Question about Brother CS6000i Computerized Sewing Machine
Error code 6 - Brother CS6000i Computerized Sewing Machine
My 6 head 15 needle baurden machine keep error message D1 then D3 I moved the needle bar but it won't move any more only to the right/ won't budge yo left. any suggestions I can. Help do
Check the troubleshooting section of the manual. Usually, there is a list of error codes and what they represent. May give you some information of what is amiss. Sometimes you can search the internet, input:
"Make" "Model" error code D1 or D3
Nov 20, 2016 | Sewing Machines
My Dreammaker VE 2200 is giving me message FO2 s/s sw on after needle broke. It will not do anything.
HAve a look through the manual (180 pages), it has a section (appendix) on troubleshooting. The manual is actually titled BP2100 but in the small print it also says VE2200 I hope it'sthe right one
Download manual
You could also try here Support Center for manuals and more personal support.
6.November.2015
Nov 06, 2015 | Brother Sewing Machines
How do i get sewing machine to stop showing code 6 when I have done everything by the book. sews perfect stitches for about an inch then code 6 and locks again?.
Since it is a computer,maybe try unplugging for about a minute and plug back in and turn the machine on. See if the code is cleared. hope this helps
Oct 02, 2014 | Brother Sewing Machines
What is a 6d2 error code On my 6 head embroidery machine
EACH MACHINE HAS DIFFERENT CODES. THE MACHINE TYPE NEEDS TO BE GIVEN IN ORDER TO LOCATE THIS CODE AND WHAT IT MEANS. FOR NOW, COMPLETELY REMOVE THE POWER CORD FOR 10 SECONDS AND PLUG IT BACK IN. I HOPE THIS WILL WORK.
Jun 16, 2014 | Sewing Machines
Singer error codes 6
You are getting a thread breakage error. I'm presuming that you are getting repeated error 06 codes to write in. Before I start, though, you also get that error code if your bobbin is out of thread. The thread sensor thinks your thread has broken because your thread is not seated at all, or not seated enough, between your tension disks, which are on the right side of your tension dial. Take the cover off the thread path (page 52 in your user's manual), lower your presser foot, and turn the tension dial to zero. Use UNWAXED dental floss, and floss between those disks. Chances are there is loose threads and/or lint between the disks, preventing the thread from seating properly. When threading, make sure that your presser foot is UP (tension disks are spread to accept thread), and apply tension to your thread, both at the top and bottom, to make sure your thread gets between those disks. Thread it a few times with the cover off, if necessary; you don't need to have it on to embroider, although you can't use your needle threader with it off.
Mar 05, 2014 | Singer Futura XL-400 Quartet 4-in-1 Sewing...
My machine give error E-6
hi there
error E-6 means your control box is older than machine model DDL-8700/7. please tell me your control box model and i can help.
best regards
ASHRAF
CAIRO - EGYPT
aabozid@hotmail.com
Jan 08, 2014 | Juki DDL-8700
How do I fix the error on a babylock emp6 "trimming sensor error?
I have found that this error most commonly is a result of a lot of thread caught in the cutting blades preventing the cutting blade from moving. See the "Cleaning around the Needle Plate" in the User Guide or "Cleaning of Knives and Rotary Hook" on page 316 (or 6-6) in the Service Manual located at http://www.brodyrmaskiner.se/service/pr620/pr-620-service.pdf.
Oct 07, 2010 | Baby Lock Sewing Machines
Brother CS6000i Computerized Sewing Machine Logo
75 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
