Question about Refrigerators
Frs96zph freezing vegetable drawer
The bottom drawers are freezing. i closed the large return on the bottom with tape, but am afraid the refrigerator is a little warm. Should there be a fan blowing air into the refrigerator?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
So if you closed the "large return" and the drawer is still freezing, but the refrigerator is warm? That almost sounds like an impossibility. Could you provide more details. Do you have a thermometer to take accurate readings in the refrigerator?
Posted on Jan 21, 2013
  • 125 Answers
SOURCE: Admiral Side by Side Fridge is warm at top, cold at bottom
CHECK TO SEE IF THE EVAPORATOR FAN MOTOR IS RUNNING, ITS IN THE BACK OF THE FREEZER SIDE, MOTOR MAY BE BAD OR SOMETHING COULD BE BLOCKING IT...
Posted on Feb 07, 2008
22yooper
  • 828 Answers
SOURCE: Vegetable crisper drawer problem with food freezing
Absolutely lower the setting.
Posted on May 21, 2008
SOURCE: Vegetable and fruit crisper drawers freezing foods
I had the same problem. Apparently the problem is the main control board. According to the technician that came out to fix mine there is a design flaw and these boards are very sensitive and can blow a circuit or malfunction from the slightest power surge. What happens then is that the control board doesn't "tell" the fan to turn on and off at the right time so the fridge and freezer warm up too much before the fan kicks in and then it cools everything down but since the fan isn't running at the correct intervals and circulating the air all of the cold air settles to the bottom which causes the produce in the drawers to freeze while the top shelves get warmer. I had done a fair bit of research before calling GE and came to the conclusion that this was a common problem. So I pressed them and was able to get the fee for the part waived (before I made the service call appointment) which was around $150. The part now has a 5 year waranty which I find funny, because I'm not sure why it wouldn't have that upfront as my refridgerator is only 2 years old. Whatever!! Unfortunately, unless you have indepth knowledge of refridgerator repair there is no way around the service call and labor. Anyone buying a new model of refridgerator (any company) should consider an extended waranty. The service tech also told me that all refridgerators made after 2001 are required, by law, to have an electronic mother board which in all likelyhood will fail at somepoint prior to when you are ready to buy a new fridge!
Good Lucak!
Posted on Feb 11, 2009
Maanita
  • 1142 Answers
SOURCE: fan runs constantly, freezer ice melting, bottom drawer in refrig
  • If your refrigerator temperature is closer to 35 degrees, try turning the temperature up slightly.
  • If you find that the temperature varies a lot from the top shelf to the bottom (where it is coldest), try putting produce and other sensitive products on a higher shelf.
  • If the temperature is too low and you can't make it warmer by adjusting the thermostat, you probably have a defective thermostat. If so, you need to replace it, because they cannot be repaired. Other possible problems are a leak in the sealed (refrigerant) system, cold air migration (in side-by-side models) or a defective air damper. These problems can be quite difficult to locate and correct, we recommend you contact a qualified appliance repair technician.
  • Posted on Mar 24, 2009
    SOURCE: Vegetables freeze in the vegetable drawer. Freezer is on lowest setting.
    Make sure that you realise that 1 degree is colder than 2 degrees and therefore a setting of 3 - 5 degrees might solve your problem
    Posted on Apr 14, 2009
    Fridge freezing everything
    THIS REF. WORKS BEST WITH THE REF. SET ON 4 OR 5 AND THE FREEZER AT 2 1/2 OR 3. HAVING A HIGH FREEZER TEMPATURE CAN HAVE FREEZING IN THE BOTTOM DRAWER OF TH REF. MAINLY BECAUSE OF THE RETURN AIR VENT TO THE FREZER IS BEHIND THAT DRAWER.
    Apr 25, 2010 | Maytag 21.9 Cu. Ft. Bottom-Mount...
    Freezing in left crisper drawer.
    If you have had a DOE upgrade the fix is availiable from LG
    Here is the service buliten # CREF20090877.
    Contact LG @ 1 800 243-0000 for repair.
    In the mean time remove crisper dware and look on the back wall of the ref. you will see a dime sized hole on the center tower. Cover the hole with tape and reinstall crisper.
    Jan 19, 2010 | LG LFX25960 Bottom Freezer French Door...
    Freezing in the bottom draw of my LG Refrigerator
    YES!!!!!!
    Remove the bottom drawer.
    In the back you will see a small dime sized hole.
    The hole allows cold air to circulate around the crisper.
    Plug the hole with tape or anything that will fit the hole.
    Set temps back to say 36 in the ref. and 0 for the freezer.
    This should help.
    Jan 09, 2010 | LG Refrigerators
    LG LRFD25850 French Door Fridge set at 37-40 c keeps freezing produce at back or in large bottom drawer
    Pull the drawers put and cover the cold air vent (small hole at back wall) with tape ...problem solved!
    Jan 08, 2010 | LG LRFD25850 French Door Refrigerator
    Bosch Refrigerator ice forming in vegetable drawer
    Emptied drawers and cleared the drain hole. Drawers were then refilled BUT MADE SURE THAT THEY WERE NOT OVERLOADED
    Jul 28, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
    Apr 14, 2009 | Refrigerators
    You have a defective thermistor and damper control in the fresh food or a bad control board.
    Check the thermistor first.
    Also, adjust the return air damper at the bottom left side of the fresh food sction to warmer.
    Feb 21, 2009 | GE PSS25SGN Side by Side Refrigerator
    Vegetable draw is freezing the vegetables
    if you pull out the vegetable drawer, you will notice a vent on the left side in the back. get some tape ( I use aluminum tape ) and cover the bottom half of the vent, that will help keep your vegetables from freezing. that should solve your problem. Joe
    Dec 12, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
    Amana bottom freezer model #BX21TW purchased in 1996
    this particualr refrig is notorious for this. check your controls ( your freezer control as well set to 4 max) any higher and the refrig is running longer, generating more cold then needed, behind the left hand crisper is a few slots( the fresh air return) by default the coldest spot in refrig, i usuallly would reccomend to my cust not to keep high water or thin walled vegies in there such as carrots cukes tom and lettuce, perfect beer and fresh /frozen defrosting meat to be though, if you ever looked at the newest bottom freezers they've pushed up the drawers and added a deli pantry, running the width of frig
    Feb 27, 2008 | Refrigerators
    Bottom vegetable/fruit drawer freezing fruit
    to the left of the bottom drawer is a veg/meat slide switch.make sure it is all the way on veg.if it is on meat,it opens a small doorway to the freezer and lets the cold air in and will freeze the food in the bottom drawer.in some cases,you will need to remove the drawer and shelf and then take apart the doorway.ball up some putty and jam it it the hole to completely seal it off
    Jan 11, 2008 | Amana ARS2661BS Side by Side Refrigerator
    Refrigerators Logo
    101 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
