Question about Chrysler Dodge ram 150/250/350 frame assembly. 131 w.b. up to jan. 6, 1986
86 dodge d250 wont start but will turn over
I have an 86 dodge d250 that will turn over but wont start. The distributor is good on it. Need it back to running quick HELP!!!!! Please!!!!
    New Friend:
  • 60 Answers
Is it in time, getting fuel, getting fire, check fuel filter, check cap an rotor, plug wires, spark plugs, make sure it has gas in it, I know your not dumb just giving ideas, on that model engie it has to be in time, have a battery, gas, and spark to run so that is where you are! Wish you luck!
Posted on Jan 21, 2013
The pickup has no spark was going down the road and it just stopped running
Search Results
    "No start" Due to Pickup Coil Failure Inside Distributor ...
    repairpal.com > Problems > Toyota > Camry
    The pickup coil inside the distributor can fail and cause a no-start condition. ... checking reveals not only no spark at the plug, but also no spark going into distributor. ... the car runs great but only for about 10 miles. then it shuts down as if there is no ... The plugs have a weak spark when checked against the engine block.
    Car dies randomly, It turns over but no spark - 1989-1994 ...
    https://www.ifixit.com/.../Car+dies+randomly,+It+turns+over+but+n...
    iFixitf your engine cranks normally but will not start because it has no spark, or it stalls ... A bad pickup inside the distributor (on engines that have a distributor), a stripped ... Really old post but could you please tell me how I would go about checking if my ... When it all got down to it, one of the timing belt idlers had worn out and ...
    Dodge Ram 1500 Questions - 1994 dodge 5.9 just shut off ...
    www.cargurus.com > Questions > Dodge > Ram 1500
    CarGurusApr 12, 2012 - 1994 dodge 5.9 just shut off and wont start back up there is no spark or ... hall effect (magnetic pickup) in the distributor? ... So I ran power back to the wire and repaired the broken wire and she fired right up and is running darn good again. ... Ihave a 2000 dodge ram 1500 it died going down the road it is ...
    No Spark - 4.3L S10 Pickup - CarGurus
Dec 14, 2015 | Cars & Trucks
86 dodge daytona wont start
The main logic module / computer is located in the passenger side kick panel under the dash. If I remember correctly that is the computer that controls the engine ignition. This could be your culprit.
Mar 24, 2014 | Dodge Daytona Cars & Trucks
1997 Dodge Distributor diagram
if it still runs loosen distributor bolt but dont take out start engine turn just little to get into time and if wont start pull distributor up rotate tooth the rotor should face number one piston
Nov 09, 2013 | 2000 Dodge Ram 1500 Truck
98 dodge ram wont start but cranks fine
I havr a dodge ram 99 gas start good run good the problem is when i stay in a light w s itin the truck turn off only in gear
Mar 09, 2013 | 1998 Dodge Ram
Have a 1993 dodge d250 wont turn over
theres a couple test to narrow it down. first thing to do is make sure the battery and all connections are good and firm. next crossover the terminals on your starter cylinoid. if nothing happens then either your cylinoid is shot or the starter is seized, if its starts or turns over then you need to replace your ignition (you can also remove the start and bench test it yourslef by apply jumper cables directly to the terminals, or take it in to a napa and have them test it)
Feb 12, 2012 | Dodge Ram 250 Cars & Trucks
The van wont start. Changed coil, changed distributor cap, got new battery, put gas in carburetor but still wont fire up!?! Please help!!
We had this same problem with the 1992 Dodge Ram D250 pickup truck we own. We wasted a lot of money until my Uncle's mechanic (he owns a small auto shop) fixed the problem. There was some kind of oil pump shaft that needed replaced. Sorry I am not very smart with vehicles, but I do remember that it has something to do with the distributor and oil pump working together. The teeth on this particular part were chewed up so the distributor was not firing correctly. The part was replaced and the truck has started and ran just fine ever since. I wish I could remember what the part is called!!! But I just know it was a part that looked like a pipe kind of; it was straight and had some teeth like things at one end...
Dec 14, 2010 | 1992 Dodge Ram 250
86 dodge 250 v8-318 no fire at spark plug, will not start
did you change the main coil and coil wire?if so then check the ing resistor and then the computor box
Mar 20, 2009 | 1989 Dodge D150
2000 dodge durango wont cranks but wont start...
had same problems with cranking and wouldnt start , i had no spark not sure if you do but if not after performing tune up and still had no luck , i changed my camshaft position sensor under distributor and rotor , and she started right up . good luck
Mar 15, 2009 | 2000 Dodge Durango
Ignition key wont turn
Make sure car is in park then try moving ignition switch back towards you and then forward as if trying to start it. That seemed to work for our 86 Dodge 600 auto.
Feb 28, 2009 | 1984 Dodge 600
1998 dodge neon turns over but wont start
Cars need three things to start. Fuel, Air, and Spark. Chances are it's either missing fuel or spark. If you smell fuel when you turn the engine over the that means you dont have any spark. If this is the case check the distributor to see if it is functioning. If you don't smeel gas then it's probably not getting fuel. In this case, start of By checking all of your fuses to see if any are blown. Mainly the fuel pump fuse and relay. These are the cheapest to start with. If your fuses are good and relay is funtioning then check the fuel pump itself. Hope this helps you and good luck.
Dec 20, 2008 | 1998 Dodge Neon
Chrysler Dodge ram 150/250/350 frame assembly. 131 w.b. up to jan. 6, 1986 Logo
119 people viewed this question
Top Chrysler Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Chrysler Cycling Expert? Answer questions, earn points and help others
