Question about Kwikset Locks & Locksmithing
Kwikset door lock jams inside and out.
It seems to have nothing to do with the key. It jams and with a lot of jiggling sometimes opens, but now nothing helps. It is jammed from both inside and out. We can only get into the house through the garage.
  • 3,904 Answers
Is sounds like the door settled or shifted and jammed the bolt in the jamb. I would put a pry under the door and gently lift while turning the key. That is only for the up and down but could be that the door needs to be pushed in or pulled out while turning the key. If you want to get real crazy just pop it off the hinges and investigate. If the lock still does not work with it free from the jamb then you will just have to replace the lock.
Posted on Jan 21, 2013
  • mikadot
    mikadot Nov 22, 2013
    All doors can be replaced easily. Yes you could purchase the door and handle first. Call a contractor, builder or handyman and tell them you have the door. I'm answering from London Ontario :)
Two guesses: 1) the door hinges are loose, so the door isn't fitting in the jamb properly. If you can open the door, tighten the hinges.
2) The door locks themselves have something wrong. Take them off the door, and take a look. If it's something simple, like a loose screw or some dirt got in it or something, then go ahead and fix it. If you can't see the problem, or don't know how to fix it, either call a locksmith or return the locks to the store you got them from and get a new set.
Posted on Nov 16, 2013
4 Suggested Answers
SOURCE: i have a smart key kwikset lock and i used the
original key or new one dont work now how to fix this please , i have the smart key kwikset.
Posted on Oct 12, 2009
rsmith972278
  • 160 Answers
SOURCE: the key for my kwikset door handle lock won't
The answers to your problem are very numerous.
Usually what has happened is that when the lock was installed the pins (the part of the lock that rides on the cut part of the key) were not facing down. This allows dirt and debris to collect in the pin holes and also if a spring breaks it won't push the pin up to the cut part of the key. Some locks you can't even rotate to a position that faces down.
What I suggest is removing the knob or lever lock from the door and blowing out the key hole with compressed air. Work the key back and forth through the lock and blow it out again. If this doesn't work ... try and get a refund or a replacement from wherever you got it. Remember your time is worth money and so is your frustration. Don't waste allot of time trying to fix something that can be replaced relatively cheaply.
Thanks,
RSMITH972278
Posted on Oct 13, 2009
SOURCE: Loose Kwikset Chelsea Deadbolt
I just had the same problem as samrpetrich with a loose kwikset deadbolt. Here's how I fixed it - on the inside of the door, take off the latch that flips the deadbolt in and out using a very small allen key. There is a round plate cover that is snapped on top of the inside deadbolt mechanism. If you look on the bottom aspect of this round plate you'll see where it snaps on; once I saw where to apply pressure it came off easily - taking off this plate exposed the two screws beneath that were loose. Once I tightened these, I snapped the plate cover back on, but the dead bolt latch back and everything is tight again. Hope this helps.
Posted on Jan 31, 2010
Will all kwikset keys unlock all kwikset locks?
I've heard of this problem happening. Whenever the key is changed, check it several times before locking the door. If you have keys duplicated, the duplicates must be very accurate or they might not work reliably. Difficult to know what causes this, unless someone is tampering with the lock, or resetting it improperly. Or could be defective cylinders - which would be disappointing. Pin-tumbler cylinders do not have this problem, it's something unique to Kwikset
Smartkey.
May 21, 2014 | Kwikset Professional Door Lock...
Kwickset door handle fell apart on my front door help
Kwikset locks are inexpensive because they do not have replaceable parts. Buy a new one.
By the time the lock breaks, it's probably time to get different keys, but if you have so many keys in the hands of people you cannot contact, or you have more than three other locks keyed alike, and you must have the new lock work with the same keys as before, the place where you buy new locks probably has someone who can rekey the new lock to your old keys. Kwikset also sells locks that you can rekey to other Kwikset keys yourself. They are more expensive than other locks of the same type, but could save money long term, especially if you find a need to rekey your locks a lot (lots of visitors, part-time tenants or roommates, your kids lose their keys a lot, etc.)
Sep 07, 2013 | Kwikset Professional Door Lock...
Our Qwikset Powebolt system is not working properly. I can lock the door from the inside and someone on the outside only has to press the lock key and it opens! How do we resolve this issue?
I think that you lockset is not set up for the proper "handing" of the door; that is, are the hinges on the left or right as you face the door from the outside. Although is see on the Kwikset website that the Powerbolt can be changed, I did not find out how to do it. I suggest that you call their Customer Service and they should be able to explain how to change it over. Here's the link:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Kwikset Customer Service
Call: 1-800-327-LOCK (5625)
Feb 09, 2011 | Kwikset UltraMax Powerbolt 1000
Just installed a Schlage secureKey deadbolt. The key goes in the keyhole but won't turn. The inside works fine - locks and unlocks.
the first thing to check is to take the hardware off the door and check the lock cylinder with the key and make sure the key works the cylinder,, lots of times the tail piece is in the wrong position and will not allow the lock to turn. also - sometimes the latch and the lock are not lined up and bind, preventing the cylinder from turning.
but maybe the cyclinder itself is keyed wrong and if you take it back to the store where you bought it you should be able to swap it out for one that works,, install that one and all should be good.
c...
Jan 19, 2011 | Kwikset Professional Door Lock...
Kwikset Smart Key Deadbolt Won't Unlock
Kwikset Smart Key locks are complete junk. I am a locksmith and I am constantly going from house to house replacing these "dumb key" locks with original kwikset pin tumbler locks. What happens is either your key or the wafers inside the lock wear slightly, slightly enough to cause your keys to not turn, and since these locks cannot be picked due to a side bar system, they must be drilled off and thrown away when this happens Unless you have another access point to get in the house. If you do remove lock from the inside, throw it in the trash, buy original kwikset and replace.
Dec 13, 2009 | Kwikset Locks & Locksmithing
Kikset dead bolt is loose on front door from the outside...
there should be a small allen screw on the shaft of the thumb turn on the inside. loosen the allen screw, pull off the inside thumb turn and take a small flat blade screwdriver and gently pry on the edge of the cover. It will come off. the 2 screws are under the cover plate. If this helps, lt others know. thanks
May 31, 2009 | Kwikset Professional Door Lock...
Jan 23, 2009 | Kwikset Professional Door Lock...
Locks & Locksmithing Logo
312 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
J.D. Browning
J.D. Browning
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
