Question about Canon Powershot A2000 IS Digital Camera
I reset the camera and all the pictures have gone missing, how do I find them
    Genius:
  • 1,019 Answers
If you have not saved them on the memory card they are gone !!!!
Posted on Jan 25, 2013
Pentax/Optio E10 family get together, camera was shooting too slow, granddaughter grabed the camera and went to RESET it to shoot faster and now ALL my pictures are GONE that I had on my disk. She just...
You do this first try to connect your camera to a computer and check if the memory card has some files inside it, you can also put the memory card on a card reader and check the content of the memory card hopefully it still has the pictures but if the memory card is blank you can try some data recovery on the internet that can retrieve lost data ....
Hope that helps........
Aug 10, 2008 | Cameras
I have a Canon PowerShot A630. Everything was just fine, but now I can't download the pictures from my camera to my computer. I get a message "can't find camera" or "missing component"....
Hello
The problem likely to be in your computer, the might gone corrupt, try this camera to other computer then it will clear the problem.
the instant solution to move your data if it is in memory card, use card reader and move your files to computer.
Scan you computer with latest virus remover.
Good Luck
Jan 08, 2011 | Cameras
LCD screen is blank in normal picture mode. I
This Camera has an CCD issue. It seems that the CCD of the Camera is gone bad. However, you may try resetting the Camera to the factory settings. If the issue persists, try power resetting the Camera. To power reset, remove the battery of the Camera and press and hold the power button for 30 seconds and reinsert the battery after one minute and check the operation. If the issue still persists, the service is required.
Jul 26, 2010 | Sony Cyber-Shot DSC-T1 Digital Camera
Deletion option for "all images" has gone missing
Go into the menu and find "format"...follow the on-screen instructions.
May 04, 2010 | Nikon COOLPIX S6 Digital Camera
I press the reset button and all my pictures are gone is reset delete.
no. it means your pictures were probably on the internal memory or you formatted your memory card
Feb 27, 2010 | Samsung L100 Digital Camera
Retreive erased pictures from my camera - cowbell@bnin.net
Sorry to be the bearer of bad news, but once pictures are erased, they're gone for good. The memory is a flash type, and erasing the pictures resets all the information in the camera. Be careful, because some things (as this) are irreversible.
Feb 22, 2010 | Olympus FE-280 Digital Camera
Missing pictures
Hey flowernthe,
The error message “card cannot be read" means there was and error when the camera tried to access the memory card. To fix this you should make sure you are using the right kind of memory card, which for this kind of camera is a SD card, and it does not support SDHc cards. Since this camera uses SD cards I would make sure the slider on the side of the card is not set to the locked position. If this doesn't help I would make sure the memory card connecters are clean, and if they're not you can use a rubber eraser to clean them up. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 11, 2008 | Nikon Coolpix 4600 Digital Camera
Cannot access pics
Once you took pictures without a memory card, all pictures taken will automatically be saved on the INTERNAL MEMORY of the camera.
When taking pictures with a memory card, all pictures are just saved on the memory card itself.
If you are seeing 100-757 on the LCD screen. It means that there are already 757 pictures taken from the first time you've used the camera.
It is possible that some of the pictures are in the internal memory and some are in the memory card.
STEPS to DOUBLE CHECK:
1) Remove memory card out of the camera
- Turn on camera
- View pictures on the internal memory
by just pressing on the PLAY mode button
(lowest of the 3 little buttons)
- Pictures seen are just the ones saved on the internal memory
2) Return memory card back in the camera
- Turn on camera
by just pressing on the PLAY mode button (
- Pictures seen are just the ones saved on the memory card itself
*** If you want to transfer pictures on the internal memory of the camera to your MEMORY CARD, you just have to follow the steps below:
- Make sure there is a memory card inside the camera
- Turn on camera
- Press on PLAY mode button to view pictures
- Press MENU/OK button
- Keep scrolling to the right until you see COPY TO CARD
- Select YES using the arrow keys
- Press MENU/OK to confirm
* When you've done these steps, all pictures from the INTERNAL MEMORY of the camera will be copied to your MEMORY CARD but it depends on the space left on your memory card
** If still, you could not view the pictures, it's possible that the pictures are really gone when you have transferred the previous pictures to your computer.
** Once you have transferred pictures to your PC, and you have deleted those on your camera, the FILE NAME of the pictures will not start from 100-001 again unless you have reset the file name on the settings of your camera.
In example, i already have 256 pictures on my camera so the filename reads 100-256 for the last picture taken. And then i decided to transfer those 256 pictures to my PC and i deleted those immediately after being transferred. So, as i took another picture, FILENAME will start with 100-257 if i have not reset
the FILE NAME settings to 100-001.
Hope i've helped you enough.
Jan 02, 2008 | Samsung Digimax S630 Digital Camera
Memory card & USB
afraid i dont think there any other way on that model of camera. you will require a cable, a good site to get the cable would be www.ebuyer.co.uk as they good prices and a large selection of stock.. John
Mar 01, 2007 | DXG Technology DXG-308 Digital Camera
Canon Powershot A2000 IS Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
