Question about Maytag MGR5880BDS Gas Kitchen Range
Have Maytag MER5755QAW range, the oven will not heat up, the display was working isn't now, i check both elements and temp sensor, all ok
    Top Expert:
  • Maytag Master
  • 9,472 Answers
The display control will need to be replaced. It may be cheaper to replace the unit since the control is so expensive. Here is a link to the part you need.
Keep me posted!
Posted on Jan 21, 2013
SOURCE: Maytag MER6772 - Oven bake element not working even after replacing it.
To find service information for your Maytag Model go tothis link
http://www.servicematters.com/
When on this site, click on Maytag Historical Service Library.
Then click on Maytag Service Library.
Click on term and conditions
Click on Literatur by Model
Enter Modle number MER 6772
Clck go
You will be able to print or download the service manual for your model
Your problem may be the bake relay on the clock or wiring.
Posted on Feb 09, 2008
  • 338 Answers
SOURCE: Proper Oven Temp
You need to make sure you have voltage coming out of your control board. 120v out of the bake relay. (usually yellow wire) and check wiring in the back of the stove. But first reset the breaker.
Posted on Nov 25, 2008
  • 71 Answers
SOURCE: Oven will not bake, but broil works
the bake ignitor is most likley bad
Posted on Dec 24, 2008
SOURCE: Maytag Gemini Double Oven-bottom temp problem
after power outage clock on oven will not set unless the oven itaelf is on unable to set clock
Posted on Jan 28, 2009
  • 3600 Answers
SOURCE: Maytag Range MER5730AAQ front right burner died
you need to replace the inner connetor to make it work.
Posted on Jun 24, 2009
I have a Maytag Electric Range model MER5755QAW. It was obvious that the heating element was bad, you could see the area where it had blown out. I have replaced the heating element, and the oven will...
Just went thru this with my GE/Hotpoint oven....the oven temp sensor removed from oven should measure about 2K ohms and vary when put in ice water and hot water...if it does then problem is control panel circuit board.My oven's board was listed at $300+ so I bought new range ($500+).
Oct 14, 2013 | Ovens
My Maytag MGR5750ADW oven will take forever to preheat. It does get hot, but the preheat light takes a very long time to go out. Food takes much longer to cook as the oven does not seem to get up to temp.
Hello there and welcome to fixya
When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out. You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results. If the bake element is burned out, replacing it should solve the problem. To determine if the heating element is burned out, watch the part testing video at the bottom of this page. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component. When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly. If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective. Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details. Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat. If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
Aug 10, 2011 | Maytag Ovens
Maytag MER5755QAW Range and the oven will not Heat
You said the broiler element which is the top element is working fine what about the botom element, needto check it, i would say its probally bad, also before you do anything be safe and unplug unit completely before checking
Feb 18, 2010 | Kitchen Ranges
Maytag Oven model MER5755QAS trouble heating up
your bake element could be burned out & the oven is trying to get to temp with the broil element only. see if it is getting warm or if it has a burnt spot on it. if it seems to be ok, you may have a bad oven sensor. the oven sensor should have a reading of at least 1100 ohms. let me know if i can be any further help.
Oct 13, 2009 | Maytag MER5755QAS CleanDesign Electric...
Oven temp maytag MER5770
check your element if thats fine u need to replace your erc and possibnly your oven sensor
Mar 19, 2009 | Maytag MER5770 Electric Kitchen Range
I have a Maytag Electric Range/Oven The Range MODEL#MER5755QAW
best guess is thermostat I believe the broiler does not need the thermo in oven.. it stays on steady hot .. thats why it still works
Mar 12, 2009 | Ovens
My Maytag Electric Range oven part will not heat over 200* ......
Unplug the range.
Open the oven door.
Remove the racks.
Remove the 2 screws holding the bake element to the rear wall of the range.
Carefully pull the element from the access holes in the rear wall.
Remove the wires from the element.
With your meter set for continuity, put one lead on each element end.
If you get a reading it is good.
If it is good. Replace the wires and reinstall the element.
Pull the range out from the wall.
Remove the rear panels.
Plug the range back in.
Set your meter for 220volts or more.
Careful now because you are working with live voltage.
Set the oven for bake.
Put a lead on each element terminal to check voltage.
If you have 220 volts at the element, unplug the range and unplug the temperature sensor.
Set your meter for ohms.
Check the 2 leads on the temp sensor.
If at room temp the sensor is 1050 - 1100 it is OK. If not replace it.
If the temp sensor checks out OK, replace the ERC
Mar 12, 2009 | Maytag MGR5880BDS Gas Kitchen Range
Proper Oven Temp
Nov 25, 2008 | Maytag MER5775Q Electric Kitchen Range
Maytag range shows fault code F14
You have a problem with your oven temp. sensor. Remove it and check it at room temp. It should meter out at 1 to 1.1K ohms. If it doesn't replace it.
Dec 21, 2007 | Kitchen Ranges
Maytag MGR5880BDS Gas Kitchen Range Logo
99 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
