Question about Whirlpool Dryers
Can't remove dryer blower wheel
Hi, We're getting a repetitive thwacking noise in our dryer, like a string or something is caught in the blower wheel or outside the drum, plus a burning smell. I pulled off the back and the lint duct. When I say lint duct, I mean the solid metal duct inside the dryer, not the hose outside. I can't figure out how to take the blower wheel off. I least I think it's called a blower wheel; it's a white plastic fan with no nut in the middle, and it won't pull off. There's a sticker on the lint duct that says "To remove blower wheel, hold motor shaft/blower shaft and turn wheel clockwise." Well, I don't even know how to get to the motor shaft/blower shaft.  Help! Thanks!!
  • danielwillem Jan 29, 2009
    How do I take the top off? I unscrewed the two small brackets at the back, but I still couldn't lift the top.
  • 65 Answers
I would start by taking off the top and checking the belt to see if part of it tore and is hitting the inside of the cabinet. I have not found a real good way to get the blowers out without having to break them sometimes. the part of the blower that you have to hold is access through the front behind the motor. problem is when you turn the motor shaft, the wrench strips out on the blower, then you have to break them, but unless you need a new motor, it should not have to come off.
Posted on Jan 27, 2009
Dryer keeps making noise?
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
GOD IS GOOD !!!!
Jan 17, 2016 | Dryers
FISHERPAYKEL DRYER SQUEALS
DRYER MAKES NOISES.
The blower:
The bearings:
Mar 13, 2015 | Dryers
Why is it making noise and smelling like something burning?
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Mar 07, 2015 | EuroTech EDV158 Electric Dryer
The dryer is making a squealing noise when tuning like something needs to be lubricated
DRYER MAKES NOISES.
The blower:
The bearings:
Feb 21, 2015 | Dryers
Asko dryer make a banging noise
GOD IS GOOD !!!!
DRYER MAKES NOISES.
The blower:
The bearings:
Oct 02, 2014 | Asko Dryers
Maytag Dryer vibrating and rattle noise
DRYER MAKES NOISES.
The blower:
The bearings:
GOD IS GOOD !!!!
Aug 17, 2014 | Dryers
Motor making noise
DRYER MAKES NOISES.
The blower:
The bearings:
Apr 15, 2014 | Frigidaire FGQ1442ES Gas Dryer
My husband cleaned the dryer vent with a brush today and now it is so loud and vibrating. It is a Neptune bought in 1999
Some lint found its way back into the dryer and is caught up in the blower wheel,the speed at which these blower wheels turn any trash that gets hung up will cause a vibration and noise.You are probably going to have to remove the front panel and blower wheel cover to get access to the wheel to clean it out properly. Its fairly easy BUT FIRST UNPLUG THE DRYER remove the screws holding the door,pull out on the front panel at the top where it meets the top,then you will see some screws holding brackets securing the top remove these.then remove screws holding front bulkhead.then you will see the blower housing ,while there make sure blower wheel is not loose on the shaft from the recent vibrating Hope this helps......
Sep 16, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Noisy dryer after cleaning lint
There is something caught up in the blower wheel. You will need to disassemble the dryer from the front to be able to get to the blower wheel housing to clear what ever you have jammed there and remove it. Everything is done through the front.
May 31, 2010 | Maytag Dryers
Dryers Logo
759 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
