Question about Gateway Computers & Internet
WHAT ARE THE SPECIFICATIONS
LlOOKING FOR SPECIFICATIONS AND HOW MUCH MEMORY IT CAN HOLD AND HOW TO UPGRADE IT
  • Gateway Master
  • 27,725 Answers
Each computer contains two important components---a Central Processing Unit (CPU) and memory chips. The CPU and memory chips work together to process computations within your computer. You can't have one without the other. Your computer has a base amount of memory installed, 512 Megabytes or higher, that can be expanded to beyond 1 Gigabyte, in most cases. Before you upgrade your computer's memory, you need to know what type of RAM your computer takes: SDRAM (Synchronous DRAM), Rambus DRAM (RDRAM), DDR (Double Data Rate SDRAM) or other type.
Open your computer's Internet browser by clicking on the program's icon on your computer's "Desktop," this applies to both Windows and Mac platforms. Enter www.crucial.com/systemscanner/index.aspx in the URL box at the top of your browser's screen. The "Crucial System Scanner" tool application website will open. Click on the check box next to the wording "By selecting this box and clicking the download the scanner button, I agree to the Terms and Conditions." Click on "Download the Scanner." The "Opening CrucialScan.exe" dialog box will open. Click "Open" or "Run" to download and set up the program directly. Click "Save" or "Save As" to save the program's setup file on your computer if you don't see the "Open" or "Run" option or you are using dial-up or a slow Internet connection. The program will download and setup on your computer if you selected the "Open" or "Run" option. Navigate to the directory where you want to save the file, if you selected the "Save" or "Save As" option. Select the "Desktop" if you have a hard time locating downloaded files on your system. Double click on the "CrucialScan.exe" icon to open the program, if you selected the "Save" or "Save As" option. Click "Run" when prompted with the "Open File -- Security Warning." The "CrucialScan.exe" program will run and appear in your computer's Internet browser. Scroll to the second section on the "Memory upgrades from Crucial.com -- Determine My Memory Needs" website. The section is labeled "Your XXXXX Specifications." The "XXXXX"s represent your computer's brand and model. Locate the wording "Each memory slot can hold..." Write down the this sentence on a piece of paper---this is the type of RAM your computer accepts. Click "File," "Print," "OK" to print this website, if you have a printer attached to your computer. If you're not sure if a module is right for your system, use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always ask for a guarantee on the compatibility before making any purchase and try to buy for working pairs if possible Hope this helps.
Posted on Jan 22, 2013
  • 1 more comment
  • rachel81rene
    rachel81rene Jan 22, 2013
    It has one of these in a slot
    KINGSTON
    ValueMemory Category: Desktop
    Memory Type: DDR2
    Memory Speed: PC2-4200 / 533MHz
    ECC: No
    ECC Registered: No
    Total Memory Size: 1
    Memory Channels: Single
    Memory Socket: DIMM
    Pins: 240
    Voltage: 1.8
    And 2 OF THESE IN 2SLOTS NEXT TO THE ONE ABOVE  I BELIEVE THEY ARE HP or samsung 512MB 1Rx8 PC2
  • rachel81rene
    I want to be able to play games from internet like WOW and was wondering if there is a way to upgrad motherboard. ..I think its an old INTEL
  • Brian Sullivan
    Brian Sullivan Jan 22, 2013
    Did you run the crucial memory adviser to see how much ram your computer can handle ? rather than spending money on a new motherboard check the crucial ram adviser tool
I need owners manual
According to your question you need an owner's manual for a car or a truck. Be more specific and provide model and year of your vehicle. Also you can do a google search for your manual llooking for terms Manual, Model and Year.
Jun 25, 2015 | Cars & Trucks
Cannot upgrade memory on my Gateway MX3215
Use Corsair Value Select VS1GSDS533D2.
Aug 17, 2009 | Gateway MX3215 Notebook
C-4765 code on km252 and solution?
Can be memory (DIMM) on MFPB, or the MFPB card itself.
Llook if you have two Ram board (behind the copier, 4 screws or more to remove, then you will be able to see the Memory on the MFPB card ... try to switch the memroy, and retry duplex copies... if same problem, try to change the memories. if the problem occurs again, change MFPB card.
Mar 06, 2014 | Konica Minolta bizhub C250 All-In-One...
How to upgrade RAM for compaq nx9010
Upgrading memory helps improve system performance. By following the step-by-step instructions in this document, you can successfully upgrade random-access memory (RAM) for all HP and Compaq notebook computers. While the graphics might not match your specific computer model, the steps will work. Read all instructions carefully before attempting memory installation. NOTE:Do not purchase memory modules until you know the type of memory used by the computer, the maximum amount of memory the computer can use, and the memory slot configuration. How to find the product number of your HP notebook PC To order replacement internal components such as memory, you must know the exact product number of the computer. For many HP notebook PCs, the product number and serial number are printed on a label on the bottom of the computer. Also, the product number and serial number are printed on the outside of the shipping box that you received when you purchased the computer. Product number locations can vary, and there are numerous methods to find the product number of your notebook. NOTE:A general family name may be imprinted on the case near the keyboard or on the frame around the display screen, but this does NOT provide sufficient information for ordering replacement parts. Finding memory information for your computer model (amount installed, maximum supported, and type of memory) Important memory upgrade information is in the specifications document for your HP computer. To find product specifications, browse to the Product Information category on the support page for your computer model. Refer to the Memory section within the product specifications document for memory information specific to your computer. Among the information listed, take note of the following items. It will be useful when purchasing memory and when performing the next steps. Amount of memory installed - The current amount of memory installed on your computer. Go to Verifying how much memory can be added to verify the amount of memory currently installed. Maximum memory supported - Subtract the amount of memory already installed from the maximum amount supported by the system to determine how much memory to get. You can also buy the maximum amount allowed and replace the currently installed memory. Once you know the maximum for your system, check Maximum memory supported by operating system to see how much memory your version of Windows will support. Use the lower of these two numbers as your maximum memory. Type of memory (including speed) - It is recommended to get the same type of memory (same size, same speed, same manufacturer) for each slot. For best performance, get the fastest memory that the motherboard supports. CAUTION: Due to the variety of possible configurations, some motherboards might not be able to properly configure memory if the array of small outline dual in-line memory modules (SO-DIMMs) contains a SO-DIMM that is not from the same manufacturer, has a different CAS latency value, or has a different density value (high and low used together). Make sure all SO-DIMMs meet the requirements of for the motherboard (the information listed in product specifications), have the same part number, are from the same manufacturer, and meet the basic memory requirements for your motherboard. If not, make sure that you can return the memory if it is not recognized by the system after you install the new memory. Determining where your memory is located Memory is installed inside of the memory module compartment, which is located on the bottom of the computer on most HP notebook PCs. Some HP notebooks are designed with the memory module compartment under the keyboard. If the memory module compartment for your particular notebook is located under the keyboard, HP recommends that you contact an HP-authorized support or repair facility for assistance in ordering and replacing the memory. Verifying how much memory can be added Prior to upgrading memory, you need to verify how much memory you currently have installed to determine how much memory can be added. Using your User Guide for memory installation instructions The User Guide contains helpful information and pictures showing how to remove and install memory in your specific notebook model. A copy of the User Guide is stored on the hard drive, and it is also available for download from the HP Web site. Installing memory Notebooks are designed so that additional memory can be added using a Phillips screwdriver. Use the following steps to install memory in an HP or Compaq notebook computer. After reviewing the following steps, if you are not confident in performing the installation yourself, contact an HP authorized distributor for technical assistance. NOTE: If someone other than HP installs or upgrades the memory, any damage caused by the memory and/or by a person trying to install or upgrade the memory is excluded from coverage under the product warranty. The customer assumes all risk and liability for damages for any such installation or upgrade. NOTE: Important! You might find that your HP or Compaq computer is able to support a physical installation of 4 GB or more memory. However, this maximum memory might be further limited by the operating system not being able to address the full range of physical memory. 32-bit operating systems, such as 32-bit types of Windows 7, Vista, and XP, can address approximately 3.3 GB. This limitation is present on all 32-bit hardware and 32-bit operating systems and is not limited to HP and Compaq PC systems or Microsoft software operating systems. Verify the computer is turned off, not simply in sleep or hibernate mode. Disconnect the A/C power adapter. Turn the notebook over and place it on a firm surface. Remove the battery. Use a Phillips screwdriver to remove the cover on the memory module compartment. (See the User Guide for instructions on how to remove the memory for the specific computer. If you need help finding the User Guide, refer to the section Locating your User Guide for memory installation instructions .) With the cover removed, and before you touch the memory, ground yourself to discharge any static electricity. NOTE: To ground yourself, and discharge any static electricity, place one hand on the case of the computer and touch the other hand to a metal surface or grounded object, such as the metal part of a lamp. To release the memory, use a small wooden tool, or fingernail, to spread the clips holding the ends of the memory in place. One side of the memory will rise when the clips are released. Remove the memory and place it in an anti-static bag. Remove the new memory from the protective anti-static bag and hold the memory by the ends. Place the gold contacts into the connector (bracket) and gently, but firmly, press the memory into place. The clips will click when the memory is properly seated. Replace the cover and tighten the restraining screw. Replace the battery and A/C power. Turn on the computer and allow it to reconfigure and recognize the additional memory and improve performance. Buying memory HP recommends purchasing memory directly from HP, an authorized HP dealer, or from a reputable computer parts supplier. You can buy computer memory from most local electronic stores and online shopping sites (such as www.crucial.com or HP , for example). Many of the online sites partner with HP to automatically suggest the correct type of memory based on the model of your computer. Before purchasing memory, make sure you know how much memory you need and what type of memory is compatible with your computer.
Aug 05, 2012 | HP Compaq Business Notebook NX9010
Whats my sdram capacity
HP Pavilion 9694C memory upgrade specification, Pavilion 9694C maximum memory, memory speed, and memory upgrade options. Upgrade memory on HP Pavilion 9694C upto a maximum of 256 MB
PC100/133 SDRAM DIMMs, with maximum 128MB per slot in 2 memory slots. The HP Pavilion 9694C takes the PC100/133 SDRAM DIMMs Memory Type.
Hope that helps.
Feb 16, 2011 | HP Pavilion 9694C PC Desktop
Can I upgrade the ram on the acer aspire 5630 notebook?
Yes, you can.
You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Nov 25, 2010 | Acer Aspire 5630 Notebook
The bios won't recoginze the memory upgrade? How
maybe the memory upgrade is not supported by the system.
  • check the specification of the computer first and verify if it can support the memory you put into your computer.
  • remove the new memory and put back the old memory, (try if it works now)
  • if it works with the old memory, then definitely, the problem is with the new memory. make sure that the memory is compatible with the system and it supports the capacity of the new memory you have in it.
Mar 22, 2010 | Sony VAIO PCG-K23 Notebook
Can the memory be upgraded (increased) from the basic (factory installed) 512mb on the Sony PCV-W300G?
Hi there.
As far as i know you can upgrade the RAM to 2GB, 2x1GB 184pin PC2100 DDR DIMM Desktop RAM modules is what it can take.
Thanks for choosing FixYa!!
May 28, 2009 | Sony VAIO PCV-W300G PC Desktop
Gateway wont take new ram???
Was the memory made for that specific model? I know that on Toshiba laptops sometimes you have to buy the memory that was specifically designed for that model. You can always try a website like kingston. They may make the memory specific to your laptop mode. If you would like more help please feel free to reply.
Mar 20, 2009 | Gateway MX3225 Notebook
System upgrading
Hello!
I think your memory specs is DDR 400 nonECC.
Maximum-is 2GIG
please refer to this site for more info. http://www.memoryx.net/p4vm800m7.html
may this help, melnavz
Mar 17, 2008 | Mercury P4VM800M7 Motherboard
Computers & Internet Logo
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
