When I try to burn data files to a CD-R disc on my toshiba satellite M1115, it repeatedly tells me to insert a disc, when I have put a brand new disc in. I have used the drive to burn music discs &...
It sounds like you are trying to burn too much data onto the disk. If you want to test this theory, you can burn a small amount of data to a blank CD-R to see if it works. If it does then you do not have a hardware problem. This will be good news.
There are different sizes of CD-R media, 650MB, 700MB and larger sometimes. If you select 700MB and try to burn to a 650MB media disk, the drive will just spit out the blank disk so as not to ruin it for a future burn. Also, if you are going to make a multi-session disk (or you have accidentally selected multi session, then you will automatically waste 22 MB leaving you 650-22 /628 MB, or 700-22 or 668 MB of space to burn your data. Each additional session will also take up 22 MB of space.
There is also a chance that the media you are trying to burn to is not compatible. Some lower end brands do not use enough reflective material for some burners. You can test this theory by trying an alternate brand of media.
