Question about Car Audio & Video
Car amplifier instalation
I have a 2005 chevy silverado with bose speaker system with the subwoofer mounted under the center console. what wires to the amp do i need to splice into in order to receive a singnal to route to another amp to power another subwoofer.
  • 21 Answers
Ur doin too much...you only use two amps to run a common subwoofer...if you want two subs either hook them both up to the amp you have, or get a bigger amp...hopefully this helps
Posted on Jan 27, 2009
Wiring color code radio
Here is what I show from the manual.
2005 Hummer H2 Car Audio Installation Guide
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Ground Wire: Black/White
Car Stereo Antenna Trigger Wire: Gray
Car Stereo Amp Trigger Wire: Pink
Car Stereo Amplifier Location: Under the Center Console or Behind the Glove Box
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Apr 01, 2014 | 2005 Hummer H2
Where is the amplifier in a 2003 chevy silverado 1500
Hello and welcome. the radio amp is mounted under the center console. the console will have to be removed to gain access to the amp. here is a picture of the amp
Aug 30, 2010 | 2003 Chevrolet Silverado 1500
2005 Chevy Silverado Bose stereo operators manual, how do I set the EQ presets?
My left front speaker sounds distorted at low volume but sounds ok when I turn up the volume.2005 Chevy silverado bose stereo and speakers
Apr 30, 2010 | OEM Systems Car Audio & Video
I would like to see a wiring dieagram for a 2005 tahoe sterio speakers
Radio 12v red/white + radio harness Radio Ground black - radio harness Radio Ignition (GMLAN Serial Data) Radio Illumination yellow (dimmer) + radio harness Factory Amp Turn-on same as power antenna wire Power Antenna white + radio harness LF Speaker +/- tan - gray +,- radio harness or amplifier Notes: If equipped, the amplifier is under the rear of the center console.
At the amplifier, the left subwoofer wires are dk. blue/white (+) - lt. green/black (-). The right subwoofer wires are dk. green (+) - lt. blue/black (-). RF Speaker +/- lt. green - dk. green +,- radio harness or amplifier LR Speaker +/- brown - yellow +,- radio harness or amplifier RR Speaker +/- dk. blue - lt. blue +,- radio harness or amplifier clear.gifthat should be it **** if u need more help feel free to email me at bertman285@hotmail.com
Oct 05, 2009 | Car Audio & Video
How to install a amplifier bose in my 2005 chevy sylverado wiring?
if it has factory bose system, you will need a aftermarket converter box for bose systems, from there most should be able to finish it out.
Sep 10, 2009 | Car Audio & Video
Radio works but no audio. 2005 chevy silverado
check to see if you have bose audio, it will say bose on the door panel speaker grills - if you do the most common failure is the amplifer located in the center console.
Jul 15, 2009 | 2005 Chevrolet Silverado
Please Help ....i have Bose Acoustimass 10, 5.1 system connected
Usually the LFE out is only a line out and is not amplified in any way, so first of all is your subwoofer self amplified or not? Cause if not, the LFE output won't be of much use to you. So if it's not self amplified you need an new amplifier to put between the receiver and the subwoofer. Any amp that supports RCA line-in input will do. Even a car stereo amplifier will work provided you can get a 12volt power supply to run it in the house. If the subwoofer is self amplified though, then all you need is to make an adapter cause none are readily available in stores to go from a RCA connector to 2 wires. You can buy a virgin RCA connector that you can wire yourself at The Source, Circuit City, or any electronics store you have locally, or if you have an old RCA to RCA wire you don't need anymore, you can just cut it in half, strip the 2 wires and you got you adapter right there.
Jul 07, 2009 | Bose Acoustimass 16 Speaker
2005 chevy silverado stereo wiring diagram
Are you trying to install a new stereo? If so will need to re-wire all your speakers because of the bose system.
And if im not mistaken your year truck might need a really expensive harness to install the radio. Here is a link to it.
http://www.crutchfield.com/p_120GMOS04/GM-Factory-Integration-Adapter.html?tp=3486
You should look into this too! http://www.crutchfield.com/p_120GMOS04/GM-Factory-Integration-Adapter.html?
May 22, 2009 | Car Audio & Video
'05 Chevy Z-71 w/ BOSE stereo upgrade. How can I wire the BA-200 ?
Unfortunately, it's not as simple as a crossover. Bose gets its name from making complete systems - meaning - Bose speakers work right because the amplifier is custom built for those speakers, and the deck is custom built for the amplifier- all Bose from beginning to end. The only way to bypass any part of a Bose system is to bypass the whole system, including amp, deck, subs, speakers, eq's, and start over from scratch, unless you are an electrical engineer and can meter components and evaluate them. Bose often has 1 or 1/2 ohm speakers which will not work with after market systems.  If you go to a Bose store, the only system that sounds good is the lifestyle system because it is Bose from beginning to end, just as an example. They are either cheaters or geniuses
Oct 15, 2007 | Audiovox BA200 Car Subwoofer
Car Audio & Video Logo
124 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
