E5 error toyo aircons
Runs 20+/- minutes then E5 error
  • 3 Answers
SOURCE: I have a Toyo Aircon
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. E3 means low pressure of refrigerant. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck to you!
Posted on Apr 18, 2010
  • 3 Answers
SOURCE: TOYO TA-09CHS aircon problem
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem.
hvac1960
  • 2133 Answers
SOURCE: I have a Carrier Aircon.
E5 Outdoor activation of compressor over heatprotection or motor lock
Please clean the condenser coil. And also check out door fan motor rpm. Rpm may be less due to weak capacitor. Replace it.If motor locked you have to replace new motor only.
If helpful, please write.
Posted on Dec 20, 2010
hvac1960
  • 2133 Answers
SOURCE: I have a Daikin split
Check condenser coil. If dust blocked-clean it.
Check out door fan motor is working. If not replace capacitor or motor.
Check compressor-gradually amps increasing-replace capacitor.
Check for gas pressure. No gas also gives over heat compressor.- Leak test and rectify.
Posted on Jan 16, 2011
hvac1960
  • 2133 Answers
SOURCE: Fairland aircon error code
E-5 Outdoor activation of compressor over heatprotection or motor lock.
Check out door fan motor mechanism locked, replace motor. If less rpm replace capacitor. If condenser coil dusty, clean it. If no gas/short of gas, do leak test and rectify. Thanks.
Posted on Feb 08, 2011
Runs 20 sec stops reads F1E5
Error Code/Message - Oven - F1 Error Code - F1 E5
Control displaying F1 E5:
There may be a problem with the Oven Control, or the associated wiring.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation.
Oct 23, 2015 | KitchenAid KEMS309BSS Combination...
Comperasor running e5 problem
Change capacitor motor and outdur working almost
But 3 minute working ok
After E5 error show display screen on indur with outdour fan stop but compressor sound
Apr 23, 2015 | Haier HSU18VC7-G Mini Split Wall A/C Unit
A error code E154 appears, then I shut down the unit, and restart, no problem a few minutes, then the error code appears again. have you the solution?
Hello there, I guess your Running capacitor is leaking already, when you start your aircon it will run after a minute the aircon will stop with errors, because the fan is stop running due to busted capacitor. thanks
Apr 25, 2011 | Heating & Cooling
Mitsubishi aircon has e5 come up. whats the problem
e5- Remote control transmission error. Check wire correctly. Touch one of each of thevoltmeter probes to the terminals marked "R" and "C," tocheck for 24 volts of alternating current (24 VAC). If you do not get a voltagereading of 24 VAC, then the thermostat is not getting power. Reset the circuitbreaker, or check for a blown fuse, and replace if need. Use the voltmeter torecheck for 24 VAC between the terminals. If the thermostat still lacks power,check and reset any tripped condensate float switches. Check the power switchon the HVAC equipment and set to the "On" position, if necessary.Replace any broken wires and tighten any loose wire connections to restorepower to the thermostat.Wait five minutes and allow the system to respond.Thanks.
Jan 31, 2011 | Heating & Cooling
I have a Daikin split system ducted aircon. temp on 22degrees.turns off error code flashes E5, and a picture of a spanner
Jan 16, 2011 | Heating & Cooling
I have a Carrier Aircon. Model 42QH12-C and it is displaying error code 5. The aircon stays on for a while (anywhere between 10-60mins) and then turns off and displays E5. If I just press the 'on/off'...
Dec 20, 2010 | Carrier 38CKC042 Air Conditioner
IDEC aircon E5 error what does it mean?
i am air con tech and i face all ready this problem may be it will help u . e5 error is ur air con not have gas becoze of that the low presser switch give error on disply thanks best regard for all. pls let now if its help full
May 27, 2010 | LG LSC183VMA Split System Air Conditioner
I have a Toyo Aircon TA 12C(H)S air conditioner that shows E3 on the readout and nothing will come on. Any ideas what the error codes mean?
Jul 03, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Jun 09, 2009 | Toyotomi TIN/TIG-329D Air Conditioner
Toyo Aircon. Starts perfectly. Runs for approx 5 min and then the yellow "timer" light starts flashing and machine stops working. Green power light on...yellow timer light flashing. When you switch unit...
TOYO mini split air conditioner made in Japan is very very good quality and it can runs for 20 years without any problem. You didn't hire a best ac technician to install your TOYO unit. The tubing connection between indoor unit and outdoor unit is not the right torque and refrigerant leak. Your TOYO unit runs out of refrigerant. You need fix the leak and fully charge the system. You will solve the problem. Good luck!
Dec 28, 2008 | Toyotomi TIN/TIG-329D Air Conditioner
Heating & Cooling Logo
112 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
