Question about Microwave Ovens
MICROWAVE SUDDENLY STOPPED
FUSE IN POWER PLUG OK
  • Microwave Ovens Master
  • 17,130 Answers
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if the switch contact are not good then it will not trigger the processor to switch on the waveguides. If the lights or fan work without any display or action of program being triggered to start then it can be a possible fault on the main board or the processor. Sometimes insect secretion can short the board and display panel and so the processor can work in such an erratic manner. If so clean, solder and reset the board. Now identify the parts by clicking this link: http://www.espares.co.uk/advice/microwave/a/5/141/identifying-microwave-parts.html
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron. Check this link to know how a microwave works:
http://www.espares.co.uk/advice/microwave/a/5/1443/how-a-microwave-oven-works.html
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off. Check the wave guide covers, if food had deposited
then it must be checked or replaced. See link:
http://www.espares.co.uk/advice/microwave/a/5/1146/how-to-replace-a-microwave-guide-cover.html
Now keeping clear of the microwave, switch on; use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Posted on Jan 22, 2013
  • 234 Answers
SOURCE: replace fuse in microwave oven
Mmost of these has a fuse in the back where the cord is connected.
Posted on Mar 21, 2009
  • 458 Answers
SOURCE: Microwave doesnt power up
If there is no power at all then it could be the internal power fuse has blown, there could also be other parts faulty also. I would not recommend you to check this if you are not electricallly qualified as a microwave is a very dangerous piece of equipment to tamper with, even if there is no power to it. It would be best to call a service engineer to check it over for you.
Posted on Sep 23, 2009
  • 4 Answers
SOURCE: convection microwave oven suddenly stopped
If there is no power to the unit at all, no lights, no nothing, but there is power at the outlet, then you are most likely going to need a new board. the Electronic control board controls everythign on that unit. I woudl call GE direct for service, adn depending how old it is they may be willing to give a parts and or parts & labor concession - they are usually pretty good about that kinda stuff.
Posted on Nov 02, 2009
kel1guy2002
  • 3740 Answers
SOURCE: microwave MH7130XEB-2 stopped working while
There are 2 fuses in your unit.
The line fuse: (Item 14) (20 A)
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=260484&diagram_id=93994#d93994
and the Thermal Fuse (Item 5) same link
Either of the 2 can cause your unit to no longer operate. Most of the time the failure is the line fuse.
Thanks for using FixYa.
Kelly
Posted on Mar 19, 2010
tbirdfan1
  • 3051 Answers
SOURCE: My microwave suddenly has no power, clock etc. I
Hello there and thank you for choosing fixya:
This is a very common issue with microwaves
Yes you are right it does indeed have a fuse inside of it
you first need to unplug it of course then take out all of the screws that are along the outer edge on the back there may be 4 or 6 ok next there are 3 or 4 screws that are on the sides that need to be removed ten if you take a small flat tip screw driver and insert it in the seam at the top towards the front you should be able to slide the cover back about 1 to 2 inches then it will lift up and slide off
Next if you look towards the front on the same side as the power panel yuwill see a electronic board it has the fuse on it it looks like this picture i have below simply remove the fuse and replace it WITH THE EXACT TYPE OF FUSE OK
then plug it in and ensure every thing is working if so great go ahead and unplugit again and put the cover back on ok but if not please post me back so i can continue the troubleshooting from there ok ? here is the pict
Best regards mike
Posted on Mar 04, 2011
Convection oven suddenly stopped working in the middle of cooking. Is it a fuse?
HI THERE IS ONE IN THE PLUG AND AN INTRNAL FUSE IN SIDE YOU WILL HAVE TO OPEN THE SIDES OF THE OVEN TO GET AT IT SOME HAVE MORE THAN ONE FUSE IN SIDE
Jan 12, 2016 | In Microwave Ovens
GE microwave suddenly stopped. Plug is OK, fuse not blown. Is there a way to reset?
No! if your microwave oven is 7 years old or less it will most likely have a inverter board that often causes trouble, or the keypad control board is defective.
May 17, 2012 | GE Microwave Ovens
My microwave stopped working suddenly, the fuse is ok, power supply ok. It is built in can you advise please.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ;'
May 16, 2011 | Electrolux EMS2487X Convection Microwave...
My microwave just stopped working. No problems until now. In the middle of cooking it just stopped. No display, no beeps, no bouttons working, no light inside. There is power to the outlet I can plug in...
for the microwave to stop suddenly it has blown its internal fuse this is located under the top panel of the unit it should be white with two silver tips ( ceramic fuse) in some cases the fuse will blow for no good reason on the other hand it can be a serious fault the fastest way to check this is to replace the fuse and re test the unit if the fuse blows instantly then bin the microwave if not it the fuse may have simply failed
best of luck always remember unplug the unit first and always replace with same size and and current fuse
please rank this advice if it helped you
Dec 28, 2010 | Kenmore 80402 Microwave Oven
Our microwave suddenly stopped operating.
Inside is a fuse. It is probably bad.
Jan 19, 2010 | Microwave Ovens
Microwave doesnt power up, suddenly stopped working, can it be the fuse? ow do u check if the fuse is OK?
Sep 23, 2009 | Oster 0.7 Cu. Ft. Compact Microwave
Microwave stopped working, no power. Checked
There are two thermal fuses.
One is located on the magnetron and another one is located on top of the left side of the cavity under the air duct. The microwave has to be removed from the cabinet to access the second one.
The problem turned out to be a 20 amp fuse that I was able to replace and the unit is working fine. Sometimes a blind squirrel finds nuts.
Aug 24, 2009 | Kenmore Microwave Ovens
JVM1440WA01
did you check the fuze in the microwave or the house?
Jan 13, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
82 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
