Question about Sole Fitness Sole F63 Treadmill
My Sole F63 will slow down a few seconds after I start it then I get a low speed displayed on my control panel
Our Sole F63 treadmill is not running. It turns on and counts donw, but it only stays on abut 5 seconds before it stops and displays low speed on the control panel. No controls will work once low speed is displayed
    Top Expert:
  • Sole Fitness Master
  • 12,223 Answers
Please LUBE the deck belt+ rollers bearings too. You must do it evey 150 miles apros. This happen because the lack of maintenance schedule.
God bless you
Posted on Jan 22, 2013
3 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: F63 sole treadmill, low speed error when inclined
If the calibration does not pass you may need to check the speed sensoralignment. You must understand the instruction for calibration is under the hood for motor.
1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
2) if the problem persist you must Test the main motor for open, ground 3) the main control board faulty. See the block diagram that I did as person like you that understand that 90% of functions the main motor controller board has effect.
good luck. sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A
Posted on Dec 01, 2011
  • 33 Answers
SOURCE: Our Sole F63 treadmill is
pls make clear , countdown is come or not, if coming means problem with controller
Posted on Feb 19, 2011
Just bought sole f63 runs data press start nothinges e4 is displayed then not happy
If you wish to get some details about treadmill repair and error codes ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
Nov 07, 2016 | Sole Fitness F63 Treadmill
How do I fix a sole F63 treadmill that accelerates to maximum speed after about 30 minutes of use?
usually the motor will be controlled by a triac its a silicon device you apply more volts to a pin to allow more current to flow thru it
between its two other pins
so its used to control the motor speed
its more likely its a problem before the triac
a 'driver' device
i would take the control board out and examine it carefully for any blackened devices
so to rule out this drive chain i would take the board to a service tech like a TV repair guy and ask him to cast his eye over it
i usually get a few beers from people to do this as a bribe
always works for me and you would be surprised
you could take a photo or two as jpg in macro mode of the board
component side and post them and i can cast my eyes over them for free..
Apr 19, 2015 | Sole Fitness F63 Treadmill
My f63 powers up and shows display, programming options, but will not start. is it my control board? Is it worth fixing a 5 yr old treadmill?
Start switch is bad most likely. Remove rear panel on console swap the stop and start switch connections.
Feb 18, 2015 | Sole Fitness F63 Treadmill
Treadmill Elevaton Error
There are a few things you may need to check. You already tried calibration. Next thing I would do is check the sensor wire from the incline to the controller. Make sure its properly plugged into the controller. The controller can also be an issue. If someone was tampering with the unit, the sensor wire could be plugged into the wrong connector as there is another connector that will fit. You may contact me for phone support or sign up for phone support at Treadmill Repair Fitness Equipment Repair Parts Services Fitness...
Mar 24, 2014 | Sole Fitness F63 Treadmill
Slow starting
Run the software calibration for easy diagnostic, and fix it. Go under the HOOD motor follow the steps and proceed.
God bless you
Dec 05, 2013 | Sole Fitness Sole F63 Treadmill
E.CUADRA
Dec 01, 2011 | Sole Fitness F63 Treadmill
Sole Fitness Sole F63 Treadmill Logo
778 people viewed this question
Top Sole Fitness Exercise & Fitness Experts
Art Wilson
Art Wilson
Level 1 Expert
Electro Med Services...
Ross Metcalfe
Ross Metcalfe
Are you a Sole Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
