Question about GE GFSS6KKYSS (259 cu ft) Bottom Freezer Commercial French Door Refrigerator
Water under the deil/produce drawer inside GE bottom-freezer refrigerator
WATER UNDER DELI DRAWER
3 Suggested Answers
  • 219 Answers
SOURCE: ge profile water/ice fridge side under bottom drawer
take out the back panel in frzzer side use a steamer to clean out your drain hole
Posted on Mar 19, 2009
woodchuck789
  • 4070 Answers
SOURCE: GE Profile side by side...water collects under the
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Oct 27, 2009
GE Water Dispenser not working
Sounds like the water tank in the fridge section froze and split open causing a leak. Plus, the water feed line to the dispenser has frozen where it runs up through the freezer door- guessing your trimmer line only goes about 5" into the tube?
There is a water line heater kit that GE makes : Refrigerator Heating Element WR49X10173 .
Then, buy two quick disconnects 5/16" and about 10 feet of 5/16" plastic tubing- use the tubing and disconnects to replace the cracked water tank and you should be good to go... Refrigerator Water Line 5210JA3004K
Jul 03, 2016 | GE Refrigerators
Water is freezing in the bottom drawer GEProfile bottom drawer freezer and leaking water on floor
Sounds like your drain tube is blocked in the freezer for the defrost water. The drain tube is in the back left or right corner and will have a drain trough under the cooling coils tilting towards it. That trough will probably have ice built up all over it. Once the ice is out you may need to force hot water down the drain tube. I use to use a turkey baster with a rubber hose on it to force the hot water down the drain tube. Its clear when you put water in the trough top and it goes down the tube freely to the drain pan under the refrigerator.
Feb 28, 2015 | GE Profile PDS22MHR Bottom Freezer...
Frigidaire French door model 28 cubic ft - deli drawer freezes cold cuts and cheeses. Model FGHN2866PF1
Hello friend, thanks for your inquiry!
I understand that you have a Frigidaire refrigerator, FGHN2866PF1, and your deli drawer is freezing items. You may want to turn down the temperature within your deli drawer, when adjusting the temperature could take 24 hours for your refrigerator to stabilize. If that does not resolve your issue I would suggest removing the drawer and checking over to make sure there are no cracks where too much air may be coming in. If there is too much weight in the deli drawer that could cause the drawer to sag, which may release cold air into the deli drawer. I hope this information has been helpfu. -Matt
Oct 10, 2014 | Frigidaire Refrigerators
Leaking water into bottom of fridge and freezing under deli drawer
Check the water lines. There should be a replaceable water filter in the interior of the fridge. Possibly the top portion, behind a panel.
Sep 03, 2014 | Refrigerators
Water collecting inside fridge, under meat drawer
Yes most responses are the freezer drain even if it is in the bottom freezer. If the drain is blocked water will build up anywhere inside your refrigerator only because it has no place to go during the defrost. Defective door seals can also can make the problem much worse. See Leaking Refrigerators I am here should you need me, Thanks John Tripp Appliance 911
Apr 21, 2014 | GE Profile 22.2 Cu. Ft. Side-by-Side...
Ice under the deli drawer
it could be that u have a leak.. sometimes this happens when to much water is delivered to the ice tray and it overflows a little leaking into fridge. if that is happening then u most likely have a problem with the water inlet valve at the back of fridge, u can buy the part on line at appliancepros.com. good luck
Apr 13, 2014 | GE Refrigerators
Water under samsung refrigerator deli drawer
You posted this question in FixYa's cellular phone area. You'll fare much better if you repost this question in the refrigerator area. Include the model number of your Samsung refrigerator if you know it.
Dec 20, 2012 | Cell Phones
Deli drawer freezing food
The temperature in the section or the refrigerator isn't set correctly.
Also, check the thermostats if it is functioning correctly. PLEZE LET ME KNOW.
Sep 17, 2012 | KitchenAid Refrigerators
GE GFSS6KKYSS (259 cu ft) Bottom Freezer Commercial French Door Refrigerator Logo
455 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
