Question about Frigidaire PLCS389EC Stainless Steel Dual Fuel (Electric and Gas) Kitchen Range
F30 code on frigidair electric range
Oven want turn on
2 Suggested Answers
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
Frigidaire gas stove, oven will not work. Shows F30 code
That is an error with the temperature sensor.
Unplug the unit or turn the circuit breaker off for 60 seconds.
Restore the power to the appliance by plugging it back in or turning the circuit breaker back on. If you still have the problem here is a link to order the replacement part and a video how to replace the part which is fairly easy to do.
http://forum.appliancepartspros.com/oven-repair-including-ranges-cooktops/561286-error-f30.html
Dec 10, 2016 | Frigidaire Kitchen Ranges
My frigidaire does not heat consistently. F10 fault goes off if it's on for a couple of hours or if we broil. F10 also goes off after cleaning during cool down. F30 goes off after oven is turned off. ...
Good Morning Irene, thank you for allowing me to assist you!
The F10 and F30 error codes are in regards to an open or failed oven sensor. If the sensor and EOC has been replaced, more than likely a professional would need to inspect the wiring harness between the EOC and sensor.
Best regards!
Oct 28, 2013 | Frigidaire FEF366 Electric Kitchen Range
Frigidaire stove door locked f30 error code
Hi - Typically error code F30 for Frigidaire range indicates an issue with the sensor probe or the wiring harness between sensor probe and EOC. Try resetting the unit and see if the error code will clear. You can either unplug the unit or flip the household circuit breaker off. Wait approximately ten minutes and turn on the range. If issue continues, contact a professional to move forward accurately
Nov 25, 2012 | Frigidaire FES367 Electric Kitchen Range
Cfef 372ec4 Frigidaire f 30 problem
Hi - Typically error code F30 for Frigidaire range indicates an issue with the sensor probe or the wiring harness between sensor probe and EOC. If you have already changed the sensor, I suggest checking the wiring or contacting a professional to move forward accurately. You can try resetting the unit and see if the error code will clear. You can either unplug the unit or flip the household circuit breaker off. Wait approximately ten minutes and turn on the range. If issue continues, once again contact a professional to properly diagnose the unit.
Oct 14, 2012 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
How do i fix an f30 error code on my frigidaire range? it only beeps when i try to turn on my oven... and shows f30
Sorry to read about your problem, I hope this helps you out.
You have a shorted keypad membrane.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire Microwave Ovens
Error code F30 on a frigidaire ples389ecc oven.
THAT CODES MEANS EITHER THE PROBE SENSOR OR THE ELECTRONIC CONTROL IS BAD. UNPLUG. WITH WIRING DIAGRAM AND OHM METER, TEST THE TWO WIRES GOING TO PROBE. IF YOU GET ABOUT 1100 OHMS, YOU HAVE A BAD CONTROL. IF YOU GET 0 OR INFINITY, IT'S THE SENSOR OR THE WIRES BETWEEN THE PROBE AND THE CONTROL
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH IF NEEDED
Dec 26, 2009 | Frigidaire PLEF398AC Electric Kitchen...
What is F30 error?
Range made by Frigidaire, cannot pull up info right now for that F30 code, just the F3 which means something is wrong in the sensor circuit, sensor, wiring harness or the EOC/clock...what does your tech sheet tell us this F30 means??? What was the ohm reading on the old sensor.....if changing this did not solve the problem about down to checking the wiring harness, if it is ok back to the clock causing the problem if the F30 pertains to the sensor circuit failure....
Oct 14, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Our figidaire electronic stove/oven model PLES399ECD, serial number NF62311528, mfg'd 2/2006 has an error code for F30 when any program is selected. The manual does not list F30, what is F30?
Open (F30) or shorted (F31) RTD sensor
probe/ wiring problem. Note: EOC may
initially display an "F10", thinking a
runaway condition exists.
1- Press Cancel key.
2- Check wiring in probe circuit for possible short or open
condition. Check RTD resistance at room temperature
(compare to probe resistance chart). If resistance does not
match the chart, replace the RTD sensor probe. Let the oven
cool down and restart the function.
3- If the problem persists replace the relay board.
Sep 25, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Hi jacksmdmat,
Jul 16, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Kitchen Ranges Logo
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
