Question about Cell Phones
My mediatek mt3351 wont load past the first screen
My satnav showed a error message then would not load..now when you turn the touch the navigation button nothing happens
SOURCE: jensen nvx225 navigator and can't get it to work
I just recieved mine as a Christmas Gift. I am having EXACTLY the same problem. I, also, have tried the reset button that is located in the back of the unit. I'll have to get back to you when/if there is a resolution.
Posted on Feb 02, 2008
zohail
  • 1223 Answers
SOURCE: touch pro screen blank
first try this
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if ur pda boot normally after reset procedure it will take some time to boot dont panic if it is ok then good luck
if it doesnt help then then go to www.htc.com and upgrade ur ROM
Pls rate me FIXYA if it helps
Posted on Mar 14, 2009
SOURCE: touch screen does not work
1) Ensure that a cartridge is not inserted
2) Hold down the Hint button while turning the unit on
3) When the LEAPSTER menu screen appears, press the A button
4) Touch each of the crosshairs that appear with the stylus
5) Restart unit
Posted on Mar 30, 2009
ginko
  • 19396 Answers
SOURCE: My Lg Monitor wont show screen (Power Button Flashing)
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on May 04, 2009
SOURCE: Touch screen won't work
I had the same problem so i went searched to see if i could find a new touch screen which they call a digitizer. Every where i looked they costed about 110 bucks! good thing i did some digging there is this site call fonlogix.com......they have phone parts and the digitizer cost 20 buck plus about 10 buck freight through usps. i also recommend getting a screen protector. it works great now!
Posted on May 27, 2009
I just purchased this unit and it has us maps and as i am in australia i woild like to know how i can change it thank you John Fogerty
if you have just purchase the unit ,there should have been a user manual in the box that it came in
if not there are several options open to you
If you have bought this unit off shore from e bay or the like then you will need to find out if the unit is supported in Australia by going to the supplies address and getting a list of service agents in this country
you can go google and type in--- distributors for ( make and model) gps unit -- and see if the are any distributors for pacific region or Australia
You can contact the manufacturer direct on their -contact us - section and ask for maps for Australia ( possible down loads ) for that unit
or you can go google and type in-- manufacturer of -(make) - units .com.au and see if there is a local head office
Oct 12, 2015 | Buybay Windows Ce 6 0 Mediatek Mt3351 Cpu...
Mediatek mt3351
lostdownload sd card
Jan 12, 2014 | Computers & Internet
Navsure n420i won't load
This is washers & dryers. Try posting in Nav.
Oct 23, 2017 | Washing Machines
"error loading operating system" message on dell inspiron 1420 laptop
only way to bypass this is use a recovery disk to boot from and then perhaps the issue will manifest itself
otherwise, it's the dreaded re format step
May 22, 2012 | Dell Computers & Internet
I have a cracked touch screen My &%T can it be
Welcome to FixYa!
Yes it ca be replaced. Go to Satellite Navigation Repairs for qoutation. Click the link below. http://satnavrepairservice.com/repair-satnav/navman-repair/14.html
Thank you for using FixYa. Have a great day.
Jas247
May 10, 2011 | Navman Navm ICN630 GPS Receiver
I have a VW Passat 2006 3.6L. I entered a wrong radio code twice after taking out my battery, it blocked me thereafter. Now I have the correct code, but it is showing SAFE. My type of system comes with a...
the satnav/radio has to be ON for 3 hours without any action. I am not sure, if it has to be 3 hours consequently, so 3 hours the engine and satnav on, or it could be for example 6 halfhours, I dont rememmber, but I had this exact problem with 2005 audi allroad. The safe characters will change after 3 hours to rotating numbers and you will be able to enter the code.
DOnt bother to go to the service station, all they can do is also wait or completely reset the unit, which is very pricey, because they have to remove the backpanel..
Be patient, dont touch the satnav let it on, its really a long timespan but it works.
Feb 28, 2011 | 2006 Volkswagen Passat
My samsung genio touch wont turn on past the loading screen it just freezes how can i fix this?
my samsung genio touch wont turn on past the loading screen it just freezes how can i fix this please i really need ur help
Jul 17, 2010 | Samsung SGH-J600 Cellular Phone
2004 S-430 command unit shows "No sound available"
PROBLEM IN FRONT SAM CONTROL MODULE WITH FUSE AND RELAY.WOULD BE BEST TO TAKE TO DEALERSHIP MERCEDES BENZ IS A EXPENSIVE CAR TAKE SPECIAL TOOLS AND HIGH SKILLS.
May 25, 2010 | 2004 Mercedes-Benz Mercedes Benz S Class
Satnav Problem
I purchased this sat nav only a couple of weeks ago :@
and when i punch in a post code for it to take me to the place i want to go it shows me the wrong way and it switches off on it own this is really irreating and im pissed off so anyone know what to do then i would be greatful from -- Jordon Carrter :)
May 18, 2008 | Garmin StreetPilot c510 Deluxe GPS...
Cell Phones Logo
61 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
