Question about Panasonic PT-AE2000U Projector
I have a Panasonic PT-AE200U Projector. When I turn on the projector the Lamp indicator lights do not turn on. Tried to replace lamp but no difference. Can anyone help me out.
Power on but no picture. Any Ideas.
3 Suggested Answers
  • 221 Answers
SOURCE: PT-L785U Projector
if the lamp warning light is flashing, this indicates a defective ballast (lamp power module). if the lamp warning light is lit steadily, then the lamp would be at fault.
Posted on Oct 31, 2008
  • 60 Answers
SOURCE: Problems with Projector Panasonic PT-L501XU after change the lamp
was this bought new or second hand?
There is a "Lamp Time" setting that can be accessd using your remote control, check this setting.
Look on page 40 and after that of your manual about ambient temperature bulb failure.
By powering off or hittign the reset button the bulb should stay on IF the projector is gettign a signal from a device to show an image. If the projector is not hooked up to a device, laptop, TV, etc. the bulb may turn off to save hours of operation.
Posted on Dec 23, 2009
PT DZ13KU NOT WORKING AFTER LAMP REPLACEMENT
I think your best bet will be to contact Panasonic Customer service. But the most common cause for this is that the lamp connections weren't properly re-installed, or there's an interlock switch that is in the wrong position from when you had the lamp(s) out.
Apr 11, 2014 | Panasonic PT-DZ13KU DLP Projector
Panasonic PT-AE700E projector light does not turn on, instead the fan runs on high for an infinite time until turned off
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
any questions, feel free to contact me
have a nice day!
Jerry Lampdeng Limited
May 04, 2013 | Panasonic PT-AE700E Projector Lamp
As all the posts on here I have the same problem. My panasonic pt-lb10u turns on, green light flashes, fan comes on. Then the green light turns red and the red lamp indicator light comes on. No light emits...
If your projector won't fire up then you can't reset the lamp counter so that is not the problem.
The combination of LEDs you have given does not correspond to an error message. There should be two LEDs, one of which is the Lamp Indicator, and the other is the Temp Indicator.
It's possible that an overheating problem has caused this. Make sure the projector is in an area where the temprature is between 0 °C (32 °F) and 40 °C (104 °F) and the humidity is between 20% and 80% (with no condensation). It shopuld have unobstructed air flow around it.
Disconnect the power. Remove the lamp and place it aside. Clean the air filters, using a hoover, being careful not to damage the filter which is located on the underside at the front of the projector under a flap.
Carefully reinstall the lamp (when you say you replaced the lamp, did you buy a new PANASONIC lamp from a reputable source?) Try to fire up the projector. Note down any combination of LEDs if the projector doesn't work and post hem back here.
Feb 14, 2011 | Panasonic PT-LB10VU Multimedia Projector
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes...
If the LAMP INDICATOR flashing red then.
Problem: Lamp circuit failure
Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
After changing the bulb image will not come on and solid orange light appears
Other then POWER BUTTON light there are three lights more
1. lamp indicator
2. temperature indicator
3. computer input
witch one light is flashing RED or illuminated RED with POWER BUTTON orange light.
If LAMP INDICATOR light is illuminated RED than lamp runtime has reached 1800 hours. but projector still working.
If LAMP INDICATOR light flashing RED than lamp circuit failure, or abnormal function or lamp unit is damaged. In this case projector doing the same behave just like your projector.
if TEMPERATURE indicator illuminating RED the projector still projecting and if flashing RED than turned of itself
Jan 11, 2011 | Panasonic PT-LB50U Multimedia Projector
After a few seconds the lamp light began to blink red, its a panasonic pt-lb10svu, show no pic at all has a new lamp
Hi, Replacing the lamp in a Sharp LCD projector requires the lamp indicator to be reset. When the lamp needs to be replaced, the indicator becomes red. Resetting the counter for the lamp hours to zero will also reset the indicator to green.
  • Attach the power cord to the projector and plug it into an electrical outlet.
  • Step 2Locate the buttons on the top of the projector and simultaneously hold down the "Enter", "Menu" and "down arrow" buttons, then press the "Standby/On" button.
  • Step 3Continue holding all four buttons depressed until the lamp indicator light begins flashing green.The counter is now reset. Zero hours will now be displayed on the screen.
  • Aug 03, 2010 | Panasonic PT-LB10SVU Multimedia Projector
    Dec 21, 2009 | Panasonic PT L501U Multimedia Projector
    The projector lamp does not turn on
    I have done this on several of our PT-LB50U's with sucess every time.Remove lamp cover and lamp.Then remove top of case by removing 6 screws on bottom.Remove metal shroud that would cover lamp 2 screws and remove 2 screws that hold lamp plug and move it away.You will see a little blue lever for saftey switch move it back and forth from top and bottom put back together and should turn on.
    Jan 03, 2009 | Panasonic PT-LB50U Multimedia Projector
    PT-L785U Projector
    Oct 13, 2008 | Panasonic PT-L785U Multimedia Projector
    My Panasonic PT-LB50U LCD projector flashes red lamp indicator and will not light up. I replaced the lamp and it still will not light. The old lamp only had 20 or so hours on it and it does the same thing....
    this worked for me what i did is: turn on projector then undo the light panel when its on the projector then will cut off, now the light panel pushes down on the hidden safety switch take a screw driver and push down on the switch, the projector will turn on then wait for about 8 sec then release the projector will turn off, repeat step several times until the light flickers, then do a couple more times and the light should come on and should stay steady turn off and let cool for 10 min, this worked for me hope it works for you!
    Aug 12, 2008 | Panasonic Televison & Video
    Open Questions:
    See all Panasonic PT-AE2000U Projector Questions
    Panasonic PT-AE2000U Projector Logo
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    HEMANT GROVER
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
