Brake won't spin
  • mglenhart Jan 21, 2013
    sorry, first time doing this and hit the wrong button at the wrong time I also asked under spin brake with a comment that explains things further, thanks Leigh Perlmutter for looking and trying to help
  • Leigh Perlmutter
    Leigh Perlmutter Jan 22, 2013
    My pleasure..
    Genius:
  • Washing Mach... Master
  • 1,669 Answers
That is useless information for anyone to help you! How about the type of machine, the make and the model number to start and then what actually happened!
Posted on Jan 21, 2013
For the Honda CRV 2004, the driver's side automatic window does not go up or down but all other ones do. Please advise.
Your emergency brake is a mechanical brake system that is indipendant of the regular hydrolic system. If the red brake light on the dash is on make sure it's the emerg. brake and not a problem with the fluid level or the calapers sticking. the best way to check the emerg. brake is to rase both rear wheels off the ground and spin them. If they spin, the emerg. brake is not locked up. If they don't spin, take the rear tires off and the brake drums. (you may have rear disk brakes.) check the springs to insure they are all hooked up properly. If there is no problem there, follow the parking brake cable to check for damage. The cable is like a brake cable on a bike, If the inner cable is binding inside the cable sleeve,the brake wont release. If you have rear disc, it's probly a bad calaper.The park brake cable is attached to the calapers. Rember if it wont run it's annoying but if it won't stop, it's deadly. DON"T experiment with brakes!!! If in doubt, take it to a pro.
Oct 12, 2012 | 2004 Honda CR-V
The machine doesn't spin properly and doesn't drain the water
see this causes and fix it. God bless you
Lid Switch Assembly If the washer won't spin the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Motor Coupling If the washer won't spin the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and transmission. Another common problem is the lid switch.
Drive Belt If the washer won't spin, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin properly.
Door Lock Motor and Switch Assembly If the washer spin the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
Drive Block If the washer won't spin the drive block might be worn out or may have come loose. Underneath the agitator the drive block connects the inner tub (the one that spins around) to the transmission. If the drive block wears out the transmission shaft will still spin but the tub may not - or it may spin slowly. This also usually causes a lot of noise. The drive block is relatively easy to replace.
Clutch Assembly If the washer won't spin, the clutch assembly might be worn out. The clutch assembly makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. The clutch is not repairable, if it is loud or not working properly it will need to be replaced.
Clutch Band kit If the washer won't spin, the clutch band kit might be worn out. The clutch makes the connection between the transmission and the inner tub. It is designed to allow the tub to get up to the proper spin speed gradually. As the clutch wears out it may prevent the tub from spinning. If the washer won't spin, this clutch band kit may need to be replaced.
Drive Motor If the washer won't spin the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged It will have to be replaced.
Tub Bearing If the washer won't spin the tub bearing might have seized. This is a common problem and relatively easy to replace.
Tub Seal and Bearing Kit If the washer won't spin the tub seal and bearing might have seized. This is a common problem and relatively easy to replace.
Bearing If the washer won't spin the bearing might have seized. This is not common. The bearing doesn't require any normal maintenance. They generally go bad when the tub seal fails and allows water to leak past into the bearing.
Basket Drive If the washer won't spin the basket drive clutch might be worn out. The basket drive sits on top of the transmission and engages with the inner tub. If the basket drive wears out the tub won't spin.
Basket Drive Hub Kit If the washer won't spin the basket drive hub might be worn out. The hub is a set of plastic gears underneath the agitator. The basket drive hub kit is easy to replace with standard hand tools.
Transmission If the washer won't spin the transmission might be worn out or defective. There are numerous more likely causes when a washer won't spin, which should be checked first.
Sep 28, 2012 | Hotpoint Washing Machines
Truck has electrical power but won't turn over. I think I can hear the starter solenoid engaging. Not sure. where do I start trouble shooting?
Safety first!--Make sure you're in park & brake on-- Try shorting across the starter terminals with a screwdriver,if the bendix kicks in & nothing spins,remove the starter & put in bench vice ,(or hold down securely), & jump with cables.--REMEMBER POLARITY--If the starter spins you are in deep *******---something in the motor is probably locked up.(If the starter doesn't spin get a new one.)
Sep 24, 2011 | 2007 Nissan Xterra Off Road
My Kenmore washing machine, model number 26812690, won't agitate or spin. It goes through all the cycles but the tub doesn't move
if its a direct drive , make sure the brake is releasing for starters, If the spin basket has difficulty getting up to speed, you have a slipping clutch. You can determine this by slightly holding the spin basket when you select spin.A rapid spin up to speed shows a "good" clutch. other things to check for are a broken coupler, or any item trapped between the drum and housing, ( which is what happens most the time, )
Jul 09, 2011 | Kenmore Washing Machines
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE
WASHER FILLS WITH WATER, THEN WON'T AGITATE. TURN KNOB TO SPIN AND IT DRAINS THEN SPINS. STILL WON'T AGITATE please show me a diagram
Jun 14, 2011 | Whirlpool LSR7333 Top Load Washer
Washer will spin but won't agitate and it "puts the brakes on" when finished spinning
Hello, Thank You for using FixYa. I will be helping you today.This unit spins in one direction for spin and the other for agitate. If its not agitating and the motor is running then the trans failed. Some of these have a ten year trans and labor warranty. Go to maytag site and put in your model and serial and check the warranty.And the brakes on this unit are pretty quick to stop.
Thank You and please rate my answer if it was helpful..
Jun 11, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
