Question about Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2 Inch 15 Gauge Finish Nailer
Porter cable 15ga finish gun pin doesnt retract after firing
After firing the pin doenst retract, i took it apart and cleaned it and lubed it but still doesnt retract after firing. does anyone know why or is this gun unfixable?
    President:
  • Senco Master
  • 1,388 Answers
Porter cable uses a rubber band around the cylinder as check seal to push cylinder up. Pull cylinder and make sure that the band is place around series of holes in cylinder (about center of the cylinder ). If the band is in place then check for too much air leaking out of the nose due to worn/cracked bumper or lower bushing (washer with slot). If bumper and lower washer good, suspect debris in head vent preventing air form excaping or the shaft if the driver is bent (easy to check, driver should be easy to push back up from down position). Good luck
Posted on Feb 01, 2013
2 Suggested Answers
  • 1388 Answers
SOURCE: Senco SLP20 not working
Senco makes a line of nailers including the slp20 that use a firing valve (part # ba0119) that fires piston when trigger is depressed. These guns do not use oil because the oil will swell the rubber parts in the valve. When the rubber swells and tears slightly, symptoms that you describe will develop. Also remove the cylinder and look for cracks and make sure that the lower oring (LB0030) is in place and that tiny vent holes are clean. The lower oring is the checkvalve and causes the piston to retract. Use only the slightest bit of silicone lube on orings. Parts are available at www.toolpartsdirect.com. Good Luck
Posted on Jan 22, 2009
Firing pin wont retract
If you haven't gotten it unstuck by now try this: take the air line off so it isn't pressurized take a punch about the same or slightly smaller than the hammer/firing pin/the part that drives the tack, and drive it back to where it clears whatever is jamming it. Clean it, oil it and try again. If it still fails, here is a site that offers parts and kits:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/portercable/RN175/
If you have another source you can try it as well. Good luck.
Sep 08, 2012 | Porter Cable RN175 Roofing Coil Nailer
Porter Cable FN250c wont shoot with every trigger pull. sometimes it shoots correctly (10% of the time), other times it just pops (no nail) and other times it shoots two nails at once. Also when it...
Worn trigger and or worn firing valve. Remove the trigger and look for wear on contact surfaces (worn pin that holds trigger, worn inner lever inside trigger, worn or loose firing pin in valve ). Easy test for worn trigger. Remove the nails, remove trigger, fire the gun against wood with finger to test for proper action. If it works better without trigger, consider replacing trigger with new (I would also order the oring repair kit that includes the firing valve )
Jul 26, 2011 | Porter Cable-Cable FN250C 1-inch...
I have an fc350a nail gun. After firing one time, the piston will not retract until the air hose is removed from the gun.
May need a new firing valve or safety foot is sticking. Easy to check, Remove air supply, nails and remove the trigger to expose the firing pin. Connect air and place the nose of the gun against thick rubber or coiled air hose. Depress trigger and let go. Gun should fire and trigger pin will return to original position. If piston still does not retract then problem is with trigger valve and most likely the rest of the orings within the gun will need replacing. Not expensive. Remove the air supply and look closely at the firing pin, if it moves quite a bit from side to side and looks worn time to replace. If it look to be in good condition, then orings within trigger valve may be swollen and will not allow the trigger to function. You can remove the valve by removing the 3mm roll pins above the valve and applying air pressure to pop out the valve. Use heavy glove to catch the valve because it could come out with force (reduce air pressure to gun if possible). If gun works ok examine safety foot mech for problem. Use silicone paste lube on orings. good luck
Jun 12, 2011 | Porter Cable Cable No. FC350A Clipped Head...
I have a Porter Cable finish nailer model FN250B. I have air escaping the exhaust deflector cap all the time and the trigger won't repond. I'm not sure if it's jammed or seals are blow. Can you...
The link below will show a parts list for your gun. Leaks from top are usually caused by debris in the gun. Remove the head and examine parts for cracks or worn orings. Replace parts as needed. If all the parts in the head look ok, clean and apply silicone paste lube to orings and other parts that make contact with orings (silicone paste is sold at Lowes in the plumbing department and at swimming pool supplies stores). Usually, cleaning and lubing with silicone will stop leak. Good luck with your repair.
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/portercable/FN250B
May 28, 2011 | Porter Cable Cable Factory Reconditioned...
Paslode (30 degrees) framing gun firing pin not retracting
The tool needs to be completely torn down, cleaned out, two orings inside need replaced, re-lubed and re-assembled. takes a technician about 1 hour to do it right. I believe either the orings or dirt is your problem. If blade doesn't return its probably the orings.
Feb 10, 2010 | RTO Paslode 902000 IM250 Ii Cordless 16...
When I fire my im250 the firing pin often does not retract fully, so not letting the next nail to progress. I regularly clean and lub the gun and it fires all the time so the problem is not at that end of...
Using a wire "toothbrush" size brush, clean the track in front of the gun where the pin slides - where the nail groove is. **** particles from the nails and the plating from the nails sluffs off fouling the path and causes the pin to stick. After several cleanings of my gun, I noticed that this brushing of the track the firing pin follows keeps it operating for several days without the problem recurring!
Jul 30, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
Feeding nails
Your nailer shares design features with Milwaukee and Ridgid. All three brands experience the same issue. Lets go thru a series of simple tests to determine the problem. First and most simple test, manually load the nails and fire the gun untill miss-fire. Upon mis-fire disconnect air, open latch and check if the driver is all the way up into the cylinder or is partially down blocking next nail. If driver is down blocking next nail, replace the driver oring and retest. If driver is up all the way, remove nails, reconnect airline, leave latch open and fire gun against rubber (old tire or coiled up waterhose/airhose) this time holding the gun down and keeping the trigger depressed. In this position, the driver will remain down and feeder will remain retracted. With feeder retracted and screwdriver in hand carefully check the spring tension on the feeder (should be rather firm tension on spring and the feeder must retract with good force). If no tension or weak, replace feed spring. When you finally release the trigger, the driver will retract and the feeder should return with good force. If feeder does not return with force, replace orings and spring behind feed piston. If all tests are ok, remove head, check lower bumper in gun for cracks or missing pieces. Replace as necessary. Lube all orings with silicone lube available at Lowes in the plumbing department. (Danco brand) Good luck on your repair and email your questions.
May 06, 2009 | Porter Cable Cable RN175AR Reconditioned...
Air escapeing through triger assembly
The problem that you are describing usually occurs when fine scratches in the head allow air pressure to bypass the orings. Here are a couple of simple tests. Remove the trigger from the gun to give access to the trigger valve plunger. Remove the nails from the gun. While pointing the gun away from you, connect the air supply. There should be no air leaks. Now quickly depress the trigger pin all the way in. This must be done with a very rapidly movement. If the gun fires, then the safety foot is not pushing the trigger pin all the way in. Check for worn trigger or safety mech. When the safety foot is depressed against the work, the trigger pin should be depressed all the way into the trigger valve for the gun to fire. Hold the trigger closed tightly and very firmly depress the gun against the work, the gun should fire. If it does not fire try next test. Remove the head from the gun. Hold it in your hand and depress the headvalve all the way into the head with you thumb. While holding the headvalve in, place a finger over the small venthole on the mating surface of the head and release the headvalve. Vacuum should hold the headvalve in the head for a moment until you release the vent hole. If the headvalve springs back with finger over venthole you must remove the headvalve and inspect the surfaces with maginfing lens for fine scratches. Remove scratches with very fine paper to obtain smooth polished surface. Lube surface with silicone lube (looks like vaseline, sold in small container at Lowes plumbing department used for lubing faucet orings ) re-assemble gun and make sure that you tighten headbolts firmly. You should be ready to work. Good Luck!
Jan 01, 2009 | Air Tools & Compressors
Porter Cable Roofing nailer rn175a
Replace the O Rings and the trigger valve assembly. 9/10 sticking rods on the Porter Cable guns is caused by a faulty TVA.
Nov 08, 2007 | Vacuums
Senco 1Y0013N FP35 1 1/4 Inch To 2 1/2 Inch 15 Gauge Finish Nailer Logo
123 people viewed this question
Top Senco Air Tools & Compressors Experts
John Trevino
yoopertech
Trippy Tripp
Are you a Senco Air Tool and Compressor Expert? Answer questions, earn points and help others
