Question about NEC D720101GJ PCI Controller Card
4 port usb 2.0 pci card sh94v-0 - NEC D720101GJ PCI Controller Card
Is the hp a1330n usb 3.0 compatible? Mine doesn't even have the "pci-e" mini slots for plugging in a usb 3.0 card. Is my only option is replacing the motherboard with one that has pci-e slots?
- You can use PCIe x16 slot (if using onboard graphics adapter) and PCIe/USB 3.0 card (data transfer rates up to 5 Gbit/s, i.e. 10x faster than USB 2.0).
- Or use PCI/USB 3.0 card (for legacy PCI slots to support the USB 3.0 standard), which allows data transfer rates up to 1.3 Gbit/s (3x faster than USB 2.0).
2 Port PCI SuperSpeed USB 3 0 Card Adapter
May 31, 2015 | HP Computers & Internet
My wifi will not use my wifi router after upgrading ubuntu to ver 11.10 it worked before and i can use different wifi routers lspci 00:00.0 Host bridge: ATI Technologies Inc RS690 Host Bridge 00:01.0 PCI...
first make sure your wireless adapter is not disabled you can check it by running rfkill list in terminal if it is type sudo rfkill unblock wifi [second you can try activating and deactivating by typing sudo ifdown wlan0 and sudo ifup wlan0 me personly have kept to 10.10 the 11.04 seem to have a few glitches you can also check for additional drivers
Nov 27, 2011 | Canonical Ltd. Ubuntu
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
What type of video card can I use on this motherboard? D945GZIS AGP? PCI? PCI EXPRESS?
Your MoBo has (1) of each PCI Express x1 & and PCI Express x16 slots, and (2) standard PCI slots. There are NO AGP bus slots on this board. You'd want to use buy a PCI Express x16 video card instead of a PCI video card due to the better performance offered by the PCI Express cards.
The full details of your motherboard are below:
Product Description The Intel Desktop Board D946GZIS delivers an integrated graphics solution in the Essential Series by combining exceptional value with quality and reliability and supports Intel Core2 Duo, Intel Pentium D, Intel Pentium 4, and Intel Celeron D processors with 1066/800/533 MHz system bus in the LGA775 package. This board features a PCI Express x16 connector, integrated 10/100 LAN, dual-channel DDR2 memory, Intel High Definition Audio (Intel HD Audio) and up to eight USB 2.0 ports.
Processor Model: D946GZIS Chipset Type: Intel 946GZ Express Processor Socket: LGA775 Socket Installed Qty (Max Supported): 0 ( 1 ) BIOS Type: Intel Storage Controler: ATA-100
Memory RAM Installed ( Max ): 0 MB / 4 GB (max) Supported RAM Speed: PC2-4300, PC2-5300 RAM Features: Unbuffered, dual channel memory architecture
Audio Audio Output: Sound card Sound Output Mode: 5.1 channel surround Compliant Standards: High Definition Audio
Expansion / Connectivity Expansion Slot(s): 1 PCI Express x1, 1 PCI Express x16, 1 processor - LGA775 Socket, 2 PCI, 2 memory ( 1.8 V ) - DIMM 240-pin Interfaces: 4 x Hi-Speed USB - 4 pin USB Type A, 1 x serial - RS-232 - 9 pin D-Sub (DB-9), 1 x parallel - IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25), 1 x display / video - VGA - 15 pin HD D-Sub (HD-15), 1 x network - Ethernet 10Base-T/100Base-TX - RJ-45, 1 x audio - line-in - mini-phone stereo 3.5 mm, 1 x audio - line-out - mini-phone stereo 3.5 mm, 1 x microphone - input - mini-phone 3.5 mm, 1 x storage - floppy interface - 34 pin IDC, 1 x keyboard - generic - 6 pin mini-DIN (PS/2 style), 1 x mouse - generic - 6 pin mini-DIN (PS/2 style)
Nov 03, 2010 | Intel D915GAV Motherboard
Can a Windows 95 have a usb port installed
Yes.
Load the required driver from Microsoft but it will not be USB 2 only USB 1.
Oct 16, 2010 | Computers & Internet
Nrrd usb controlers for dell optiplex 260
You need a PCI USB port, these are redily available, from my favorite place eBay.. There are a few "Models" they all have multiple ports and sometimes even have a firewire port ot two as well.
See the link below to get the idea. http://cgi.ebay.com/5-Port-USB-2-0-High-Speed-PCI-Controller-Card-Hub-480MB_W0QQitemZ350320565691QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item5190bb9dbb#ht_2578wt_1165
Feb 24, 2010 | Dell OptiPlex GX260 PC Desktop
How to install a sd card reader on a Dell Dimension 8200 PC Desktop? no 4 pin usb on motherboard?
I managed to install a card reader on my Dell Dimension 8200.
The main problem is that the Dell motherboard does not have the correct USB pin. This is a 9-pin MoBo USB header.
The quick answer is I installed a USB card with an internal port.
http://www.amazon.co.uk/Unbranded-USB-2-0-PCI-Card/dp/B00066LPA2/ref=sr_1_6?ie=UTF8&s=electronics&qid=1264968643&sr=1-6
Secondly I reverse mounted a powered 4-port USB hub in the spare 3.5" bay.
http://www.cablecity.co.uk/product_info.php?products_id=1149&ref=6
Third, I purchased 2 USB 5 pin male to usb leads...
http://www.amazon.co.uk/v2-0-Male-Motherboard-Header-Connector/dp/B000QC7NKM/ref=cm_cr_pr_pb_t
You cannot buy a USB card with 2 internals and do away with the 4 port powered USB hub because the card reader does need to be connected to a powered USB port.
for more info see this...
http://www.mods-n-clocks.co.uk/?p=181
Jan 23, 2010 | Dell Dimension 8200 PC Desktop
I have an old hard drive tower. I bought a printer today and the UBS cable is not compatible. How can I get the right cable?
Check the back of the printer, is there a another connector or only the usb?
if the printer has only usb, you would need to buy a usb card for your old tower
You would need to look inside your tower and check if you have a white PCI slot available
heres what it will look like
And heres a USB - PCI card that will fit into the white slot giving you the USB connectors needed for the printer and everything else
http://cgi.ebay.com/Internal-PCI-USB-2-0-Controller-Card-5-Ports-4-1-VIA_W0QQitemZ400008832746QQihZ027QQcategoryZ90718QQtcZphotoQQcmdZViewItemQQ_trksidZp1742.m153.l1262
Nov 15, 2008 | Computers & Internet
UPGRADING USB 1.1 TO USB 2
I searched and found a 1/2 height PCI card with 2 USB ports, plus a internal connector for two more ports. My little NetVista will not hold a full-height PCI card. Get out your tin snips.
Works like a charm !
FYI: I disabled the BIOS USB support for the old ports, and plugged the old MB cable into the new PCI card. I now have two 2.0 ports on the front, and two 2.0 ports on the back. However, I lost the ability to boot from USB
Aug 31, 2008 | IBM NetVista X41 PC Desktop
NEC D720101GJ PCI Controller Card Logo
173 people viewed this question
Top NEC Computers & Internet Experts
Steven Wander
Steven Wander
Martin Murray
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
