cannot write to a DVD, if you want to write a DVDs you need to buy a DVD-RW burner which can burn all CD-formats
Jan 16, 2009 | Sony (CDR320E) CD-RW/DVD-ROM (Combo)...
Problem with sonic record now
You have to format the cd to prep it for burning. Go to your operating system's help and support and look for formatting a cd and follow the steps to do so prior to burning pictures. then you just drag and drop your pics onto your cd drive.
Nov 22, 2008 | Toshiba Satellite A105 Notebook
Computers & Internet Logo
David Payne
David Payne
