Question about eMachines EL1333G03w (884483010820) PC Desktop
I have an el1333g desktop it has a amd 64x2 2.4 prosscer in how much bigger can i go
  • eMachines Master
  • 27,725 Answers
Select the "Start Menu." Click to select "Control Panel." This will open a new window with several clickable options. Choose "System and Maintenance," typically located near the top left-hand corner of the Control Panel Click to select "System" from the new list of options Look for the CPU's stock speed as indicated under the "Processor" heading. This is a ballpark, relatively close estimate of your computer's CPU speed, as provided by the manufacturer. Checking the Stock CPU Speed in Windows XP Click the "Start Menu. Right-click on "My Computer." Select "Properties." By default the Properties window will usually be set to the "General" tab, but if the window is set to a different tab you'll need to click on the "General" tab located near the top of the window. Check the CPU rating as listed underneath the "Computer" heading. b> Determining Real-Time CPU Speed Go to CPU Speed Professional's website (see Below) and download "CPU Speed Professional." While other free CPU clocks exist, many are beta programs with glitches and unwanted bugs. CPU Speed Professional is well-known and reputable, receiving the "Vista 5 Star Software Award" according to its website. Install the recently downloaded " http://download.cnet.com/cpu-speed-professional/3000-2086_4-10833139.html " file by double-clicking on it and following on-screen prompts to complete the automated install procedure. Open CPU Speed Professional. Click "Test Your Speed" on the main program interface. A real-time, active measurement of your CPU speed will appear numerically, and CPU Speed Professional will also display your CPU speed on a stylish meter for easy visual comprehension. Get a Faster Processor b> Start by visiting Intel.com (see the Below ) to research and figure out which processor you want. http://www.intel.com/products/processor/index.htm Read the page and click on the links to the different processor families. Once inside the processor families you can look at the specifications and speeds of the processors. There are three main ways of determining the speed of a processor. First is the speed, measured in GHz. The higher the speed (example: 2.4 GHz) the faster the processor. Second is the L2 cache, measured in MB (example: 2 MB L2 Cache). The L2 cache is kind of like the CPU's own RAM; the larger the cache, the faster your computer operation will be. Finally, there is the Front Side Bus (FSB) speed. The FSB speed is the speed that bits of data are fed through the processor. FSB is measured in MHz (example: 1066 MHz FSB). Once you have an idea of the processor you want, continue to step two. Ensure that your processor of choice will be compatible with your current system. You can do this by checking the documentation for your motherboard. Look through the manual to find out what its CPU socket type is (example: LGA775). There can and will be different socket types on CPUs so ensure your processor choices match up with your motherboard before continuing. The socket (or package) type will be listed in the specifications of any processor you look at. Worth noting is that some motherboards also impose a limit for how high the FSB of a processor can be. While a higher FSB processor will still work with a lower FSB motherboard, processors have to go by the speed limit imposed by the motherboard. Keeping this in mind, as long as the socket type is the same on both parts, they will be compatible. Visit Newegg.com (see Below) or a similar computer or electronics store of your choice and nose around the processor section of the site. http://www.newegg.com/Store/Category.aspx?Category=34&name=CPUs-Processors You should be able to find the processor model you are after. Decide on a processor. If you've already done the research suggested in steps one and two, you should have a decent idea of the kind you want. Choose among the models you selected and add it to your cart, ensuring that the socket type of your new processor will match your motherboard. Once purchased, you should receive it within a few days.
Hope this helps.
Posted on Jan 22, 2013
Need a diagram for el1333g motherboard
Try:
http://ez93.com/download/emachine-el1333g-motherboard-manual.html
Nov 27, 2013 | E-Machines EL1333G01w Desktop PC with AMD...
EMachine EL1333G windows 7 64 bit AMD Athlon 2650E Processor ( BIOS OVERCLOCK HELP)
What type of cooling do you have currently? How fast do you want it to go? What options does your BIOS offer?
Apr 23, 2013 | E-Machines eMachines Desktop PC
Troy,
When Processors (CPU) are made, they are made on a Pass/Fail scale. Processor is either Good, or not good.
This means you may get a Processor that is on the Top of the scale, or Bottom of the scale. The AMD factory doesn't discriminate.
In fact they don't care. (This goes for all Processor manufacturers, not just AMD)
All they care about is does the Processor work, or not?
Therefore, you may have a Processor that is on the Bottom of the scale, but passed as Good.
Point? Stating a setting that might be good for joeblow's AMD Athlon 2650e, may not work for yours.
Might work for yours, and not joeblow's.
This is why you need to go into BIOS Setup, and using a SMALL increment, overclock the Processor.
Run the computer for 24 hours, and see if everything is chiily.
(Computer still works OK)
This is a "Burn-In test"
Works OK for 24 hours? Then go back into BIOS Setup, and go up one more small increment. Do the Burn-In test.
Keep going until the computer has glitches, or doesn't work.
Then go back into BIOS Setup, and come down one small increment, or go back to where the computer WAS working OK.
It's an individual thing. Each Processor (CPU) is different from the others.
For additional questions please post in a Comment.
Regards,
joecoolvette
How to use the card reader emachines EL1333G-03W
Insert your media into the appropriate slot. Open "my computer" and open the media once it is recognized.
Nov 10, 2012 | eMachines EL1333G03w (884483010820) PC...
I have a emachine EL1333G. How do I record on the DVD
install super drive and instal nero burrning and enjoy burn dvd
please yes for vote
Jan 15, 2011 | E-Machines eMachines Desktop PC
I need a manual for a HP Pavilion 8860 which I bought at a garage sale. It had a virus and everything was removed, and only windows 2000 professional was installed. I have tried for over two week to find...
Here are the specs:
  • Form Factor: Micro Tower
  • Processor: AMD Athlon 1 GHz
  • Installed Memory: 128 MB (SDRAM)
  • Operating System: Microsoft Windows ME
  • HDD Size: 60 GB
  • Optical Drive Type: CD-ROM CD Burner
With 128 MB of memory it is mostly good for a door stop. You could buy more memory, buy an operating system, etc. but you'd be better off getting a low cost machine out of the Sunday ads.
Walmart as an example has this computer for $298
eMachines EL1333G-03w Desktop PC with AMD Athlon LE-1640 Processor and Windows 7 Home Premium 3_7.gif
  • AMD Athlon LE-1640 processor
  • 2GB memory & 500GB hard drive
  • Multi-in-1 card reader, Gigabit Ethernet
  • Windows 7 Home Premium Model#: EL1333G-03w
  • .TopAd { margin-left:-280px !important; text-align:center; } Order Online $298.00 icn_free_shipping_to_home.gif icon_instock.pngIn Stock
    icon_s2h.pngShip to home
    Aug 17, 2010 | HP Pavilion 8860 (P2941A) PC Desktop
    Overheating desktop
    Hi..It could be your processor is overheating. The cpu may be perfectly fine for gaming but it may need a bigger heatsink and fan or needs to have the dust bunnies removed.
    Jul 25, 2010 | HP Pavilion a6547c Refurbished AMD Desktop...
    eMachines EL1333G03w (884483010820) PC Desktop Logo
    193 people viewed this question
    Top eMachines Computers & Internet Experts
    Avishek Samaddar
    Avishek Samaddar
    Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
