Question about Maytag Neptune MDE4000 Electric Dryer
Test door switch - Maytag Neptune MDE4000 Electric Dryer
    New Friend:
  • 169 Answers
More details please.
Posted on Jan 22, 2013
2003 grand marquis ls door locks and trunk not working
Hi, sounds like you may have lost power. Check your fuses, remember, you have fuses in the cab and under the hood. Hope that helps
Oct 10, 2017 | Cars & Trucks
2003 navigator interior Lights and driving lights won't turn off. Door ajar warning on
Is your 'door ajar' or 'dome light' staying on? Forum members suggest various methods that they fixed their issue. The methods include:
  • Adjusting the dimmer
  • Spraying the switch with a lubricant
  • Replacing the switch
  • Replacing the relay
Sep 28, 2016 | Cars & Trucks
LR window won't go up,motor been changed & switched been tested with other switch which tested good.Is there a fuse for this window.
you need to test at drivers door master switch with a test light or volt meter to see if switch is sending voltage to that wire if switch is working and no voltage at door connector,slit open the rubber boot for that door and ck for broken wire in that area this is a prone area that flexes the wire when opening and closing the door causing wire to break
Sep 22, 2014 | 2004 Nissan Maxima
The switches on the 3 doors dont work either even if i try to control the windows or locks from the Driver switch still dont work. Ive tried changing the control switches and still nothing works, the
the drivers door switch is the master switch i would take a test light and check to see if the drivers door swich is sending 12 volts to other doors when pushing down on other windows test with test light to see if any light up if you find one that lights up stop pressing switch and see if it goes out if it does the switch is ok if it does not then the drivers door master switch is probably your problem
Aug 22, 2014 | 2001 Buick LeSabre
Power door locks wont work on chevy colorado 2005
I really doubt one loose door latch will keep all the door locks from working . There are a lot of thing's involved in the power door locks ,relay's , wiring , master control switch etc..... Viewing wiring diagrams , testing electrical circuit's , PWR LOCKS 20A fuse etc....Are the power door locks and the driver power window inoperative?
Did you review the Power Door Locks Description and Operation?
YES - Go to Step 2
NO - Go to Symptoms - Doors
Verify that the power door locks are inoperative.
Do the power door locks operate normally?
YES - Go to Testing for Intermittent Conditions and Poor Connections in Wiring System
NO - Go to Step 3
YES - Go to Step 7
NO - Go to Step 4
Are the power door locks inoperative from a single door lock switch?
YES - Go to Step 5
NO - Go to Step 6
5
Is the driver door lock switch the inoperative switch?
YES - Go to Step 8
NO - Go to Step 9
6
Is the driver door lock actuator the inoperative actuator?
Test the battery positive voltage circuit of the drivers switch assembly for a short to ground or an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Did you find and correct the condition?
Go to Step 21
Go to Step 8
8
Test the ground circuit of the drivers switch assembly for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 13
9
Test the passenger door lock switch control circuits for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 12
10
Test the driver door lock actuator unlock control circuit for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 14
11
Test the door lock actuator control circuits for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 15
12
Test the passenger door lock switch ground circuit for an open. Refer to Circuit Testing and Wiring Repairs in Wiring Systems.
Go to Step 21
Go to Step 16
13
Inspect for poor connections at the harness connector of the drivers switch assembly. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 17
14
Inspect for poor connections at the harness connector of the driver door lock actuator. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 18
15
Inspect for poor connections at the harness connector of the appropriate passenger door lock actuator. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 19
16
Inspect for poor connections at the harness connector of the passenger door lock switch. Refer to Testing for Intermittent Conditions and Poor Connections and Connector Repairs in Wiring Systems.
Go to Step 21
Go to Step 20
17
Replace the driver switch assembly. Refer to Door Lock and Side Window and Outside Rearview Mirror Remote Control Switch Replacement .
Did you complete the repair?
Go to Step 21
18
Replace the driver door lock actuator. Refer to Front Side Door Lock Replacement .
Go to Step 21
19
Replace the appropriate passenger door lock actuator. Refer to Front Side Door Lock Replacement or Rear Door Lock Replacement .
Go to Step 21
20
Replace the passenger door lock switch. Refer to Door Lock and Side Window and Outside Rearview Mirror Remote Control Switch Replacement .
Go to Step 21
21
Operate the system in order to verify the repair.
System OK
Go to Step 2
Jul 17, 2012 | Chevrolet Colorado Cars & Trucks
F-26 flashing
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door
switch is open while the door is locked for more than
5 seconds.
Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Faulty door Switch or CCU board or door not closed during run cycle.
Starting Diagnostic Test and bypassing
the Service History Mode:
Execute this procedure with an empty drum. All
of the steps below must be done in sequence
in order to reach the Diagnostic Test. This
executes the automatic test but does not show
the error history.
Close the door.
Push POWER.
Select the CLEAN WASHER cycle.
Press EXTRA RINSE four times within
5 seconds.
Press EXTRA RINSE to advance to the
next step of the test procedure.
If the starting procedure fails, push
PAUSE/CANCEL, then repeat the starting
procedure.
Nov 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
We have a dishwasher model:SHU9925UC/14. The problem is that when I run a cycle it doesn't fill up with water. Please can you help us.thank you.
Check this all causing not fill water:
  • Check that the water supply is turned on. The valve may be located under the sink.
  • Check the door latch
  • Test the door switch
  • Inspect the float assembly
  • Inspect the fill tube for kinks
  • Test the float switch
  • Check the inlet valve filter screens
  • Test the water inlet valve
  • Test the drain valve lever arm
  • Check the drained valve
The water inlet valve can be identified by the water hoses connected to it. One hose will lead from the valve to the pump/motor assembly in the center of the dishwasher. Check that the hoses are securely connected to the valve and that there are no kinks in the hoses which could restrict water flow.
The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
If the door latch is not properly aligned it may not pull the door tightly closed and the door switch will not be fully depressed. Unless the switch is fully depressed the dishwasher will not operate.
It is a simple matter to determine whether the door latch is theproblem. Simply open the door, close the latch and select a cycle anddepress the switch. Note that if the test is successful, with the dooropen, the dishwasher will operate and water may spray out. Make sure tofirst remove all tools from inside the dishwasher. Do not reach insidethe dishwasher during the test. Now, inspect the cabinet where the doormakes contact with it and locate the door switch. It may have aprotruding button or spike or more likely it is a hole with a piece ofmetal or plastic inside it. You must fully depress that switch. If theswitch is recessed, then use a non-conductive object, such as a woodenpencil, to depress the switch.
If the dishwasher begins to operate during this test, then you have isolated the problem. The door switch is not being fully depressed when the door is latched. There are three likely possibilities:
  1. The door latch is misaligned.
  2. The entire door is misaligned.
  3. The striker for the door switch is damaged or misaligned.
To service the door latch, it may be necessary to access it in the control panel. Access varies by model; on some models you can remove just the control panel on others you must remove the interior or exterior panel of the door.
Before removing the control or interior panel, look first for exposed screws that may allow you to adjust the latch or the strike plate. You may be able to loosen the screws and shift the latch on the door or the strike plate on the cabinet. It may require some trial and error, but you can loosen, adjust, tighten and test until it latches properly.
Good luck ;
Don't forget to rate:
Jul 10, 2009 | Bosch Dishwashers
2004 crown vic interior lights stay on
Don't think you have a door ajar switch problem , more then like the lighting control module is the culprit . Does the door ajar light on the instrument cluster stay lit ?
The interior lighting can be separated into two distinct modes of operation: the courtesy lighting and the demand lighting. The lighting control module (LCM) controls all of the interior lighting in the vehicle, as described in the following text.
The front dome lamps, rear reading lamps, and instrument panel courtesy lamps, can be illuminated either by opening any of the vehicle doors (courtesy lamp function) or by depressing the headlamp switch (demand lamp function).
When any door is open, the door ajar switch grounds an input to the LCM which then sends power to the courtesy lamps. The voltage sent to the courtesy lamps gradually increases from 0 volts to 12 volts within 500 ms (± 50 ms), to achieve the theater lighting effect. When the door(s) are closed the door ajar switch(es) break(s) the ground to the LCM input which then gradually reduces the power from 12 volts to 0 volts within 5 seconds. (± .5 second).
When the headlamp switch is depressed it grounds an input to the LCM which in turn sends 12 volts to the front dome lamps, rear reading lamps, and instrument panel courtesy lamps. When the headlamp switch is depressed a second time, it breaks the ground to the LCM input which then ceases to send power to the front dome lamps, rear reading lamps, and instrument panel courtesy lamps.
The battery saver will disrupt power to the courtesy lamps after 10 minutes, the demand lamps after 30 minutes, and the headlamps after 10 minutes. Turning the ignition switch to the RUN or ACC position will terminate the battery saver feature by disabling the interrupt timers and reinstate power to the lamps.
Do you know what DTC'S are ? diagnostic trouble codes !
LCM Diagnostic Trouble Code (DTC) Index DTC Description Source Action B1322 Driver Door Ajar Circuit Short to Ground LCM Go To Pinpoint Test F . B1442 Door Handle Switch Circuit Failure LCM Go To Pinpoint Test G . B1445 Door Handle Switch Circuit Short to Ground LCM Go To Pinpoint Test G . B1563 Door Ajar Circuit Failure LCM Go To Pinpoint Test C . B1566 Door Ajar Circuit Short to Ground LCM Go To Pinpoint Test H . B1685 Lamp Dome Input Circuit Failure LCM Go To Pinpoint Test I . B1687 Lamp Dome Input Circuit Short to Battery LCM Go To Pinpoint Test I . - All Other DTCs LCM REFER to Section 419-10 .
PINPOINT TEST C: THE COURTESY LAMPS STAY ON CONTINUOUSLY CONDITIONS DETAILS/RESULTS/ACTIONS C1 CHECK THE SYSTEM OPERATION Open and close each door, making sure that each door is completely closed.
  • Are the courtesy lamps still illuminated after the 25 second time-out period?
Yes GO to C2 .
No The system is operating correctly. C2 TEST DOME LAMP SWITCH Depress the dome lamp switch.
  • Are the courtesy lamps still illuminated?
Yes DEPRESS the dome lamp switch a second time. GO to C3 .
No The system is operating correctly. C3 CHECK THE LIGHTING CONTROL MODULE
LCM C2145a
Yes REPAIR circuit 53 (BK/LB). REPEAT the self-test. CLEAR the DTCs.
No INSTALL a new LCM. REFER to Section 419-10 . REPEAT the self-test. CLEAR the DTCs.
Apr 16, 2017 | 2004 Ford Crown Victoria
I have a 2003 corolla le my door light is on and wouldn't go off
I could be a door switch.  1. switch dome light to door 2. close all the doors 3. open each door one by one. if the dome light comes on then you    know that switch is good. 4. closed the door and wait for the dome light to turn off then move on to the next door. 5. If you find a door that does not turn on the dome light than bingo you have a bad door switch. * the door switch may be your problem because of the constant abuse of slamming, closing , and opening the doors. * This test is not 100%. it is just a visual test. and sometimes with a simple visual test you can diagnose your problem while saving time, and $ Good luck!
Mar 29, 2009 | 2003 Toyota Corolla
Wil not fill with water
  • Check the drain valve
  • The door latch pulls the door tightly closed to prevent water leakage around the door. It is also designed to prevent operation while the door is open. The door latch works in concert with the door switch to ensure that the door is tightly closed and latched. The door switch is a separate part from the door latch and is found inside the cabinet. The switch is off when the door is open. Depressing the switch closes the circuit and enables dishwasher operation. Closing the door does not depress the switch all the way. Only when the door is closed and latched, does the door fully depress the switch.
    It is a simple matter to determine whether the door latch is the problem. Simply open the door, close the latch and select a cycle and depress the switch. Note that if the test is successful, with the door open, the dishwasher will operate and water may spray out. Make sure to first remove all tools from inside the dishwasher. Do not reach inside the dishwasher during the test. Now, inspect the cabinet where the door makes contact with it and locate the door switch. It may have a protruding button or spike or more likely it is a hole with a piece of metal or plastic inside it. You must fully depress that switch. If the switch is recessed, then use a non-conductive object, such as a wooden pencil, to depress the switch
    Sep 21, 2008 | Dishwashers
    Maytag Neptune MDE4000 Electric Dryer Logo
    32 people viewed this question
    Top Maytag Dryers Experts
    Tim Whalen
    Sal De
    Are you a Maytag Dryer Expert? Answer questions, earn points and help others
