Question about Holmes Products Heating & Cooling
Switch broken on holmes hoh 2000 - Holmes Products Heating & Cooling
I need a 3-speed fan switch for a Holmes stand fan #HASF1522
Just a thought
If you find a junker fan try the switch off of it. Quite often they will work. Sometimes different makes the switches are interchangeable.
Jan 31, 2015 | Holmes Products Dryers
Refill cap center plunger is broken
I dont see any other way to fix other than purchase another cap...
I ordered 2 replacement caps from here they were the cheapest tat I found http://www.jardenstore.com/productdetails.aspx?BrandId=494&pid=1783 but they seem to be out of stock at the moment These http://www.appliancefactoryparts.com/humidifiers/holmes/holmes-water-tanks.html are 3 dollars more here hope this helps
Jan 29, 2014 | Holmes Products Warm Mist HM5700...
It gets hot near the switches and there is a burn mark there.
You should contact Holmes immediately. This is a fire hazard and people can get hurt. They should assist you right away in getting your dangerous unit replaced.
Oct 15, 2013 | Holmes Products Air Purifiers
Needc to replace three speed switch for portable house fan.
Try contacting the company that built it, on line. There are shops around that repair items like yours. Try an electronics store, ie- Radio Shack
Oct 07, 2010 | Holmes Products Holmes Patton...
Holmes HM4600HD humidifier tank
Mine dried out too. I could not find where to get the rubber valve seal for the tanks. Holmes does not list the part and when I called the rep told me they didid not stock the part. I solved my problem by purchasing thin rubber washers from Lowe's. They are 3/16 X 1 1/4 X 1/16 thick. The 3/16 hole in the center "snaps" on over the end of the plastic plunger just like the original. I had to trim the outside diameter with scissors to about 1" or using the old ones as a guide. Cost me $0.67
Nov 09, 2008 | Holmes Products HM4600-U 11 Gallon...
Heater will not operate!
did you take it apart to see if the switch is good or the thermostat was functioning?  without looking inside, other than saying it don't work, isn't going to solve anything.
Oct 16, 2006 | Holmes Products HOLMES COMPACT OIL FILLED...
Heating & Cooling Logo
106 people viewed this question
Top Holmes Products Heating & Cooling Experts
Paul Carew
Gil Shultz
Paul Bade
Are you a Holmes Products Heating and Cooling Expert? Answer questions, earn points and help others
