Question about Miele S558 Red Velvet Bagged Canister Vacuum
How do I install a new power hose on a miele - Miele S558 Red Velvet Bagged Canister Vacuum
My Miele S 558 hose keeps powering down while vacuuming. I understand that the newer SES 125-3 hoses are supposed to correct the problem. Before I buy, I'm wondering if this has proven to be true.
Debra, Searched the net. and the problem does seam to be poor/faulty circuit board in the hose and the SES 125-3 replacement hose is to be the fix. You could dissassemble first and clean the contacts first, to see if you can correct and extend the life of old hose. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
just bought Miele s558 Silver Moon seems like it from 2000 or so If it in...
My Miele S5980 is cutting out How do repair the hose to fix it
Amazon com Miele SES125 Vacuum Cleaner Deluxe Electric Hose Miele Vaccum...
Jul 08, 2016 | Miele Vacuums
Hose has split
VacuumSpot are miele agents for Australia and New Zealand if you need any Miele parts in this area you can hit us up on the contact us page and we will get you anything you might be after
Feb 12, 2013 | Miele Vacuums
My miele has no suction and i changed the bags
99% of the time you can fix this problem with a new filter i have put the link in for the filter for your vacuum cleaner if you have changed the filter in the last 3 months then you might have a blocked hose check the hose first then get yourself a new filter
Miele filter for s514
Jun 04, 2012 | Miele S514 Solaris Bagged Canister Vacuum
Power Problem
Hi There,
Unfortunately this is being caused by static electricity building up in the electronic controls in the handle of the hose. I've seen this problem on numerious occasions, and in fact I have the twin brother of the Blue Moon, or the Silver Moon which used the same hose, and has the same problems in my own home.
The good news is that Miele has redesigned the hoses to fix this, and I have never seen a single problem on the newer style hoses. I guess the bad news is that the hose is not cheap.
I would recommend to you to go ahead and purchase the new hose. The average life expectancy of your Miele is 20-25 years, so you still have a lot of life left in your vacuum.
Here's a link to the SES125 Hose that fits your Miele Blue Moon on our website:
http://www.govacuum.com/miele-165.html
To change the hoses out, simply push the two tabs on the end of the hose that plugs into the vacuum, and pull the hose backwards until it disconnects. You'll see on the end of the new hose electrical connectors. Simply line these up with the opposity receptacles on the canister and push the hose down until you hear a snapping noise.
I really hope that this information was helpful to you. If you have any follow up questions, or would like a clarification, please use the comment box on this page.
If this was able to help you fix your machine, please be so kind and rate my repair or leave me feedback. This is really appreciated.
Thanks again,
Chris Jones
GoVacuum.com
Jun 15, 2010 | Miele Blue Moon Bagged Canister Vacuum
I just bought a Miele s558 Silver Moon, seems like it's from 2000 or so. If it's in good condition, can I expect this machine to last another ten years? Or would it have been better to buy a lower end...
Greetings from GoVacuum,
Ahh, the Miele Silver Moon model S558i. This is great model that I know a lot about because I actually own this exact model. I have had my Silver Moon now for going on 10 years, with almost no problems. The motors in the Silver Moons are excellent, and should last 20 or 25 years without problems. This particular model did have one major problem however. This is the first model that Miele put the suction controls in the handle of the hose of the vacuum, allowing the user to easily adjust the suction setting with fingertip controls. The problem with these models is that static electricity (usually happens when vacuum carpeting) causes the hose to shut down the power to off. You can be in the middle of vacuuming, and all of a sudden the vacuum will turn off. You can easily turn back on the vacuum with the push of a button, but it's irratating for sure.
Miele did come up with a solution for this problem with a newly redesigned hose, part number SES125-3. Since this new design has come out I haven't had a single issue with my hose. The way you can tell if you have the old or new hose is by the numbers (or lack of ) on the different suction levels. If your hose goes up to 1100 Watts, then this is the older style hose. If you're hose simply has a minimum to high setting with no numbers at all on the hose, then this is the redesigned 125-3 hose.
If you have the older style hose, I would get the dealer that sold you the vacuum to exchange the old hose for the new hose, you definitely don't want to have to buy that new hose ($150+). If you have the new hose, then I would say stick with the Silver Moon over the newer Miele models, in my opinion the Silver Moon is one of the most durable models that Miele has ever made.
The only other thing you need to be careful of is the cord reel. When you are retracting the cord reel, it's best to kind of guide the cord back in, and take it slow rather then just stepping on the cord rewind pedal. The cord reel can sometimes be touchy, especially if you are rough with it. If you're careful with it, you should never have any problem with the vacuum cleaner as long as you change the filters on a regular basis as well as the bags.
I hope this helps, if you have any further questions, please feel free to contact me at chris (dot) jones (at) govacuum (dot) com.
Thank you,
Chris Jones
GoVacuum.com
Mar 18, 2010 | Miele s558 Silver Moon Vacuum
Will stop running for no apparent reason. The light stays on and you can amp up the power to restart, but the problem is persistent. The book says to change the filters, which has been done.
This problem is caused by the static electricity which causes the hose controls to jump back down to the off setting. I have seen this issue on several Silver Moon and Blue Moon models before.
The only way to fix this problem is to purchase a brand new, redesigned hose. The new hose can be purchased here; Miele Electric Hose Miele Part # SES 125 .
In fact, I'm so sure that this new hose will fix the problem to your Miele, that if you do purchase the hose from GoVacuum, we'll give you a 60 day satisfaction money back guarantee. If this hose doesn't fix your problem, you may return it to GoVacuum within 60 days for a full 100% refund, no restocking fees or shipping charges will be deducted. We'll even include a free return label you can use to return the hose to us at our expense!
If you have any questions, please feel free to send me an email, or request a clarification. I hope this helped you. If you found this solution helpful, please remember to rate this solution as helpful by clicking on the four THUMBS UP icons in the top right hand corner of this solution.
Thanks so much,
Chris Jones
GoVacuum.com
Jul 12, 2009 | Miele s558 Silver Moon Vacuum
Blue Moon S658 Miele vacuum problem where suction cuts off. The power light stays on. Sometimes I lose full suction, and other times I just lose partial suction. This shows on the handle by going from...
This is a problem with the circuit board in the SES-125 hose. If you replace the hose, this problem will stop. Unfortunately this is the only solution to this problem.
-R
Mar 05, 2009 | Miele Blue Moon Bagged Canister Vacuum
My Miele cat & dog
Will it power up without the hose attached? If it does then you have a clogged hose. If not, there is a circuit board by the motor that may be bad.
Mar 22, 2008 | Miele CatAndDog700 Bagged Canister Vacuum
Miele S326i Vaccuum cleaner hose broke
any miele warranty center can help you with ordering a new part, look on line for close center. Or try main office.
Mar 13, 2008 | Vacuums
New Miele Red Star - Powerbrush not working
Wish you had listed the model number of the vac and of the powerhead. The plug going into the cannister, is it pushed all of the way in, also same for the plug going into the hose end? You can hook up the powerhead plug to a/c and see if it runs, if it does, then it is ok. Unhook the hose and plug and hook up a/c to that plug end and see if the powerhead will run, if not maybe the switch on the hose handle has a problem. Otherwise you have a problem in the cannister. If this is brand new, then it has a warranty, take in for repair.
Feb 21, 2008 | Miele Red Star Bagged Canister Vacuum
Miele S558 Red Velvet Bagged Canister Vacuum Logo
29 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
