Question about Directed Electronics 1100f Ford Pats Securilock Data Remote Start Interface Module
Tried using the remote start I hear it tring but no success opens doors
    Genius:
  • 1,003 Answers
Sounds like you have a bad relay
Posted on Jan 22, 2013
Door stuck closed
The door has the child safety on possibly try opening from outside with a little leverage if not successful remove door panel to unlatch from inside with a small screwdriver on the latchy
Jul 22, 2014 | 2002 Jaguar X-Type
Programming keyless entry to 95 landcruiser
1. Start with key out of ignition, drivers door is open all others closed and
drivers door is unlocked.
2. Insert key into the ignition (Do NOT Turn) and Pull key out.
3. Perform these steps within 40 seconds.
A. Using the power lock switch on the drivers door, perform 5 lock/unlock cycles
starting with lock. Use an even pace and try to go about one cycle per second.
(1Cycle = 1 lock and 1 unlock).
B. Close, then open drivers door.
4. Perform these steps within 40 seconds.
B. Insert the key in the ignition cylinder.
C. Turn the ignition to ON (Do NOT Start) then back to OFF.
D. Remove the key from the ignition.
5. Within 3 seconds the power door locks should cycle automatically indicating successful
entry into programming mode. Return to step 1 if the locks do not cycle at this point.
6. Perform these steps within 40 seconds.
A. Press the lock and unlock buttons on the remote simultaneously for 1 second.
B. Immediately after letting go of the lock and unlock buttons, press the lock button by
itself and hold for 2 seconds. Within 3 seconds, the door locks should cycle once
indicating successful programming. If the door locks do not cycle, or cycle twice.
repeat steps A and B in step 6 as your remote has not been accepted.
C. Repeat steps A and B in step 6 for each new remote.
7. Close drivers door.
Oct 29, 2013 | 2008 Toyota Land Cruiser
Pontiac keyless fob
This worked for me...
Once the keyless entry receiver enters the programming/diagnostic mode, the programming of the first transmitter erases all previous transmitter programming information. You must then program all of the transmitters.
Program only 1 vehicle remote control door lock receiver at a time. If you program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Perform the following steps:
Sit in the vehicle driver's seat.
Remove the ignition key from the ignition lock cylinder.
Close all of the vehicle's doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body and Chassis.
Turn the ignition lock cylinder to the ACC position.
Turn the ignition lock cylinder OFF, then back to ACC within 1 second.
Open and then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If you do not hear a chime, start again at step 1.
Important
After 7 seconds, you may hear a chime confirming successful synchronization. After approximately 14 seconds, you will hear a chime confirming successful programming.
Press and hold the transmitter LOCK and UNLOCK buttons simultaneously for 14 seconds.
Repeat step 8 in order to program each additional transmitter.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body and Chassis.
Validate that all the transmitters that were programmed operate properly. Refer to Keyless Entry System Operation .
Sep 02, 2013 | Keyless Entry Remote Fob Clicker for 2003 ...
Replaced the battery in my keyless entry fob and now it does not work. What do I do?
HAS TO BE REPROGRAMED
Sit in the vehicle driver's seat. (actually it's much ezr from the front pass seat)
Important
Aug 05, 2011 | 2007 Pontiac Grand Prix GXP Sedan
Alreaddy did replace new batteries for key remote but the key remote is not working properly.. What cause is that?? do you know??
I know that this procedure work for Grand Prix and Monte Carlo, tesi it...
KEY FOB PROGRAMMING INSTRUCTIONS
Transmitter Programming
No Tools Required
In the event that a transmitter is lost, program the old and the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Sit in the vehicle driver's seat. (actually it’s much ezr from the front pass seat)
Important
Hope helps.
Jul 16, 2010 | 2001 Pontiac Grand Am SE
Cars sercuity light flashes on dash while tring to start and will not start
theres something wrong with the anti theft either in the key or the switch or if this is key less the remote
May 14, 2010 | 2004 Jaguar S Type
I have a problem with opening car doors with remote for 1997 pontiac sunfire. I noticed that when you are in the car and you activate the open and close switch from drivers side the locks at the rear open...
Try this procedure...
No Tools Required
In the event that a transmitter is lost, program the old & the new transmitters into the memory of the remote control door lock receiver. Up to 4 transmitters may be programmed.
Important
Program only 1 vehicle remote control door lock receiver at a time. If u program multiple receivers simultaneously, the same transmitter could possibly be programmed to more than 1 remote control door lock receiver.
Sit in the vehicle driver is seat. (actually it’s much ezr from the front pass seat)
Close all of the vehicle is doors.
Remove the MALL PGM fuse from the fuse panel. Refer to Electronic Diagnosis in Body & Chassis.
Open & then close any vehicle door. You will hear a chime when the remote control door lock receiver enters the programming/diagnostic mode. If u do not hear a chime, start again at step 1.
Important
Press & hold the transmitter LOCK & UNLOCK buttons simultaneously for 14 seconds.
Install the MALL PGM fuse back into the fuse panel. Refer to Electrical Diagnosis in Body & Chassis.
Hope this help (remember comment and rated this).
Apr 16, 2010 | 1997 Pontiac Sunfire
Can't program keyless entry remote.
Try this,
No Tools Required
Important
Important
Good luck and hope this helps.
Jun 23, 2009 | 1995 Cadillac DeVille
Directed Electronics 1100f Ford Pats Securilock Data Remote Start Interface Module Logo
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Mark Skinner
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
