Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Red Covergance Issue
I have a sony KP-51WS510 projection tv and the red is off. I think it may be the coverganc part #874901908 but can not locate it on my set. I am reluctant to spend another 400 plus dollars on a 5 year old tv. My knowledge is enough to be dagerous but figure what could it hurt to try. Thanks
  • kofia Jan 31, 2009
    I do have a similar problem. Please cc me on any information you get
  • Sony Master
  • 3,459 Answers
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
One or more colors can't be adjusted when using the convergence menu.
Screen is bowed in or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence or magic focus section.
Try to adjust the convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
Its a fairly easy fix.
You can get a repair kit that includes all the parts from www.TvRepairKits.com. The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself.
Posted on Jan 31, 2009
  • Edward
    Edward Feb 12, 2009
    Your TV most likely has one of two possible problems.
    Problem #1: Convergence Chip Failure ( common problem )
    Here are some of the most common symptoms and example photos of a convergence problem
    • Screen looks 3D
    • Colors don't line up
    • One or more colors can't be adjusted when using the convergence menu.
    • Screen is bowed or warped.
    Using your original remote go-to the tv settings then goto the convergence section.
    Try to adjust the red and then the blue convergence.
    Solution #1
    You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
    Problem #2 CRT Fluid is Cloudy
    Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
    Picture of a set that needs the fluid changed.
    TV set after fluid change
    Solution #2
    What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Is problem covergance is bad model kp-fx43m91
I have Sony projection tv model FX 43 m 91 spiel no 1002334 in Mumbai India . I can see blue and red colour in every pitcher so let me know solution or any reliable official service centre
Aug 15, 2012 | Sony KP-FX532M91 TV
Our Sony Projection TV has the red color distorted
Double picture symptom shows tv got problem with convergence out section and most probably convergence out chips would be replace to fix this issue.
Though its job of qualified tv tech to replace convergence out chips yet I can provide you helpful info if you are handy with electronics stuff repair and can replace parts in circuit board as soldering work is needed with proper tools to repair tv.
Thanks.
Mar 14, 2010 | Sony KP-51WS510 51" Rear Projection...
Sony kp 51ws510 upgrade to HD - how to do this
There are inputs on the back of the set. If your tv is Sony 51ws510 then it is capable of HD, but you have to have component or DVI cables to connect the tv to the HD device (HD cable box or DVD player).
<br>
<br>
On your set the component inputs on the back of the tv are video5 and video6 in the middle located in a vertical line (red, green, blue rca video connections with red and white rca audio connections).
<br>
<br>
You also have a DVI input toward at the top of the input panel (white connector with red and white rca audio connectors).
Jan 03, 2010 | Sony KP-51WS510 51" Rear Projection...
Convergence chip part# ?
Convergence chip used in Sony KP-51WS510 part number is as follows..
STK392-560 and Sony part number, 874901908
Available in Part Store.
Thanks.
Dec 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
KP-51WS510
If you are facing the front of your TV, the red CRT is on your left. To get access to remove the CRT assembly, you will need to remove the speakers cover and one more wood or plastic cover that is protecting the CRTs.
Jul 16, 2008 | Sony KP-51WS510 51" Rear Projection...
Red Shadow
UNDER THE FRONT DOOR PRESS THE BOTTOM BUTTON "FLASH FOCUS" AND SEE IF IT FIXES IT. IF NOT AND YOU SEEN RED DOUBLE OF THE IMAGE, THEN THE SET PROBABLY NEEDS THE CONVERGENCE CIRCUIT REPAIRED.
DON.
Feb 01, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-51WS510 Shuts itself off
eight blinks means, "High-voltage error" and the probable cause location listed is, "T8005 is faulty (D board)". T8005 is the fly-back transformer assembly.
Dec 09, 2007 | Sony KP-51WS510 51" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
131 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
