Question about Kenwood KDC-215S CD Player
KENWOOD KDC-215S HOW TO SET BALANCE
HOW DO YOU SET BALANCE AND TREBLE
    President:
  • 720 Answers
Step 1:
Press and HOLD the A.ADJ (Audio Adjust) button for 1 sec. to enter audio control mode.
Step 2:
Press either FM (or AM) button to select the mode you wish to adjust. Keep pressing until you find the mode you require (in this case, it will be BL for Balance).
To change the value, press the Down Search or Up Search button to your desired setting. Centre balance is "0", negative number is Left speaker, Positive number is Right speaker.
Step 3:
Repeat Step 2 to select the TREBLE (TRE) mode, then use Down, or Up keys to change the value.
Hope this helps.
Cheers,
Scott
Posted on Feb 02, 2013
  • 3 Answers
SOURCE: Kenwood KDC-MP208 Clock Set
Make sure that the source is set to "Standby" when trying to access the menu. It took me about an hour to figure it out and afterward I felt like a ******.
Posted on Sep 14, 2009
jyackle5
  • 8197 Answers
SOURCE: cant set clock kenwood kdc 2011 s stereo
Here is a manual on how to set the time page 22.
http://inform3.kenwoodusa.com/manuals/KDC3011.pdf
Good Luck
Please Rate FixYa!
Posted on Dec 19, 2008
LVT7857
  • 116 Answers
SOURCE: INSTALLING A CD RECEIVER IN MY CAR
Some decks only give one pair of pre outs. Most 4 channel amps can use just a 2 channel input and feed the other 2 channels by the flip of an input selection switch. I recomend a 4 channel amp if you want to power front and rear speakers and be able to set the gains to blend properly, or you can run all 4 speakers at a 2 ohm stereo on 2 channels and run a sub on the remaining r channels. It just depends on how you want the setup to be nd to how much control you want. Let me know.
Larry T
Winona Lake, IN
http://www.cybersoundsaudio.com/cybersounds/vehiclepics.html
Posted on Jan 28, 2009
smarthome2
  • 1114 Answers
SOURCE: I have a kenwood radio model kdc-135 and can not set clock or sh
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDC-135.pdf Here's the manual link from Kenwood and it's on page 13. Hope this helps
Posted on Nov 18, 2009
iamdefiler
  • 50 Answers
SOURCE: How do you adjust the bass and treble on the
Here is the link to the instruction manual for your head unit.
http://www.kenwoodusa.com/UserFiles/File/UnitedStates/Consumer/Manuals/kdcbt742u.pdf
There are a number of places it mentions adjusting bass and treble levels.
Posted on Jan 10, 2010
KDC-215S battery drain
You could add a switch to control the power going to the head unit. I have seen this done in many different vehicles where the head unit drains the battery, even when supposedly off.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Jul 19, 2010 | Kenwood KDC-215S CD Player
How do you adjust the bass and treble on the Kenwood KDC-BT742U
Jan 07, 2010 | Kenwood KDC-BT742U
How do i adjust the treb/bass?
my initial reply was...On the function button you may need to depress it for 3 seconds to activate base, treble, balance etc But
then I found this, "Rotary Volume Control: The CD receiver uses a 7-way rotary volume control that increases and decreases the volume of the stereo from 0 to 35. The rotary knob also controls other audio settings such as Balance, Fader, Bass, Mid, Treble and preset EQ settings. In addition, the rotary knob allows you to scroll through and select your music tracks when the Music Search function is activated.
Cheers, this should help ya.
Jan 01, 2010 | Kenwood KDC-BT742U
Larry T
Winona Lake, IN
Jan 22, 2009 | Kenwood KDC-215S CD Player
Kdc 215s
its the face plate just need to take out clean with little rubbing alcohol these kinda face plates has a scrolling feature that i donot like very much face plate just needs to adjusted back on sterio mount
May 07, 2008 | Kenwood KDC-215S CD Player
C/d car player
Push the left toggle in. It will go through different preset modes, then it will let you adjust things manually.
I find it helps to keep the Beep function (in the standby menu) on so that you can keep pressing the toggle and know when you're back on volume. It's easy to press by accident.
Jan 16, 2008 | Kenwood KDC-MP205 CD Player
Kenwood cd kdc 215s
Contact a stereo shop. they should be able to get you an adapter that will interface it with the amp.
Sep 13, 2007 | Kenwood KDC-215S CD Player
Kenwood KDC-215S
mechanism out of siychrony.....you need a nearest technical support.
Mar 12, 2007 | Kenwood KDC-215S CD Player
Kenwood KDC-215S CD Player Logo
146 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
