Question about Element Electronics Televison & Video
Tv shows no picture or sound or menu options
Tv was on an kids played new ps3 systeym a hr later game was paused an an pictuer had went out tried turning tv off replugen it an had turn off all day still no screen sound or menu
    Genius:
  • 1,003 Answers
Replace power supply or inverter board (note)some power supplies have inverter circuits intergrated on the power supply circuit
Posted on Jan 21, 2013
SOURCE:
jdbouncer
  • 72 Answers
SOURCE: Blank screen, cannot get menu to display, but sound works
Does the lcd screen have a glow to it ? Or is it really dim if u get real close to screen u can see images moving ?
it it has a glow to it you panel lighting is fine but you control board is bad. If you have a dark screen and see faint images you panel back lighting is out u can check the power with a meter at the connection to inverter board on panel.
Posted on May 06, 2008
welcomejee
  • 10594 Answers
SOURCE: My LCD tv's menu screen keeps popping up and won't stop.
Since it is brand new then should be OK.
Please return it to store and get another TV.
Posted on Feb 24, 2009
  • 123 Answers
SOURCE: i get sound but no picture
If the screen went dark blue, this is the way that sets mute the video to protect the tube. However If the screen is very bright blue with possibly blue lines going through the screen, either the blue gun in the CRT has failed which is unusual but can happen or the driver transistor/IC which drives the blue gun has gone short circuit. If you know how to use a meter, you can perform a comparison check by comparing say the red O/P TX with the blue O/P TX. Ian
Posted on Jul 23, 2009
rulds2008
  • 3866 Answers
SOURCE: blinking red light, no picture or sound
You goingto need to replce the powersupply inside www.partstore.com should have it or preorder it for you from the manufacture i think there around $150 they could be cheaper. Another option is Ebay. thanks for using fixa.com please rate.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on Aug 21, 2009
  • 6 Answers
SOURCE: my tv screen just went blank i still get sound but
its the motherboard. i got the same tv with cracked screen. i can sell you the motherboard for cheap or i will buy your lcd to fix mines. if interested email me at [email protected]
Posted on Oct 25, 2009
My Xbox 360 shows a grey screen, the sound works fine and i do have picture
Hey dude, I had this problem and found a solution on another website. Basically, I had either changed the display settings on my tv, or it had done it by itself or my new ps3 had done it or whatever, but to fix it I went into the TV menu, went to display options, on my tv it has something entitled 'Colour system' I changed that to PAL-60 and I now have colour, just to give you an idea of whether you have the same problem, try setting your x-box display to pal-50 and see if that shows colour (if it's easier to do), if it does then try then solution above! Hope it helps!
Mar 13, 2012 | Microsoft Xbox 360 Console
My ps3 is freezing
Hey.
I might sound like a stupid solution, but if the PS3 is in a dusty area it sometimes freezes.. Try to vacume clean it.. Also, is your fan on and does it sound ok. It might freeze due to overheating. If it only freezes when you play games on a disc, it might be a problem with the laser reader, which could also be due to dust.
Hope some of it helped.
Regards
Jun 05, 2009 | Sony Playstation 3 (PS3) Console
I downloaded 2.76. Two days later i went to play the system and it froze on the wavy lines won't let me get to the main menu
youu could try to take a card of some kind. put it about half way in the game spot. then blow in the gap between the card and the black rubber on the ps3. It may build up dust. also try restoring
May 27, 2009 | Sony Playstation 3 (PS3) Console
Can hear sound and see picture but it is all fuzzy
u need to reset the screen options back to regular spec if its not a 1080 p tv if its a regular tv you will need to use the 1080 p tv to fix it before you can use it on any tv
May 22, 2009 | Sony Playstation 3 (PS3) Console
PS3 Works on HD TV without Sound, no sound or display on a reg TV
when u connect ps3 to your tv turn on main switch now red led will come on press and hold touch button ps3 will come on keep your finger on the button and ps3 will turn off again factory settings are now reloaded this will work because i often change from standard v to hd tv
Jan 18, 2009 | Sony Playstation 3 (PS3) Console
Samsung DLP TV and PS3 Problem
Would you please read the manual of TV & PS3 for HDMI cable's
version.
If you match that version, can play.
Dec 27, 2008 | Samsung DLP HL-P5663W 56" TV
PS3 - tv says no signal
You need to change the resolution output on your PS3 to match the capabilities of your TV. If your TV is not HD you can't leave the PS3's video output on HD. SCART is for european television connections. Have you tried using component cables? Have you tried changing your tv's source to Video 1 or Component 1 or HDMI or anything that might work? Good luck!!
Sep 30, 2008 | Sony Playstation 3 (PS3) Console
No picture any more
if your tv has a light blub replace it this is only for hdtvs
May 10, 2008 | Sony Playstation 3 (PS3) Console
"Lag" during play
Have you tried playing the game with the controller connected to the PS3 via the USB cable? Also, just as a test, DISABLE the Internet connection option on the PS3's menu to see if it makes any difference. I found that for some reason some titles (namely Enchanted Arms) have been know to act erratically with an active Internet connection whilst playing.
Aug 25, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
67 people viewed this question
Top Element Electronics Televison & Video Experts
Steve Allison
Steve Allison
LP
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
