Question about Cybex Remanufactured Cyclone 530c Upright Bike
How do I run a diagnostics test on the Cybex Cyclone 530c upright bike?
Just spoke to a repair man, He recommended that I run the test before he comes out and I am not actually sure how this is done.
Trying to connect my new Cybex 77c upright bike to internet do I just plug the Ethernet cable to my modem
sure thing.
the modem should give the bike a number
like this one 192.168.0.110 'example'
Jan 03, 2018 | Internet Computers & Internet
Feels like pedals slip once in a while. How do I repair this please?
replace the spring, maybe it has lost some of the loading and become "tired".
Jul 03, 2015 | Cybex Cyclone 530c Upright Exercise Bike...
Tire replacement
No, go by the original recommended size for your bike. Now that being said - if you want to modify your bike and run a wider tire on your bike I personally can say the 180/55 is a good choice. I am running one on my M2 cyclone. Less expensive and easier to find tires for.
Aug 15, 2013 | 2002 Buell Thunderbolt S3T
Cybex 530t treadmill speed slows down intermittently anyone help
Please LUBE deck belt + rollers bearing too
2) test the input voltage motor, if there are the motor need repair.
3) test the output voltage board, for input voltage motor, if there are NOT the board is faulty.
God bless you
Dec 17, 2012 | Cybex 530T Pro Plus Treadmill
Trek spokes sze
I could not find the spoke size online so you should probably take a wheel to the bike shop and ask them. They should not charge you for that. Unless you REALLY know what you are doing, I do NOT recommend you tampering with the wheels of you bike. The wheels are one of the most delicate parts of a bike particularly the spokes. If you dont feel compterable altering your wheels, have the bike shop take care of it. It is easier to pay a little more for labor up front than to try it yourself, mess up and have to replace more parts than originally needed plus labor.
For wheel advice use...
http://www.parktool.com/blog/repair-help/categories/wheel-and-rim-service
Jul 13, 2011 | Trek 7.1 FX
I have a Cybex 700C upright exercise bike--it is an alternator powered unit. The display is dead. I have the bike apart, and everything looks fine inside, so I wonder if the most likely suspect is the 6V...
I would start by checking the voltage of the battery, before just replacing it. I will attach a link to a video on how to do this and also a link to the possible battery if this turns out to be the issue.
Video about How to Test Battery
Parts for Cybex Equipment Treadmill Belts Grips Pedals SPORTSMITH net
Oct 30, 2010 | Cycling
How do you clean the Dyson dco7 cyclone top
Hi its Darran at Dyson.
We would not recommend that you take the cyclone top apart. This part is designed to be a sealed unit and taking it apart may affect ther performance of your machine ongoing.
If you are concerned with the performance of your machine, please follow the blockage procedure and filter washing instructions on our website in the support section at www.dyson.com or check your user guide.
If you do want to clear dust and debris from the cyclone, we recommend that you simply hold the cyclone top over a bin and bang the sides gently to remove any dust from the inside.
Kind regards
Darran
Dyson Customer Service
Mar 16, 2010 | Dyson DC07 All Floors Bagless Upright...
Suction on the hose is
HI THERE.
THE PROBLEM COULD EITHER BE THE BELT HAS SNAPPED AND IN WHICH CASE IT WOULD BE EASIER TO CHANGE THE CLUTCH AS THERE ARE 2 BELTS ON THE CLUTCH. OR THE CLEAR RUBBER HOSE BEHIND THE FOORPLATE COULD BE SPLIT OR THERE COULD BE A BLOCKAGE AT THE TOP OF THE CYCLONE CYLINDER.
REGARDS
DAZ
Dec 08, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
2000 cyclone broke
Itt sounds like you might have a short in you system thats frying you bike. Make sure that none of the wires are exposed or coming in contact with the frame.
Nov 10, 2008 | 2001 Buell M2 Cyclone
Cybex Remanufactured Cyclone 530c Upright Bike Logo
59 people viewed this question
Top Cybex Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ray gallant
Techmotionusa.com
Techmotionusa.com
Are you a Cybex Exercise and Fitnes Expert? Answer questions, earn points and help others
