Question about Refrigerators
What is the problem when water drips constantly from the ice maker into the ice tray, making one big block of ice
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
This sounds like the automatic water valve is not shutting off completely. It may be due to something in the valve that is keeping the it partially open. You might could take it off and clean it out. Or replace it with a new one.
Posted on Jan 21, 2013
  • 489 Answers
SOURCE: Lg side by side Ice maker not filling all of the tray/dripping
You may have a restriction in the icemaker.  Remove the icemaker and make sure that there is no ice buildup other than in the cube slots.  Also make sure that the fill tube is clear of any ice obstruction.
Posted on Apr 27, 2008
  • 8 Answers
SOURCE: fridgidaire refridgerator - adjust water level in ice maker
Hello....remove the from cover on the ice maker, and adjust the water flow screw inside. Turn the screw in the direction of the (-) negative side by half a turn to start. Adjust as needed. I hope this helps. ;)
Posted on Feb 20, 2009
  • 358 Answers
SOURCE: water leaks from ice maker in ice tray.
When the ice maker calls for water it'll be filling for about 7 seconds if is more the ice maker inside control board is bad , but if there's water in the ice maker all the timeeven after or before it calls for water it means that the water valve (solenoid) that supplies water to the ice maker is leaking and you have to replace it.
Posted on Apr 27, 2009
  • 358 Answers
SOURCE: Shelf kitchenaid Refrigerator's ice maker leaking water
Turn off the water line that goes to the refrigerator and see if still leaking if not the problem is with the solenoid valve ,which is an electric valve that opens only when the ice maker calls for water and is located at the back of the fridge in the bottom behind the cover(if your refrigerator has water and ice dispenser ,Its called dual valve). And if leaks when you turn on the water ,this part has to be replaced .But if leaks and overflow the ice maker only when it calls for water the problem is in the ice maker and to repair it will cost almost as a new one .
Posted on Aug 13, 2009
  • 358 Answers
SOURCE: ice maker dripping water fusing ice cubes
The dual water valve (solenoid) that open and let the water from the line when the ice maker calls for it, is leaking and needs to be replaced.
Posted on Aug 17, 2009
Pim10bls
Possibly the water control valve is leaking when shut off, and water constantly drips into the ice tray fill tube. When this happens, the fill tube becomes clogged with ice, and the ice tray does not fill. The ice tray will cycle often, because there is no water in the tray, but will remain empty. If this is the case, the water control valve at the bottom rear of the refrigerator will have to be replaced.
Jul 31, 2014 | Polar PIM10BLS Portable Ice Maker
What is the problem when water constantly drips from the fill end of an ice maker into the ice box, making one big ice block?
It appears that the automatic water valve is stuck partially open. You can remove it and try cleaning it or purchase a new one and replace it.
Jan 21, 2013 | Refrigerators
Hoshizaki model AM50BAE not dropping ice...
Replace water float and check water inlet valve. with water constantly filling sump tray it will not make ice water will never cool down to 32 deg.
May 26, 2012 | Hoshizaki Cubelet Ice MakerDispenser Water...
Ice lies in tray in big lumps
If the water fill tube in back of ice maker is frozen also it is very possible that the water control valve is defective for the ice maker side. For example to turn off a faucet and it it off but there is that constant drip of a bad seal in valve that needs to be replaced. I am not saying this is the solution but this is the most likely reason. I will need you to answer before you rate. Some customers come here because they need answers yet are not able to answer back. Were you wrote Quote, (ice lies in tray in big lumps) I noticed that you placed no model number. Then ae you sure the model number above your post is RS2630SH? Thanks, Sea Breeze
Apr 09, 2010 | Samsung RS2630SH Side by Side Refrigerator
The Ice maker does not make cubes.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze blocking the fill tube.. You can take the water line off the valve and watch to see if it drips.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Feb 06, 2010 | Refrigerators
Ice maker drips water into ice tray
Probably the solenoid valve leaks(electric valve that opens when the ice maker calls for water) and overflood the ice maker,the only way to fix this is replacing the solenoid.
Sep 22, 2009 | Kenmore Refrigerators
Aug 13, 2009 | Refrigerators
Ice maker is making ice cubes AND pouring water
the apparatus that distributes the water into the tray had been knocked out of balance when taking the tray out. We pulled the ice maker and replaced the apparatus back in it's proper location .
Aug 07, 2009 | Freezers
LG ICE MAKER
Be sure that the fill tube is getting into the ice maker and that the ice maker is not blocked with ice.  If everything seems ok, you may have a leaking water valve which causes it to constantly drip water into the ice maker causing the block of ice.
May 16, 2008 | LG LFC25760 French Door Refrigerator
Refrigerators Logo
60 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
