Question about Vehicle Parts & Accessories
My 2008 gran Prix has no heat but blows cold air
    New Friend:
  • 60 Answers
I dont understand your question fully? It could be your thermastat, heater core (which in most cases your passenger floor will be wet in the front) maybr even not enough anti-freeze... Good Luck
Posted on Jan 21, 2013
  • dennis broombaugh Jan 21, 2013
    Hoses to and from radiator are hot , one hose to heater core is hot other is cool like heater core is pluged , could it also be valve not working
  • Dave Matthews
    Dave Matthews Jan 21, 2013
    Has to be heater core then because if both top and bottom hoses are hot then water is getting through the block and therm. but not heater core!
  • Vehicle Part... Master
  • 3,904 Answers
It is more than likely one of two things here. Thermostat or your heater core. Pray it is your thermostat.
    Thanks I was hoping it wasn't the heater core
  • dennis broombaugh Jan 22, 2013
    Is there a good acid flush or should it just be changed
2008 Grand Prix GXP keeps blowing the 10amp fuse for the AC. When replaced, it runs cold again until I start driving, then it blows and only has hot air once again. Very frustrating in Texas heat!
13
A/C CLUTCH Fuse
10A
A/C COMP Relay - try replacing the A/C compressor clutch relay # 38 in under hood fuse / relay box . ! Could be shorting out after hot . I don't won't to get to technical on you, doing voltage drop testing on the circuit . If not relay the compressor clutch coil could be going bad when heating up . There are videos on you tube , testing A/C compressor clutch relay .
Jul 05, 2016 | 2008 Pontiac Grand Prix
I have a 2008 Toyota Corolla and heat on the left side and the right side is cold, what to do?
Heat is blowing on passenger side, but cold air ... - RepairPal
repairpal.com > Questions > Dodge > Ram 1500 > 2002 Dodge Ram 1500
Dec 7, 2009 - When I turn on the heat, the passenger side is receiving warm/hot air but ... blow hot air on the drivers side and it would get cold right away. about a week ago... I have a 2008 Dodge Ram 2500 SLT. ... Regardless of the settings cold air blows from the left vent and on the floor on driver and passenger sides.
Temperature Blend/Recirculation Doors May Fail and ...
repairpal.com > Problems > Jeep > Grand Cherokee
2008 Jeep Grand Cherokee143,000Visitor. I get cold air on driver side and warm air on the passenger side. Upvote (29) ... right side air is always at the coldest. no heat on the right side and air temp will not change, left side works good. .... Models: · Honda Accord; ·; Toyota Camry; ·; Honda Civic; ·; Acura TL; ·; Toyota Corolla ...
Heating and AC Temperature and Air Delivery Mode Do
Jan 16, 2016 | Toyota Cars & Trucks
Passenger side blows cold air--what part could it be
2001 Chevy Tahoe Heat Problem - Tahoe Forum
www.tahoeforum.com > ... > Technical Discussions
Dec 5, 2008 - 10 posts - ‎7 authors 2001 Tahoe, the front heater blows a little hot air when the car warms up and then blows cold air. The rear heat seems to work fine. I changed ...
Rear AC blows hot air - Tahoe Forum - Chevy Tahoe Forum
Jul 14, 2008 - 10 posts - ‎5 authors
On my wifes 03' Yukon the rear air conditioning blows hot air no .... Pull the panel off and look at the hot/cold actuator shown in the picture.
Oct 30, 2015 | 2001 Chevrolet Tahoe
My 2000 grand prix blows out cold air when its on heat
Could be air in the cooling system , try an bleed the system . On top of the thermostat housing is a bleeder valve , with the engine up to temp. open valve till coolant comes out . Is the coolant full ? What color is the coolant ? Have see where coolant turns like a muddy color an clogges the heater core an engine coolant passages . Check the heater hoses going into the fire wall ,are they hot ? Does your grand prix have manual or automatic climate control ? Duel zone ! Do you hear a clicking sound behind the instrument panel ? Bad temp blend auctuator .
Feb 20, 2018 | 2000 Pontiac Grand Prix
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital...
I have a 2000 pontiac grand prix with a digital climate control system. The heat quit working, it doesn't blow out any heat. Now that it is warm outside the air stopped blowing out any air. The digital temperature on the climate control is not correct. When it states that it is below 30 degrees on the ext and it is warm outside the air wont be cold. Once it starts going above 30 degrees the air gets colder. Today the blower stop working all together. Was told it maybe the climate control unit was bad. You can hear the door opening/shutting when you switch the temp from cold to hot. But there was no heat blowing out whatsoever in the winter time. Could you please give me your opinion on whether or not it is the climate control unit or something else?
Jul 11, 2011 | 2000 Pontiac Grand Prix
Even if my 2008 grand prix is completely warmed up, when I turn the fan on it only blows cold air.
Could be air in cooling system. Add antifreeze to cool radiator, run engine, cool, check level again, until completely full.
Jan 12, 2011 | 2008 Pontiac Grand Prix
2008 Pontiac Gran Prix,Radio MP3 line-in/aux-in
The upscale model is the only that i know of that has one. What model do you have?
Oct 15, 2009 | 2008 Pontiac Grand Prix
Only the passenger side vents blow cold
The cabin filter might be clogged, try replacing it.
Sep 30, 2009 | 1999 Pontiac Grand Prix
Heater control not working on 1997 pontiac Gran Prix
There is a flat filter that sits between the firewall and the blower. Sometimes the filter is blocked and needs to be cleaned or changed. On older cars the filter is located on the firewall in the engine compartment infront of the blower. In the newer cars the filter is under the dash inside the car and much harder to get too.,
Sep 14, 2017 | 1990 Porsche 944
2004 pontiac gran prix gt
I would suggest replacing the blower motor resistor. When this component fails the blower will only work on one spped or none. This is a very common issue with all automotive models
Nov 04, 2008 | 2004 Pontiac Grand Prix
Vehicle Parts & Accessories Logo
42 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
