Question about Hotpoint Aquarius WD640 Front Load Washer/Dryer
Ive got an hotpoint aquarius+ wmpf742 it keeps cominup with F-05 pls help i dont know how to sort this out
It says its washin it washs a lil bit then gets stuck,then comes up with the code
WhIzAtIt
  • 136 Answers
SOURCE: error code f 05
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump. The fault is associated with drain out (pump blocked or restricted in some way). Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Posted on Sep 17, 2007
SOURCE: HOW CAN I GET MY HOTPOINT AQUARIUS 1400 - OFF CONSTANT TEST PROGRAM?
This works
To exit the TEST mode, press and hold down the "Start/Cancel" button until ALL of the console lights light up. Press both "Start/Cancel" and On/Off buttons simultaneously until " dOFF " appears in the display. The default setting will now appear and the machine can be used normally.
Posted on Feb 07, 2008
barkencoa
  • 3463 Answers
SOURCE: i cant find the filter on the hotpoint aquarius wd440
Depending on which model you have ,there are 2 possible locations for the filter.
Check to see if there is a removable plastic panel at the botom front of washer, if there is then remove it and if there is a filter there , you will see it, unscrew the cover anti clockwise and clean same.
If no filter there then remove lower rear panel of washer,locate large black hose, and remove clip and hose from bottom of tub,be careful as there will be some water run out.
Remove plastic filter and ball ,clean and replace, and refit hose, making sure it is secured properly.
Test for leaks.
Plz rate my solution.
Thanks.
Posted on Jan 15, 2009
barkencoa
  • 3463 Answers
SOURCE: HI F 05 IS FLASHING ON MY WASHING MANCHINE
You will probably need to clean the pump filter.
To access the pump filter,remove the lower plastic panel at front of washer, there you will see the filter, unscrew the cover anti-clockwise, remove filter and clean.
This should clear the fault.
If it does not , let me know, and i can can tell you other things to look for.
Please rate my fixya solution.
Thanks.
Posted on Jan 31, 2009
SOURCE: How do I change the door boot seal on a Hotpoint Aquarius WMA31N?
Ok - I will answer my own problem seeing as though I have now fitted it!
1. remove door (2 screws)
2. There is a tensioned wire loop holding the front part of the boot seal in position. - prize off the plastic cap at the 11 o'clock position, all will become clear and you will be able to remove the wire loop.
3. Remove top of washing machine (2 allen screws behind caps at the front.
4. Remove soap dispenser draw and any screws holding the front control panel and top of the door.
5. Remove bottom front plinth (just pull it off) underneath are a couple of screws holding the front panel part of the machine, remove these.
6. Remove front of machine giving you access to the steel band which locks the other end of the boot seal in position. Slacken this band right back using a nut-spinner screwdriver. Pull off the old boot and clean the lip ready for fitting of the new boot.
7. Fit new boot seal using a squirt of washing up liquid as lubricant if needed (mine didn't) to reseat the seal.
8. Refit and tension steel band.
9. Re-assemble front panel, ease boot back into front lip position then refit wire loop using a suitable pair of pliers/molegrips to crimp the retaining plastic cap back in situ.
Posted on Nov 02, 2009
Hotpoint Aquarius WMPF742
just need to know,if its a sealed back on the machine,as i have been told the bearings have gone,also if it is sealed,i have been told to scrap the machine???
Aug 12, 2012 | Hotpoint Washing Machines
When washin drying my black shirt get covered in bits
The machine likely has had a paper towel washed / dryed in it. There are still pieces of it hanging around. It should clear up over time.
Charlie
Jan 13, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius wf320 door won't open.
what you need to do is say 'abracadabra' 3 times , then swear allegience to the queen always remembering Glasgow Rangers are the best ..hee hee
May 04, 2009 | Hotpoint Aquarius WF000 Front Load Washer
WF340 hotpoint aquarius WASHINING MACHINE
Hi, Remove the drive belt from the drum & motor then turn the drum be hand, Is it noisy? if it is then the drum bearings need replacing i have used this website before and they are very good.
http://www.candmdomesticappliances.co.uk/section.php/88/1/hotpoint-washing-machine-spare-parts
Apr 22, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Door Locked. Cannot open. Washine inside.
Try buttons "dry" & "spin" together for a few seconds. This is the child lock display.
Or press "end of cycle" for over 3 seconds.
Or press "options & select" till the light goes off.
Works for other machines..............And please rate me if helped
Mar 16, 2009 | Hotpoint Aquarius WD63 Front Load...
I dont where the trap is to let out water in the drum it wont let any water out when i wash its a hotpoint aquarius wash system plus
There is always some sort of drain plug at the base of the washing machine - though it may be a bit tricky to locate. If the pump out is not working there may be debris - buttons, coins etc trapped in the pump.
Apr 27, 2008 | Washing Machines
Hotpoint Aquarius Extra washine machine. Won't start..
hi there the pcb behind the control panel is blown this is due to the carbons running low
Nov 03, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Error code f 05
Sep 17, 2007 | Hotpoint Aquarius WD640 Front Load...
Hotpoint Aquarius WD640 Front Load Washer/Dryer Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
