Question about Maytag Washing Machines
Remove covers how do i remove covers from lat9406aae
  • Maytag Master
  • 17,129 Answers
Click this link for tips: removing covers
Posted on Jan 22, 2013
Removing steering column shroud on a 2006 sierra 3500, no screws where videos show to remove them there's a recess area but no screws in the locations indicated
Steering Column Trim Cover Replacement
Important: You must check for 2 pan head tapping screws (1,2) in the lower trim cover before removal.
If necessary, remove the 2 pan head tapping screws (1,2) from the lower trim cover (3). Remove the lower trim cover (3).
If screws are not present in the lower trim cover, proceed to the next step.
Gently unsnap the lower trim cover from the upper trim cover.
Important: You must check for 1 TORX® head screw (1) in the upper trim cover (2) before removal.
If necessary, remove 1 TORX® head screw (1) from the upper trim cover (2).
If a screw is not present, remove the upper trim cover (2).
Dec 01, 2016 | 2006 GMC Sierra 3500
Change timing belt
timing belt? on a Jeep? 05 wrangler
what engine is this>?
ah the 2.4L
front cover
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove the crankshaft vibration damper.
  3. Remove the generator drive belt tensioner assembly.
  4. Remove the timing belt front cover bolts, and remove the covers.
rear cover
  2. Remove the front covers.
  3. Remove the timing belt.
  4. Hold the camshaft sprocket with Special Tool 6847, or equivalent, while removing the center bolt.
  5. Remove the timing belt idler pulley.
  6. Remove the rear cover fasteners and remove the cover from engine.
Apr 04, 2014 | 2005 Jeep Wrangler
Maytag washer LAT9406AAE overflows and will not advance through any cycles
Check the small hose that goes up to the water level control. Check and blow out any water in it. Replace if it is loose or any broken fittings are in the line. IT works by building up pressure in the line as the water rises and activates a switch that is set by the water level you select. IF it doesn't sense the pressure it will allow the water to keep running. Unless it switches off when full there will be no further progress in the cycle.
Aug 12, 2013 | GE WBSR3140DW Top Load Washer
Maytag washer model lat9406aae totaly dead is there a fuse in the washer?
If this does not work on any cycle then make sure you have electricity at your outlet as there is no fuse for this unit.
If you have power but it will not work in any cycle then you most likely need a new timer.
If the unit will fill and wash but not spin or drain then you most likely need a lid switch.
Feb 19, 2013 | Maytag LAT3600A Top Load Washer
I have a maytag washing machine, model #LAT9406AAE, water leaking from the bottom of the tank where the transmission housing shaft is hooked up.
That sounds like the center shaft seals are worn out. If the shaft and related parts are not corroded or rusted, it can be fixed. If it is the tub boot seal, it is a major teardown either way. But that model is worth fixing up if it is in good enough condition, and the cost in your area isn't over $200.
Jan 06, 2010 | Maytag Washing Machines
Top Loader LAT9406AAE s/n 23257742UQ Will not operate in any mode
if the washer will not fill I would change the water inlet valve. this could be the problem for all other issues. if the machine has no water in it, likely the timer will not advance to wash.
Oct 27, 2009 | Washing Machines
Maytag top loading washer will not agitate
My rule of thumb: Take what you paid for the washer new and divide by number of years without repairs. That is your cost per year for the washer. If the repair will get you another year and is less than the number above do the repair. If you have done more than 2 major repairs in a year it is time to think new. eric
Aug 10, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag top loader washer
The brakes are probably stuck or the cam that releases them is damaged
Sep 27, 2007 | Washing Machines
Washing Machines Logo
297 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
