SOURCE: Replacing steering wheel for 1999 bmw 323i sedan manual
it ois always better to replace your current part with either a used, a new OEM part, or a new aftermarket compatible part it will save you alot of frustration and money in the long run. please rate this solution
SOURCE: Remove me Steering wheel bmw 1999 e46 3 series
Disconnect negative battery cable. Locate airbag retentions on back of steering wheel. Unbolt or unclip retention devices, and release airbag. Then: Unplug airbag electrical connector. Remove nut or bolt in center of steering wheel with pneumatic impact wrench if necessary . Using appropriate steering wheel removal tool kit, carefully remove steering wheel, paying attention to associated wires, etc. Unplug anything not accompanying wheel, or that is in the way. Pay close attention to any rods, or contact pieces associated with the horn button(s.) Replace these upon reinstall. Reverse order to install including tightening center bolt to 35-55 ft-lbs. If this is your first stg wheel removal, try an old chevy, preferrably someone else's! If inexperienced, don't risk bruising your favorite Bimmer!!! Hope this helps you make your decision. Tater Todd
SOURCE: Steering Wheel Radio and Cruise Control stopping
This is due to a broken clockspring behind the steering wheel. It works as a constant contact for all acessories on the steering wheel to include the air bag system. It is a simple ribbon of wire to allow for turning of the wheel incased in a plastic housing that shouldn't be messed with. If you mess with it internally, you run the risk of the airbag deploying in your face!! It is best purchased from BMW.
