49.2fc8 service error on laserjet 5500dn - Office Equipment & Supplies
3 Suggested Answers
  • 21 Answers
SOURCE: Standard Output Full
Empty the standard out put. It will only hold so many sheets before it stops. If the output tray is empty, there is a sensor that needs to be cleaned or replaced.
Posted on May 26, 2009
seeker5211
  • 1089 Answers
SOURCE: I have a HP color
Get into MENUS, go to DIAGNOSTICS, PQ TROUBLESHOOTING. Check the cyan.
Clean the contacts on the cyan cartridge, replace the cyan cartridge, Replace the High Voltage Board. The laser scanner for that color may have to be replaced. The DC Controller could be bad.
Also, under DIAGNOSTICS there is a "Disable Cartridge Test".
That test will allow you to remove all the cartridges and swap them around(in other words, put the cyan in the black slot and the yellow in the magenta slot) and print. So why don't you run that test and swap the cyan and the black. Print and see if the problem follows the cyan cartridge. If it does, replace it. If the problem stays with the original slot for the cyan, then the stuff mentioned in the first paragraph comes into play and you may need a tech to look at it and replace parts.
Good luck
Posted on Apr 01, 2011
Standard output full message
no pic, but, it sounds as though an exit sensor is failing or sticking; this is where the paper exits the printer.
Dec 23, 2012 | HP LaserJet 5500DN Printer
51.2K Printer Error (LaserJet HP5500dn)
this error broken down just means that the laser head that writes to your Black toner cartridge is faulty and needs to be replaced, if you pull the black toner out youll see a small long **** on the back wall and thats where you'll find the laser. you'll have to remove the cover in back and some other items to get at it. If your not mechanically inclined, better get a tech...
decent priced lasers for this model Click here
Sep 13, 2011 | HP LaserJet 5500DN Printer
What is the solution to this error that displayed on the screen of my hp5550 laserjet printer that unable to store job at printer
Hi:
Check to make sure your storage buffers is not full, or memory for the printer is not full of older documents you may of not deleted. Most printers in its menu will give you the amount of mem left in the sytem, check the Menu on the printer and look for memory usage.
Nov 10, 2010 | HP LaserJet 5500DN Printer
81.0180 EIO 1 error code on a hp laserjet 5500 dn
The printer has encountered a problem with an EIO card device in slot 1. Power off, remove the device from the slot and power on. If it comes up ready then refit the card and try again. if it still fails with the error recommend replacing the EIO device in that slot
Oct 07, 2009 | HP LaserJet 5500DN Printer
May 15, 2009 | HP LaserJet 5500DN Printer
HP laserjet 5500dn paper jam at fuser
I was able to fix my problem. On the left side of the fuser assembly there are two small plastic tabs or flags that move up & down. One is attached to the plastic rod/flap that you can see from the top of the fuser and moves when the paper comes out of the "chute". The other tab, which is below the first tab and moves when the paper has passed some point in the fuser, was broken off. I glued the tab back on and now the paper is ejected from the printer like it is suppose to.
I'm thinking that the broken tab was part of a page sensor flag that would tell the printer to stop rolling the fuser assembly when the paper was ejected. Without the flag, the sensor would disengage the fuser prematurely and stop ejecting the paper while the paper was still in the fuser.
Charlotte
Apr 17, 2009 | HP LaserJet 5500DN Printer
Hp printer 5500n
the magenta laser scanner is defective and needs replaced.
Jun 02, 2008 | HP LaserJet 5500DN Printer
HP Laserjet 5500dn-Background Colour setting
I take it that machine was fine before you changed cart.
Sounds like you have got a faulty cart, if HP then it is under warranty so return for credit.
but I suspect you have a aftermarket/refill cart that is causing you greif, return it and use genuine HP ones.
Nov 02, 2007 | HP LaserJet 5500DN Printer
56 people viewed this question
k24674
