Goodman furnace model 0410752008 , burner kick on & off , on & off then finally kicks on.
You can hear the burner kicking on & off till it finally stays on, after the 1st. time the burner kicks on you hear the fan start running.
  • Steven John Glowacki
    Steven John Glowacki Jan 21, 2013
    The gas furnace ignites , then you hear the blower turn on, then you can hear the furnace ignite several times till it gets hot then you will hear it stay on till close to reaching temp. it is only 7 years old.
  • Leigh Perlmutter
    Leigh Perlmutter Jan 22, 2013
    That is alot for a furnace before something goes wrong! The next thing to check is the thermostat.
    Genius:
  • 1,669 Answers
Either the ignitor is dirty and needs to be cleaned off or the flame sensor is either dirty or needs to be changed. Here's a supplier of parts:
http://www.allpartsheating.com/goodmanignitors.html
Posted on Jan 21, 2013
    The furnace ignites & gets hot, then you can hear the blower start blowing , than you hear the furnce reignite constantly till the furnace runs for awile, & it is only 7 years old.
  • Leigh Perlmutter
    Leigh Perlmutter Jan 21, 2013
    Yes, but...things get dirty, like the flame sensor...CLEAN IT OFF!
Therinnaiguy
  • 1420 Answers
SOURCE: furnace won't stay running
1 FLASH
Furnace fails to operate.
• Integrated control module
diagnostic LED is
flashing ONE (1) flash.
• Furnace lockout due
to an excessive
number of ignition
“retries” (3 total)1.
• Failure to establish flame.
Cause may be no gas to
burners, front cover
pressure switch stuck open,
bad igniter or igniter
alignment, improper orifices,
or coated/oxidized or
improperly connected flame
sensor.
• Loss of flame after establishment.
Cause may be
interrupted gas supply, lazy
burner flames (improper gas
pressure or restriction in flue
and/or combustion air
piping), front cover pressure
switch opening, or improper
induced draft blower
performance.
• Locate and correct gas
interruption.
• Check front cover
pressure switch
operation (hose, wiring,
contact operation).
Correct if necessary.
• Replace or realign
igniter.
• Check flame sense
signal. Sand sensor if
coated and/or oxidized.
• Check flue piping for
blockage, proper
length, elbows, and
termination.
• Verify proper induced
draft blower performance.
Posted on Nov 25, 2008
  • 3280 Answers
SOURCE: Dayton blower fan repeatedly kicks on and off
chech the air filter is clean and the fan limit switch look to change fan limit
Posted on Dec 11, 2008
WaltGe
  • 46 Answers
SOURCE: no hot surface igniter
This is why swapping parts is never a good idea. It could be a board, pressure switch, or several other issues. I'm a service technician and realize that many furnace issues are difficult to diagnose over the phone, or internet.
Calling a qualified, NATE certified technician to diagnose and repair this properly is probably the best solution that I could suggest. Yes, there will be a bill and it will be expensive, but it will be a lot less so than changing out parts you might not need.
www.natex.org
Posted on Jan 03, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: On occasion, my furnace will not kick on at
If your Rheem furnace is less than 10 years old, it may store an error code to help you figure out if it is the furnace or the thermostat. Look at the circuit board for a blinking light. If you have to remove the panel that opens up the door safety switch, it will erase the code. Look for a small viewing port. Next time the furnace fails, prior to doing all the things you did last time, look thru the viewing port to count the number of blinks. Once you get the number, open the cabinet and on the wiring diagram glued to the back of one of the panels'\; there will also be an error code chart. It may give you a starting point where to look. If you have no error code, chances are that your thermostat is freaking out or has a bad connection. Hope this helps.
Posted on Dec 28, 2009
  • 3280 Answers
SOURCE: I have a coleman evcon model dgat070bdf furnace.
Hi check the flame sensor is clean also check out the pressure switch , and check air filter is clean
Posted on Feb 05, 2010
1999 Goodman down draft natural gas furnace. It starts as normal, the burners fire and it warms up, but the blower doesn't start, after a couple minutes the burners shut down and the blower immediently...
IT SOUNDS LIKE THE FAN CYCLE RELAY OR BOARD IS NOT MAKING THE FAN COME ON WHEN IT SHOULD THE BURNER SHUTS OFF PROBABLY BECAUSE IT REACHES THE HIGH LIMIT.
Feb 03, 2015 | Heating & Cooling
Where is the pilot light on a Goodman LP furnace CAPF1824B6CA
I could not find that exact model but I don't think it has a pilot. I think what you have is a faulty igniter.(its a glow plug)
You need to find it-should be on rt side just in front of a burner venturi. Unplug it and check for continuity.
Dec 24, 2014 | Goodman Heating & Cooling
Goodman Model GMV950905DX-an electrical surge burned out the transformer which I replaced, also replaced the circuit board. The variable speed furnace will no longer kick into high speed and it will l
If I remember correctly, there are dip switches on that control board that can be set individually. It is possible that it is just a setup issue. The switch positions should be explained in the installation instructions. I know that some Goodman and Amana two stage furnaces can be controlled by a single stage thermostat, but the dip switches have to be set properly. If the switches are set correctly the furnace will run in low stage heat for approximately 5 minutes and if the thermostat hasn't satisfied yet, it will kick in to high stage heat. I hope this points you in the right direction!
Dec 16, 2014 | Goodman Manufacturing Goodman Gas Furnace...
I have a goodman gmpn that the middle burner has a little bit of flame rollout it kicks the flame sensor switch after about 1-2 minutes then it will not cycle back on. The flames are perfect until the main...
Unfortunately that means there's a hole in the heat exchanger, particularly in that cell of it. When the main blower comes on the air is pushed into the heat exchanger, causing the flame rollout. A heat exchanger crack or blowout is usually what condemns a furnace for good. Goodmans however, have a lifetime warranty on their heat exchangers, so you'll probably be able to find someone to replace it pretty cheap, or do it yourself for free.
Nov 04, 2011 | Goodman GMS90703BXA Heater
We r in our NEW house built in 2008. HVAC unit looks clean, & New. our A/C do not work, or kick on. the unit is Goodman during troubleshoot found-open rollout ->6 flashes gmh80704bn -...
If you didn't reset the rollout switch, the air will not work. The rollout switches are in the furnace burner secton. Look at the burners, the rollout switch(es) are just above the burner. They will have a button on top to push for reset. These rollout switches will generally have two wires going to them.
May 18, 2011 | Heating & Cooling
Goodman furnuce cycling on lights, burner runs 6-12 sec, kicks out exuast fan runs, cycles through and does the same thing after 2-3 minutes, could this be the thermelacouple?
If your furnace has an ehxaust fan, your furnace does not have a thermocouple, it has a flame sensor. The flame sensor is a small metal rod that is in the burner area. It has one wire leading to it. Your problem seems to be flame sensor. If unit does not sense flame, it will kick off the gas valve.
Turn power off, take sensor out, (should be on 1/4" hex screw).. Probably some white film on sensor. Clean with steel wool, or dollar bill if don't have steel wool. Replace sensor.
Jan 24, 2011 | Heating & Cooling
My furnace blower kicks on and the flame lights for about 5 seconds then kicks off. I replaced the igniter recently. The service trouble light blinks continuously.
Your furnace may be kicking out on high limit. Its possible your circ. or blower fan needs to be cleaned. If you don't get enough air moving across you heat exchanger it will kick off on high limit.
Jan 14, 2011 | Goodman GMS90703BXA Heater
When I set my thermostat to 78° the furnace
There seems to be an intermittent problem with the heater itself. You may need to call a technician to provide you with more information.
Dec 02, 2010 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
42 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
