Question about Dryers
My Neptue dryer was running and starting making a grinding noise. It stopped and will not go back on. The panel will light up but will not start when pressed. Any ideas?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 169 Answers
Do you hear anything like a motor running? Or a small vibration?
Posted on Jan 22, 2013
gittos73
  • 244 Answers
SOURCE: hotpoint aquarius vtd00 dryer starts ok then slows down and stops
sounds like your bearings have gone at the back off your drum behind the small middle panel try turning it by hand if it starts scrapping straight away then u need to replace the bearings m8
Posted on Feb 08, 2008
hunter19_46m
  • 7482 Answers
SOURCE: grinding noise in Maytag dryer
ALWAYS UNPLUG YOUR DRYER BEFORE STARTING ANY REPAIRS Your problem sounds like drum rollers have flat spots on them or in need of lubrication.If you have a front loading machine, Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be REAL CAREFUL not to knock any of the wires off of the timer switch. Then remove the top of the dryer. Remove the front of the dryer. This will expose the drum and belt. Remove the drum and belt and this will expose the drum rollers, idler arm pulley and motor. Now is a good time to check the belt condition for wear. Be sure to note the route of the belt, this will come in handy when you go to reinstall the belt. Check your drum rollers for flat spots or wear, if they have flat spots or wear on them replace them. If the drum rollers don't have flat spots or wear on them then they probably only need lubrication. Lubricate the shaft of the rollers with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve your noise problem. I will include these two websites for parts and further help: http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx Both also have chat assistance 24/7. Good Luck, I hope this helps Please rate me, Thank You
Posted on Mar 03, 2010
heatman101
  • 43501 Answers
SOURCE: squeeky noise in the back of dryer when running?
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up " -
Posted on May 12, 2010
Testimonial: "Thanks for your response to this matter, as I thought that it was exactly what you said, but needed a solution from some one that knows. thanks"
TheMobilian
  • 8220 Answers
SOURCE: dryer won't start
Might be a bad motor, locked rollers/ idler, or worn out glides pinching the drumd43e4a0.jpg
Posted on May 24, 2010
heatman101
  • 43501 Answers
SOURCE: dryer makes clicking noise when running
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
w56w
Posted on Sep 29, 2010
When the dryer starts it makes a horrible squealing noise and then stops running within 5 mins..all lights flash on with error code Ad...no clue what I should be looking for to fix this
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 19, 2011 | Electrolux Frigidaire Affinity 5.8 cu. ft....
AEG Lavamat 16820 turbo Washer/dryer won't start - makes noise
heatman101
dgmj
Apr 18, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
Dryer makes clicking noise when running
heatman101
w56w
Jan 19, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Clicking/tapping noise back of dryer
heatman101
fgj
Dec 27, 2009 | Frigidaire FEQ332E Electric Dryer
Kenmore dryer stopped running
Hi, I can determine a motor bad by the noise. Does it hum while holding the start button or is it a grinding deep sound? It can sound like the motor starts slow but once it gets going, it is ok. Sometimes the house lights will dim when the motor statrs going bad.
Let me know if I can help you further.
Vic
Jul 02, 2009 | Dryers
Gas dryer runs sometimes, not others.
heatman101
dhjhdf
Feb 15, 2009 | Magic Chef CYG4000AWW Gas Dryer
My Kenmore Soft Heat Dryer starts, then stops.
heatman101
fsh
Dec 10, 2008 | Kenmore 74602 Gas Dryer
Dryer Problem
Grinding noise most likely due to the front drum bearings worn out - result is the metal drum making contact with the rim of the from panel.
This requires a total disassembly of the dryer to investigate & likely replacement of the front slipper pads (dry nylon slipper bearings 4 x ).
This will only be a succesful repair if you stopped using the dryer the moment it started screeching.
If you have let it run, the metal-on-metal will have gouged the edge of the drum and will rip up any new replacement bearing pads.
Do not attempt this unless you are a very competent handyperson. Many screws lost, cut fingers and swear words will ensure if you are not confident in approaching this job, so either toss the dryer or get a competent repairman to do the job.
Mar 18, 2008 | Fisher and Paykel Dryers
Hotpoint aquarius vtd00 dryer starts ok then slows down and stops
Feb 08, 2008 | Dryers
Dryers Logo
29 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
