Question about Home
Install an aqua-dynamic shower drain on 2" pvc pipe
2 Suggested Answers
  • 35 Answers
SOURCE: My shower (fiberglass) drain is leaking and needs
There are a few different drain styles available. If you pop the drain cover off of the shower, does it look like a brass ring pressed up against a rubber boot? If this is the case, that brass ring will have to unscrew first. if this is not the case, There will be a large nut on the underside of your shower that holds the drain in place. Often times, a helper is very beneficial to hold the top part of the drain assembly in place while the other person unscrews the bottom portion. You may say a few choice words during the process, as sometimes an older drain becomes hard to unscrew. There is a special tool for removing the drain, and it is relatively inexpensive. If the pvc is glued into the drain, a section of pipe will have to be cut away to get the tool around the strainer nut. Plan on replacing the trap and strainer. If it is pvc, you will need a coupling, trap, plumbers putty to go around the strainer where it meets the base of the shower, a new strainer, and possibly a couple street 45's and a couple of 45's. Don't forget the glue, primer, and a short piece of pipe.
Posted on Nov 19, 2009
How do you get rid of an airlock in the bathroom drain pipe? There is no specific product....just pvc drain pipes.
Your vent may be clogged. Sometimes birds try to nest inside the pipe up on the roof. It must be snaked.
May 23, 2014 | Home
Aquabrass tub drain control lever cover separated from nut
lock tight red or stronger will bond it together . but forget remove it after
Nov 16, 2013 | Aqua Brass Deckmount 5 pc tub set with...
Aqua steam shower cubicle not doing as it should when pushing control buttons example press radio button shower comes on etc
If you had it installed by some one have them come back and rewire it correctly and if you did it get out the wiring diagram and check your wiring.
Feb 10, 2011 | Plumbing
My shower drain was running slow during a shower, and when i stepped out i realized that the toilet was leaking from the bottom -screw under cap on left side. i am at a loss and do not even know where to...
You can try using rock salt and boiling hot water down your drains. That will help if you have roots getting into your line. Chemicals are not very good for your pipes. If you have PVC drains the chemicals can eat a hole in the pipe because most of them have acid in them. They are also bad for your health (breathing in fumes, getting on skin, etc.) If the line is broken down, has a break in it, it will need to be repaired.
Jan 24, 2011 | Plumbing
8" shower head with thermostatic
your litre per minute usage is probley greater than the recovery time on the cylinder..install a dual coil cylinder and pipe a heat exchanger off central heating system through second coil and you shall double the recovery time on tank,both coils should be controlled through pipe stats for effiency purposes
Jan 15, 2011 | Aqua Brass Akro Shower Kit #2 AQUA BRASS...
My shower (fiberglass) drain is leaking and needs to be replaced. I can pop off the drain cover to reveal a pvc collar that is glued down and unmoveable. I have ripped the ceiling open underneath the...
Nov 08, 2009 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
I have to move the kitchen drain pipe over 2
You need to measure the outside diameter of the pipe then go to your hardware store and buy a flexible coupling of that size.
Oct 15, 2009 | Jacuzzi Rotary PVC Drain Kit DA34-815
The threads are stripped on my Hayward sand filter drain plug.
I've had the same problem every year since I bought this house 10 years ago with my Hayward filter drain and finally MacGyvered a great solution. Went to Home Depot and bought a 1" PVC shutoff valve. The Hayward drain has an outside 1 1/4" thread. The part I got was an 'Aqua-Dynamic' 1" PVC Schedule 40(I can't find a picture of it on the internet). It is a white PVC valve with an inside thread that mates with the Hayward and a red shutoff winged knob. You need to hacksaw the red wings off the knob in order to be able to screw it onto the drain because the filter's base gets in the way. Leave the valve in the open position(especially if water is still draining with filter off) and put PVC cement on the outside of the drain thhreads and a bit on the inside of the valve and screw it on. When the glue dries(5 minutes), you now have a drain that you can open and close every year with ease(you need a pair of pliers because the wings are off the turn knob but it works great!)
Jun 10, 2009 | Hayward SAND FILTER, PRO SERIES
Can't remove broken PVC pipe from bathroom wall...need to install new faucet
there should be an acess pannel there somewhere too get too it ,if not then you will have too cut the wall and replace the pipeing
Apr 15, 2009 | Plumbing
1 drain pipe with 2 traps
eyohe
Please read and understand these entire posts and collect all tools & materials before beginning this project.
Materials needed:
2 - PVC 1-1/2" compression x 1-1/2" female Schedule 40 solvent        weld trap adapters.
2 - 1 1/2"PVC-DWV ADJ P- traps (serviceable)
1 - PVC 1 1/2 X 1 1/2 X 1 1/2 sanitary Tee
1 - 90 degree PVC short turn elbow
1 - 4' piece of 1 1/2 PVC sched. 40 pipe
1 - 4oz can Oatey PVC Regular Clear Advanced Cement
1 - 4oz can Oatey PVC Clear Primer
1 - Small container plumbers putty (To be used as a gasket like bushing between the disposers basket strainer and the sinks surface)
Tools that are needed:
Safety glasses
Latex gloves
Hacksaw
Torpedo level
Measuring tape
Channel locking pliers
Sharpie type pen/marker
Old work rags to clean the edges of freshly cut PVC pipe of loose debris.
Old newspaper to protect your floor/work area and the floor of the sink base.
Any other tools listed with the disposal installation instructions.
Feb 19, 2009 | Plumbing
Home Logo
717 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
