Question about Lakewood (5500) Oil Filled Radiator Heater
The heater turns on but doesnt heat - Lakewood (5500) Oil Filled Radiator Heater
  • miguelgon196
    miguelgon196 Jan 21, 2013
    Should i add oil? if so, what kind of oil?
Heater turned on. Why is there no heat?
Check the heater tap turns on and there is good water flow through the hoses and heater core ,check that the water temp is at least 85 deg.cel.. could also be the baffle in the heater core broken off.
Dec 19, 2015 | 2003 Saturn L-Series L300
Heat stays on with thermostat off
How Your Car's Heater Works (Or Doesn't) ' AC Pro
acprocold.com/blog/car-tipstricks/cars-heater-works-doesnt/
At A/C Pro, we're focused on helping people stay cool with our do-it-yourself car A/C repair kits. ... dropping, drivers are switching off the A/C and turning on the heater. ... When you turn on your car's heater, the hot coolant flows from the engine to ... Or it could be that the thermostat, which is a valve that regulates the flow of ...
Heat Won't Turn OFF: troubleshoot the room thermostat ...
inspectapedia.com/heat/Thermostat_Stuck_On.php
Here we discuss how to diagnose & fix a thermostat that keeps calling for heating or cooling when it should not. A separate article, HEAT WON'T TURN OFF, ...
Oct 06, 2015 | Cars & Trucks
Why is my lay z spa not heating?
if the heat light comes on but doesnt heat bad heater element if red heat light doesnt come on need new temp sensor
Aug 31, 2014 | Pool & Spa
Kenmore Dryer, heating element doesnt turn off
remove the back of dryer and remove the heating element from the heater box,check to see if the wires in the box are touching the heater box walls any where,this would make the element stay on all the time,also check the high temp thermostat on the left side bottom,this is the on off thermo for the heating element-mike
Feb 16, 2010 | Kenmore 63942 Dryer
My ACL lifestyle lp522 doesnt turn heater off
Hi it sounds like it hs worn inside exchaning it would be the cheaper option
Feb 01, 2010 | Honeywell Programmable Thermostat Heater
Pilot light goes out when i turn on heat. pilot light is blue flame lights good but when try to turn on heat it clicks and goes out therefor heat doesnt come on
How long do you leave the pilot on before you turn on heat. The thermal pile will take 3-5 minutes to heat up before it will send a signal to gas valve. If thermal pile doesn't send signal then gas valve closes. You might need a new thermal pile.
Jan 18, 2009 | Rinnai Toyostove Direct Vent Heater:...
Fan runs backwards forces flame to blow back into heater instead
cracked heat exchanger not cheap replace unit ur motor just doesnt change rotation on its own
Jan 13, 2009 | Reddy Heater RLP100 Portable Forced Air...
90 ford ranger heater trouble
Heater core or one of the hoses are leaking. Low on antifreeze now so no heat.
Dec 31, 2008 | 1990 Ford Ranger SuperCab
Heater control only works on high
You need a blower motor resistor,and the heater blower motor should be checked for high amp draw. check Napa for the part or go to Dodge..prpbably about 60.00 dollars.
Dec 19, 2008 | 1996 Dodge Caravan
Heater doesnt change to cold
Try looking at the hot/cold switch.
Dec 07, 2008 | 1998 Mazda B-Series
Lakewood (5500) Oil Filled Radiator Heater Logo
42 people viewed this question
Top Lakewood Heating & Cooling Experts
jay kaye
jay kaye
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
Are you a Lakewood Heating and Cooling Expert? Answer questions, earn points and help others
