Question about ASUS Computers & Internet
My asus x50z laptop is not starting ,only power led ,no screen
2 Suggested Answers
soumin24
  • 74 Answers
SOURCE: How can i make my X50Z asus laptop work like
go to asus.com\support you can find what do u want
Harry
Posted on Aug 08, 2009
No starting laptop Asus f3t
Maybe the motherboard gone bad. You can test the hard drive and the memory first. First, take out the hard drive and restart your laptop. If the problem persist, take out 1 memory, then restart your laptop. If the problem persist, then take out the second memory and install the first memory. If the problem persist, then your motherboard is dying. Please do not forget to detach the ac adapter and the main battery before you touch the hard drive and or the memory; and read the laptop's service manual.
Mar 01, 2014 | ASUS Computers & Internet
Asus f80 can't start. when connect to power adapter no activity on notebook, no power led etc. led on power adapter ok.
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 21, 2010 | ASUS F80Q-X2AM Notebook
Looking for breakdown and purpose of each part inside my asus x50z laptop
maybe I can help you label it if you send me a clear picture of the mainboard...laptops are not manufacturer-uniform in parts placements.
hint: the one under the aluminum fins with blower is the CPU...if you want to know the chipset or the video controller chip...
yadsyon@yahoo.com
Aug 16, 2009 | Computers & Internet
My x50z asus laptop wouldnot start when i press on/off push button unless after tens of start presses .now i Hibernated my laptop but still start button don't work.so to have my laptop operate i had to use...
did you check the switch if can do a shutdown process after you press the power button for 2 or 3 seconds? If not there's a problem with the switch...but if it shutdowns ok then I suggest have the OS re-installed to isolate the problem. You can use a separate HDD to do a disk recovery install. At the same time you can make the original disk as your backup.
On/off power s/w
have you tryed to flex the laptop, grab eather corner and just gently flex it side to side, laptops generaly flex a little and the internals some times come apart, i had a simular problem and it helped to tighten the base screws a little.
may not fix the problem but is the easyest thing to test to check if it is the problem.
good luck.
Aug 11, 2009 | ASUS AP 8000 PC Desktop
LOOKING FOR ENGLISH VERSION USER MANUAL FOR X50Z VISTA HOME LAPTOP mahmoodmurad94@yahoo.com
Icannot install my driver/manual disc as it is a small disc and as the disc holder is upright it just falls out is there any other way to install tha technika bluetooth class2 USB device
Jul 15, 2009 | ASUS Computers & Internet
What type of hardware or card should i install on my X50Z VISTA HOME LAPTOP to receive satalite t.v stations away from internet.
This cannot be done with a laptop. You would need a special video card, and laptops do not have an expansion slot that will hold such a card. It would need to be a laptop custom made for that purpose.
There are TV tuners that will go into a USB port, but they receive channels broadcast over the airwaves. Satellite channels require a decoder specific to the satellite provider.
Harry
Jul 13, 2009 | Computers & Internet
Computers & Internet Logo
126 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
