Question about Dell Dimension 4300 PC Desktop
How much can my system take??
I have a 1.7 Intel Pentium Dell Dimension 4300 from about 2001/2....... I currently have only 40GB hard drive and I need more.
Does anyone know what type I should get and how big my system will take? I dont want to get a 320GB when it might only hold 160 or something.........
ITs a 40GB ATA-100 7200 RPM currently......
    President:
  • 948 Answers
You can put as large a hard drive in there as you like. If the bios does not recognize the entire thing you can format and partition it using the HD manufacturer's software.
Posted on Jan 27, 2009
Dell optiplex GX270 reconnect disk drive D:
if you have two partitions on your hard disk drive that means that D partition is dead! If you have two separeted hard disk drives C and D check the flat and power cables, check the jumpers on hard disks, switch the possitions of the jumpers on drive D to SLAVE position!
Oct 06, 2012 | Dell Optiplex GX270 Desktop Computer -...
I dont have audio device pls let me know what will i do to my dell dimension series 8250 . thanks
Dell Dimension 8250 Drivers
Visit the above link from Dell Official Support. Click Audio, download the files and install.
CreativeTECH
Jan 17, 2011 | Dell OptiPlex GX280 Desktop PC - Intel...
Where is the sound card located in a dell dimension 1100?
The sound is integrated onto the motherboard in this model, it isn't a separate card.
Jan 01, 2011 | Dell Dimension 1100 PC Desktop
I have a dimension 2400. the current processor is a pentium 4 2.2 can i swap the processor with a intel core duo ??
After checking the specs of this here : http://support.dell.com/support/edocs/systems/dim2400/en/sm_en/specs.htm
i can confirm that a intel core duo would not be supported without changing the motherboard, and probably the memory too.
Rytech Computer Services Limited
Oct 12, 2010 | Dell Dimension 2400 PC Desktop
Error loading operating system
You will need to perform a repair install using a Windows CD. The current configuration on the hard drive was basically with an entirely different computer and thus, it does not know how to "talk" to the new hardware. The repair install should fix that and create a new Hardware Abstraction Layer (HAL) that will enable Windows to "talk" to the new hardware.
Mar 18, 2010 | Famous Brand Dell Optiplex GX280 Intel...
Im trying to upgrade my hard drive from a 40g to a 160 but it only shows up as 40gb
You probably used software to "clone" the "old" disk-drive to the "new" disk-drive. So, the "new" drive is an *EXACT* image of the 40GB drive.
Click Start
Point to My Computer
Click with the SECOND (usually the RIGHT) mouse-button.
Click Manage
Double-click Storage
Double-click Disk Management (local)
You'll see that the "last" 120GB on the new disk are "unallocated".
Use that "disk-cloning" software to "resize" the 40GB partition on the new disk-drive, to integrate that "unallocated" space into the current partition.
Or, right-mouse click on that "unallocated" space, and create a partition within that space, and to "format" that space, and to assign a drive-letter (E: ? F: ?) to that 120GB of disk-space.
Nov 11, 2009 | Dell Dimension 3000® Pentium® 4...
I need to replace the dead hard drive in my dell dimension 4500s. Current dead drive is a 40GB Ultra ATA-100 (7200 RPM). Can someone tell me what I can upgrade to. I think I have the flat data cable so it...
You can replace the hard drive with a larger capacity hard drive. Best bet would be a 250GB .
Hard drive have come down in prices, you should be able to get a 250 GB. for less then $100.
Western Digital ansd Seagate are my preference.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | Dell Dimension 4500 PC Desktop
Have maxtor 40gb hd want to add 2nd WD hd in DEll dim8200
(if both drives on the same cable):
Your boot drive goes at the end of the primary data cable.
Your second drive goes on the middle connection of the same cable.
The red stripe on the data cable needs to be closest to the power connection (red stripe to pin 1).
The jumper on the boot drive set to master.
The jumper on the second drive set to slave.
Look in the BIOS to make sure it sees both harddrives.
Boot the system.. it will need to be partitioned and formatted if not already..
Regards..
Apr 04, 2009 | Dell Dimension PC Desktop
DELL OptiPlex GX150 Upgrading
The fastest processor you can install in a GX150 is a Pentium III 1.13 Ghz processor.
The Socket 370 was a design used only for P3 processors.
Max RAM for that system is 512MB no way to upgrade past that.
If you paid $100 for a GX150, you paid way too much (You can buy a refurbished Dell Dimension C521 for $225 at their refurb site)
Jan 26, 2009 | Dell OptiPlex GX150 PC Desktop
Vista Ultimate
need at least 2 gig of ram and 160 gig hard drive to run vista
May 29, 2008 | Microsoft Windows Vista Ultimate Edition
Dell Dimension 4300 PC Desktop Logo
73 people viewed this question
Alun Cox
