Question about Car Audio & Video
2004 jeep libirty has two dead slots in fuse box one goes to my ignition what could be the problem
    Scholar:
  • 116 Answers
Try looking under your hood (unless that's the fuse box you are talking about) There are "fusable links" that protect the inside fuse box.
Hope that helps.
Posted on Jan 28, 2009
Is there a blower motor fuse on the inside fuse box
2004, blower. dash hvac blower
good question
easy answer , the FSM book covers this. best
got the climate control option? we cant guess that. and is key to the answer.
WJ jeep, just before the big change to WK.
on link below , click WJ
then wiring Air-conditioning
then go to page. 8w-42 page 1
JB fuse 29
pdc 1
(jb is cab) pdc is enging bay box.
http://www.morris4x4center.com/knowledge-base/index.htm?utm_source=cj#service
blower dead on high?
Dec 20, 2015 | 2004 Jeep Grand Cherokee
Fuse for radio 1993 jeep Cherokee
anthony he ask for radio fuse.... fuel dont run radios.
the fuse is marked RAD.
did you check all boxes?
fuse boxes ?
the operators guide lists it.
the full book is here
read page 200 pdf
read that yet?
under RAD and wiring?
XJ jeep. 93 is first good year.
radio dead or just back lamps in it dead. why must i guess?????
ill pretend the RAD is dead. totally.
fuse 2 is RAD 15amps.
in the book, 1min to find. it.
4.0L engines???? guess that?
pdf page 200 and 142 (4LITER)
radios have 3 power feeds
illum
radio power
memory
ill guess, rad power is dead. runs Cig lighter too... it dead?
ITS MARKED .
Jul 04, 2014 | 1993 Jeep Grand Cherokee
None of the Eletrical works on jeep 2004
old post
all electrics dead.
that is a dead battery.
surely head lights work they do , key in pocket.
fix head lights first (path) starting with a voltmeter at the battery
12.6vdc is charged, if ok , check the fuses in the engine bay fuse box called the PDC.
Feb 15, 2014 | 2004 Jeep Grand Cherokee
2004 JEEP LIBERTY. BATTERY GOOD. THE CAR WILL NOT TURN OVER. IT SOUNDS LIKE IT IS COMMING FROM FUSE BOX UNDER HOOD
I assume you are hearing a starter Relay/solenoid chattering. That's usually caused by:
A dead battery.
A loose connection on Battery or start relay/solenoid.
Bad connection at starter or bad starter.
Good Luck
Jun 29, 2011 | 2004 Jeep Liberty
2004 Nissan Xterra. Battery died and now the radio will not turn
Hi, check the fuse box for a blown fuse in the radio slot. sometimes during jumps, this fuse will blow.
Mar 06, 2009 | 2004 Nissan XTerra
Fuse Box
Does the wire have a connector on it? if not, look for a connector plugged into fuse box that has no wire on it and likely evidence that there had been a wire there. If you are not the first owner, there is a possibility that someone pulled that wire to "cure" a problem. Make sure that a new problem does not arise after you re-connect it>
Feb 24, 2009 | 2004 Jeep Grand Cherokee
2000 Jeep Gr. Cherokee 4WD 4.7L under dash fuse diagram
Do you have the owners manual, so spots are left open on purpose.
Oct 14, 2008 | 2000 Jeep Grand Cherokee
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
