Question about Samsung ML-3712ND LASER 37PPM 1200DPI Inkjet Printers
ML-3712ND, paper won't feed from tray 1 - Samsung ML-3712ND LASER 37PPM 1200DPI Inkjet Printers
Orbixx
  • 133 Answers
SOURCE: automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Posted on Sep 06, 2007
SOURCE: Samsung ML 2510 feed problem
I purchased the printer new in a box from ebay. Samsung agreed to repair the printer under guarantee. The repair shop has fixed the printer easily apparently. There was a gear out of line which once readjusted ensured the printer works properly. I have not taken the printer apart myself but this should be straight forward. No need attempt if the printer is still under guarantee.
Posted on Jan 11, 2008
Bubbabear64
  • 2794 Answers
SOURCE: Paper jam
You could try cleaning the tires if you can get to them and check to see if there isn't any paper stuck in the paper path.
Posted on Jun 11, 2008
SOURCE: Paper jam error
After I looked online for a solution I contacted the manufacturer and was advised to return the unit for repair.
Posted on Feb 12, 2009
ghassun
  • 499 Answers
SOURCE: Samsung ML 1510 LAser Printer
check the spring if it push the roller well or it's weak also check ur paper if its high quality to be rolled
Posted on Jun 12, 2009
Why does my Samsung ML-3712ND printer say "paper empty in MP tray" when it is not empty?
The MP tray is the fold down 50 sheet tray that is built in to the front door of the Samsung ML-3712. It is usually used for thick papers, letterheads and unusual sized paper.
Sometimes people mistake the 250 sheet cassette tray that slides underneath the printer for the MP tray.
If you want to print on plain paper in your cassette tray and you keep getting this message.
1. cancel all print jobs
2. try printing a new document ( you can make a new word document with just one line)
if that works
Usually one of the settings in the print job you are printing will be out of specification ( could be too small margins) and the printer will be trying to feed from the MP tray
If the new print job doesn't work, the problem is likely in your default printer settings/properties
Dec 01, 2014 | Samsung Office Equipment & Supplies
I can't get anything to print from tray 1, the manual feed. I'm trying to print envelopes and they keep printing on 8.5x11 paper from tray 2. If I put envelopes in tray 2 it won't print
Have you already tried this? After you click print and select your printer, click properites and select your paper from 8.5x11 to Envelope.
Jun 25, 2012 | Xerox Phaser 8560MFP Laser Printer
1) paper won't feed through. 2) Constantly saying paper jam
If it is a laserprinter, your paper can be too dry or humid. Try a new pack of paper. Or turn the paper that is in your tray upside-down.
Jul 17, 2011 | Office Equipment & Supplies
We just moved, and now that I've set the printer up in a new location, the paper won't feed at all. I removed the cartridge and wipped the paper feeder with alcohol still no luck
Hi
When you move the printer normally somethings will brake and get stuck. But 1st things 1st did you check if the tray lifts to take the paper? or try to take the paper atleast? if not then you can try to wiggle the printer a little and you should fine some thing being stuck come out and the printer work well again.
PLZ RATE MY SOLUTION
Jul 06, 2011 | Samsung ML 2010 Laser Printer
Paper won't feed from both tray and manual feed tray...motor starts, attempts to grab paper, but doesn't
THERE IS TWO REASONS. PICKUP SENSOR PROBLEM OR IN THE FIXING UNIT HEATER SECTION PROBLEM. SOMETIMES HEATING ELEMENT BURNED. CHECK THE BOTH ITEMS .
Jun 18, 2011 | HP Office Equipment & Supplies
Wheres the manual paper feed on a samsung ml-3051n
The Upper Tray (Tray-1) is the Manual Paper Feed Tray.
CreativeTECH
Jan 05, 2011 | Samsung ML-3051N Laser Printer
Samsung ML-1651N Printer
I have the exact same problem with my ML-1651N printer. It started out as an annoying problem that i solved by pulling the paper try out and then pushing it back in again. Now that solution doesn't work anymore.
Aug 23, 2007 | Samsung ML 1651N Laser Printer
Samsung ML-1440 Print Problem
SOME PIECE OF PAPER ETC IS STUCK IN THE FUSING, PLEASE CLEAR THE SAME , PROBLEM SHOULD BE RESOLVED OMNIPRESENT
Aug 26, 2006 | Samsung ML 1440 Laser Printer
Samsung ML-3712ND LASER 37PPM 1200DPI Inkjet Printers Logo
59 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
