Samsung model HL-S6187W DLP TV NOT BRIGHT PICTURE
jerryg50
  • 1667 Answers
SOURCE: 46" Samsung DLP Lines & Freeze up
This is a possible fault in the power supply, and can be a problem with some decoupler caps on some of the boards. The vertical bars and unstability are usually attributed to having high frequency noise and or clocking pulses crosstalking on to the power distribution lines that run through the boards. This can be switching power supply noise, or cross-talk from clocking pulses.
Another thing that can cause your described fault is unstable clocking between the devices that are reading and writing to the data busses. There are a number of data busses running through the set for the boards to be able to communicate with each other.
The tech will use the process of board swapping to service the set, and then do the adjustments as necessary to make sure the new boards match up.
Yes... DLP sets are fairly expensive to service!
This is my personal opinion. If the set is out of warranty, I would change for a Plasma or LCD set. If you compare the performance of these to ther DLP, the difference is very big. From what I am seeing from a service point of view, the DLP's are lower in reliability.
Jerry G.
Posted on May 06, 2008
welcomejee
  • 10594 Answers
SOURCE: Samsung DLP HL-R5056W 56" TV Problem
How old is this TV?
I think its time to replace Lamp.
Posted on Oct 03, 2008
  • 7 Answers
SOURCE: Samsung DLP TV shuts off
Hello All, I may have an inexpensive solution to your problem. I had the same problem with my TV as well. It would shutoff by itself about an hour after it was turned on. The when I would turn it on again it would shut off after 5 to 10 minutes. Finally I got fed up. I knew it was not my bulb because the picture still looks good. I did here a buzzing if I would turn the TV on right away after it would shut off. That was do to the bulb recharging itself. I noticed the TV was extremely hot in the back. So automatically I thought it was the cooling of the set. All post I read keep saying the TV would last about 2 years to a year after a service. Which would be right because (most) service repair clean out the units before installing new parts. What I did was I opened unplugged the TV from the wall and opened unscrewed the back panel door. I used my Air compresser and blew out all the dust inside. ( A can of compressed air should do the job if you do not have a compressor) I removed the bulb and blew out the dust on the bulb as well. I did not remove the bulb from the housing unit. After I dusted the bulb and housing unit I reinstalled it. I keep my home clean but you should have see all the dust that came out. The dust covering the components overheat the unit which causes it to shutdown. It has been about 2 weeks and have not experienced any problems since. All I can say is give this a try and maybe this will work for you. This will only cost you about 10 dollars and 30 minutes of your time. This is better that Hundreds of Dollar in repair.
Posted on May 25, 2009
stonephoenix
  • 563 Answers
SOURCE: tv turns off after 5 sec.
I have over 10 years experience in electronic tech support.
I know this isn't what you want to hear, but the problem you've described can't be fixed with troubleshooting. Your TV will have to be repaired. There is a part that has developed a defect and needs to be replaced. If you're still in warranty, the TV will be repaired at no charge to you. The warranty would likely be at least one year from the date of purchase from the manufacturer. If you purchased an extended service plan they will repair the TV at no charge as well.
If the TV is no longer in warranty, it will likely cost a minimum of $150 parts and labor. This is assuming that you only need one circuit board or small part. If the problem is more than one of the circuit boards, the price of repair could go much higher.
I hope I've provided you useful assistance and that this information allows you to make an informed decision as to how to proceed from here. Please be sure to vote on my response. I hope I've earned a good rating from you today.
Please let me know if I can be of further assistance.
Posted on Jul 02, 2009
  • 73 Answers
SOURCE: I have a SamSung HL-S6187W DLP whide screen tv
You need to replace the light tunnel.you will need to remove the lamp and color wheel along with the lamp housing and fan housing to replace it .If you are not comfortable taking things apart you might want a tech.
Posted on Nov 30, 2009
Samsung HL-S6187W 61 in. HDTV black screen on the right side
There's a bloated capacitor on the circuit board. That one needs to be replaced.
Aug 30, 2008 | Samsung HL-S6187W 61 in. HDTV
Samsung dlp 1080p picture is dark and brightness control is at max
I am hoping somebody will answer this because my TV is dark and I played with the controls and it is still dark!
Sep 24, 2012 | Samsung HL-S6187W - Rear projection TV -...
No picture, replaced lamp on HL-S6187W. TV makes a audio sound when I turn it on. Lamp does not light.
Did you replace the lamp? Was the Lamp original? Some time if you dont replace the lamp with original you are going to have this issue. Is there any sound. If you have sound and no picture is the Color Wheel.
Thank you,
Nov 03, 2010 | Samsung HL-S6187W 61 in. HDTV
Nov 30, 2009 | Televison & Video
Samsung dlp hl-s6187w turns itself off after about an hour of operation. Once it cools down (5 minutes) it can be turned back on. what could be problem
check or replaced LAMP-BALLAST board
Manufacturer Samsung Part Number BP47-00037A Description LAMP-BALLAST;EUC 132
Nov 09, 2009 | Samsung HL-S6187W 61 in. HDTV
Broken Mirror
you need to see if the lens where the light comes out is scratched..
if it is then the picture will never be right until you replace it..as for a cheap replacement mirror the picture might be watchable if it is a good quality mirror
Aug 01, 2007 | Samsung HL-S6187W 61 in. HDTV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
Electro Med Services...
