Question about Horizon Academy Sports Fitness T202 Treadmill
The T202 belt is not in the center - Horizon Academy Sports Fitness T202 Treadmill
    Genius:
  • 1,669 Answers
At the end of of the running beltsThe T202     belt is not in the center     - 2_bing.gif in the end caps will adjusting bolts you will need a allen wrench to adjust the tension. Start your treadmill2_bing.gif and turn clockwise a 1/4 turn each time see i f you can stop the belt. You need to be aware that the drive belt can also cause this problem so I suggest that you remove the motor shroud and when you are adjusting whether the front roller is moving and the running belt has stopped or the roller has stopped and motor is rotating ( adjust Drive Belt)
Posted on Jan 21, 2013
What is causing my Treadmill T202 to display a "connection" and make a loud beeping sound?
you should remove the motor cover and inspect to see if you can locate where is came from. check the incline motor
Aug 09, 2014 | Horizon T202 Treadmill
The fan on my Horizon T202 stopped working . Any Suggestions?
if the fan still turns by hand it is likely the temp sensor or power source check if there is a fuse or review a manual for location of the sensor.
Jul 19, 2014 | Horizon Fitness T202 Treadmill - Sport...
How to center walking belt?
Most treadmill belt adjustments are controlled by the bolts on the back of the machine on either side of track rails. Loosen opposite side of track while running and the track will move over and tighten when in desired spot. Be care not to have it running to fast or the belt will quickly move to far over. Running for a few minutes on hire speeds after adjustments are complete to make sure belt is not in need of fine tuning.
Horizon t202 treadmill makes a constant beeping with the word "connection" displayed on dash board.
1) adjust the REED switch see the diagram attached. Clean it+ 2)test for open or faulty 3) tight the connector very well.
2) tight the upper and lower connectors very well and clean it.
3) inside from console tight the ribbon cable and clean it
Sep 02, 2013 | Horizon T202 Treadmill
My treadmill belt is sliding from left to right
One of your rollers is not running true or straight causing this. Take the belt off and see if it is visibly off. Also check to see if there is an adjustment that you can do to straighten these out. This can also happen if the belt is bad and stretched. Could be just time for a new belt.
Jan 21, 2013 | Horizon Fitness T202 Treadmill - Sport...
Unlock code for huawei t202
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Oct 18, 2012 | Cell Phones
Unlock code for huawei, model T202
To Unlock HUAWEI T202 model Mobile use unlock code...Visit the site
Prounlocking.com/huawei-t202/rs8wp9/ get the Unlock code and unlock it from network lock easily...
My horizon t202 treadmill wont start i cant even located the on/off switch where is that? I see the reset button
Normally the button and reset is in FRONT from the machine is you stand from the machine in the lower part, Is RED and at the side is reset button.
2) Test the fuse inside see the block diagram , test and replace.
3) Test the power cord for open, break
4) test the outlet wall, reset the breaker from you house, DO not use any extension cord. and proof again.
5) If you can NOT resolve the problem, you must call to the service tech,.maybe you have problem with some component, inside capacitor, transformer in the power supply.
God bless you
Sep 03, 2012 | Horizon T202 Treadmill
How do I fix the on/off switch for and ATW-T202?
Had the same problem - faulty switch. The switch was labeled ALPS so did some searching and found a replacement switch at Mouser Electronics. P/N SSSS928200. Switch is $.64 + shipping. So I ordered 3.
Best way to replace it is destroy the old switch in place careful not to damage the solder lands on the PCboard. Then unsolder each pin using minimum heat to not damage the PC board. Insert new switch an resolder. Note carefully the routing from the pins so if you do damage a land a short piece of wire to its destination will replace the damaged routing.
May 05, 2009 | MCM Audio-Technica ATW-T202 Microphone
Horizon Academy Sports Fitness T202 Treadmill Logo
64 people viewed this question
Top Horizon Exercise & Fitness Experts
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Are you a Horizon Exercise and Fitnes Expert? Answer questions, earn points and help others
