Question about Health & Beauty
I want to register my shaver
Philips Norelco 13-40463/ buy in Bed bath &Beyond/ shave Norelco 6945
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Health & Beauty Master
  • 102,366 Answers
Assuming you're in the US, start here.
Posted on Jan 21, 2013
Blondie Girl
  • 25 Answers
SOURCE: can i use shaving cream with a norelco electric
According to the Phillips website, it is NOT a waterproof shaver, therefore it is not advisable to use any liquids prior to or during shaving.
However, as a hairdresser and having experience with shaving men for many years, you can use the tried tested and true method of either shaving AFTER you get out of the shower so that your hairs on your face are softer from being in the moisture, or if you are not planning on having a shower, you can just use a hot face cloth on your face for a few minutes before you shave. This will soften the bristly hairs on your face and make it easier to shave.
I hope this helps. Please remember to rate my help. I would greatly appreciate it!
Posted on Apr 26, 2009
brector3
  • 1602 Answers
SOURCE: Battery doesn't hold charge
sounds like you need a new battery. battery can be ordered from shaveroutlet.com
repair services are also available
Posted on Jan 16, 2010
brector3
  • 1602 Answers
SOURCE: How to lubricate Norelco 3405 shaver?
The sewing machine oil should work fine.
This model has 4 screws on the back. You must push up the trimmer to see two of those but the other two are in plain view. Remove screws with a flat jewelers screwdriver or you can purchase a special removal tool from shaveroutlet.com here:
http://shaveroutlet.com/screwdriver-access-tool-for-norelco-shavers-and-some-braun-p-262.html
Once the back cover is removed, you will be able to see the motor. It is attached to the gear housing by two metal clips. Remove the clips and you can lift the motor out. Apply a couple of drops of your oil to the pinion gear on the 'front' of the moto and a drop to the small indentation on the back of the motor.
If you still have noise. you will need to lubricate the gears. Temove the gear housing by removing the 2 screws that are on either side of the motor. The gear housing will then come off. The front and back of the housing are held together by plastic snaps on the three corners. Gently pry them apart to seperate and reveal the gears inside. Lift the gears out and apply a light form of grease to where the gears fit onto the back of the gear housing. Vaseline should work well if you have nothing else.
Reassemble in reverse order and it should run very quiet when you're done
Posted on Jan 26, 2010
brector3
  • 1602 Answers
SOURCE: Philips Norelco 7310XL Men's Shaving
Yes, this model can be used with voltage of 100-240V
Posted on Nov 07, 2010
  • 9 Answers
SOURCE: Norelco/Philips jet clean shaver cleaning bath no longer works
I have had three 1050CC shavers all with the same problem. Apparently other models have the same issue. After about a year of use, the unit reverses after dipping the shaver into the cleaning solution for a second. Two were replaced by Philips within the 2 year warranty period. I still use the 3rd one. There are several things you can try. If the cleaning solution is low this will cause the shaver to reverse and not clean. Add more cleaning solution. I have noticed that sometimes I have to add more fluid to the unit after a week of use. Sometimes it is necessary to fill the solution a little above the max fill line. Be careful though. Filling it too much above the max fill line can cause cleaning fluid to run out of the bottom after a cleaning cycle. If the above two fixes don't work, then press the clean button and after the unit reverses back up, wait about 5 or 10 minutes and press it again and it should stay down as long as there is enough cleaning solution in the unit. If you wait too long or too little to press the button, it won't work. I have noticed if I press the button immediately after it reverses the same problem occurs. Also if I wait 30 minutes before pressing the button the same problem occurs. There must be some sort of timing cycle. You may have to repeat this process a few times to get it to stay down and clean. This is the only way I can get mine to clean now. Obviously something is getting dirty or wearing out over time in the cleaning system. Since I have had 3 shavers with the same problem, I know many others have had it too. Philips must be aware of the problem. It is frustrating that they don't offer help on their own website and consumers have to band together to solve problems that they should be solving. The two year guarantee is very generous, but there is a design flaw with this product.
Posted on Jan 23, 2011
The norelco shaver i have does not shave
If the shaver is running ok but does not shave well, the blades either need cleaned or replaced.
You will find replacements for 8175XL model at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-hq9-replacement-heads-p-252.html
Scroll down the page for tutorial video showing how to remove blades for cleaning or installation
Oct 07, 2011 | Philips Norelco 8175XL Electric Shaver
I m loking for phlips shave battery # 6885
norelco replacement battery NiCd two batteries pack for electric shaver philips norelco 6885xl replacement parts.
Dec 26, 2010 | Norelco Quadra 6885 XL Electric Shaver
I need to buy shaving heads HQ8
philips norelco HQ8 replacement heads for electric shaver norelco spectra 8800 series, norelco 7800 series, norelco 7100 series, norelco 7200 series.
Oct 25, 2010 | Braun Replacement Foil Cutter for Most ...
What is the red blinking light showing the head mean?
Hello. That is a reminder that it is time to change the head, to maintain optimum shaving. It will blink the next 7 times you turn on the shaver. Here is the manual if you want to read more about it. http://download.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
ps kindly rate my answer as very helpful. thank you. Joe
Mar 29, 2010 | Norelco Arcitec Electric Shaver -...
Health & Beauty Logo
66 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
