Question about Husqvarna 50 51 55 61 254 257 261 262 266 268 272 Ignition Coil
Repair Husqvarna 261 gas vent
Gas is leaking
2 Suggested Answers
  • 5 Answers
SOURCE: gas leaks out of husqvarna 350 when in use
when you refer to using it i take that as your motor is running properly which rules out the fuel supply lines, and the primer bulb .. probaly one of two things check the gas cap and make sure it has a washer and makes a liquid tight seal and inspect the tanke for any hairline cracks that begin to drip when the motor is at idle, if it could also b the primer return line that vents back to the tank ethanol has a bad habit of eating up fuel lines on two cycles
Posted on Apr 13, 2012
Where to find vent line on 359 husqvarna
Husqvarna chainsaw fuel line check and replace - YouTube
? 3:44
https://www.youtube.com/watch?v=8FyU_fG9qwc
Feb 6, 2012 - Uploaded by mweba1
359. ... Husqvarna chainsaw fuel line check and replace. mweba1. SubscribeSubscribed .... You will want to inspect the tank vent and fuel line.
Husqvarna common air leak - YouTube
? 1:51
https://www.youtube.com/watch?v=Z7f9zNQTJBQ
Apr 11, 2012 - Uploaded by mweba1
Husqvarna common air leak ... Husqvarna 136 ChainsawCarburetor Rebuild & Fuel Line Repair - Duration: 22:39. by donyboy73 59,377 views.
Husqvarna 359 Professional Chain Saw Review
Dec 14, 2015 | Husqvarna Garden
562xp leaking gas
Where does it leak gas? There is a tank vent that should only flow "in" if this vent is faulty it could leak. If the fuel cap is faulty this could be the leak. Lastly, the fuel lines could be leaking. Clean the saw and see if you can determine the location of the leak.
May 20, 2014 | Husqvarna 562xp Auto Tune 20" Chainsaw
Husqvarna 141 clogged fuel vent
The breather is made of a sintered brass plug and beneath this ia what i call a duck bill valve ( because it looks like a ducks bill ) this is a one way valve green in colour which allows air one way into the tank, to test correctly you should do a vacume test via the fuel hose, to remove the valve will normally destroy.
Jun 23, 2012 | Husqvarna 36 41 50 51 55 136 141 154 254...
Gas leaks out of husqvarna 350 when in use
Apr 13, 2012 | Husqvarna 350 Rancher Chain Saw
Gas leaks out when chainsaw is tilted and in use
sounds like you have a cracked fuel tank or stripped out gas cap
Apr 13, 2012 | Husqvarna 350 18 Inch Gas Chainsaw 52CC...
55 rancher leaks thru the gas tank vent
a small amount of fuel leakege shouldnt hurt anything most gas tank vents are in the fuel cap if so replace cap
Nov 15, 2011 | Husqvarna Chain Saw 20" Bar
Hi how to put front spring in to clutch brake
No model 61 listed @ Husqvarna.
How about a 261 here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter 261 (no XPs, Es, just the numbers)
Serial number decode – for use with IPL
06 1500198
06 = year produced – 2006 (single digit before 2000)
15 = week produced - March
00198 = 198th unit Husky produced that week
See the Chain Brake Assembly detail. HTH
Lou
Oct 22, 2009 | Husqvarna Chain Saw 20" Bar
Can't start husq. 261
Most all of these saws use a 50 to 1 ratio. However, i like to use a two cycle oil that has a TCW3 rating to it. This helps to fight again moisture and condensation when the saw isn't being used.
Jul 14, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Husqvarna chainsaw leaks gas when filling
HI. IT SOUNDS LIKE YOU MAY HAVE A PROBLEM WITH THE FUEL LINE, WHEN YOU TURN IT ON ITS SIDE THE FUEL MAY BE LEAKING AROUND THE SEAL ON THE FUEL LINE OR EVEN POPED OUT. ITS HAPPENED TO ME BEFORE. JIMBO
May 18, 2009 | Husqvarna Garden
Husqvarna 50 51 55 61 254 257 261 262 266 268 272 Ignition Coil Logo
53 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
